Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Engine Trouble  (Read 2079 times)
Offline Stephen1
  • Where there is a will, there is a way.
Engine Trouble
« on: December 06, 2009, 10:42:22 pm »
I was milling  wood today on my 1st day of vacation, and things were looking good. I cut some logs for a neighbor who gave me some logs and some cash, and then along came Murphy, the clutch flew off jammed the blade. That was not the worst, the keyway and the key sheared
I do not know a great deal about motors, but I think this the end of the crankshaft
this is the inside of the clutch where you can see the key is also broken.
Can I fix this or is this the time to upgrade to a new motor?
This motor is a 10 horse Tecumseh snow king engine.
I have been wanting to upgrade to a bigger motor and this might be the time.
Offline fishpharmer
Re: Engine Trouble
« Reply #1 on: December 06, 2009, 10:50:12 pm »
So how much cash did the guy give you?
Aw go ahead and replace it. 8)
I built my own band mill with the help of Forestry Forum.
Offline Stephen1
Re: Engine Trouble
« Reply #2 on: December 06, 2009, 10:51:59 pm »
hey fishpharmer, not enough for a new motor,
So---- do I go Diesel - gas - or electric
Offline fishpharmer
Re: Engine Trouble
« Reply #3 on: December 06, 2009, 11:00:41 pm »
Can't really help you there.  There's lots of folks with experience repowering that will hopefully chime in.  I always liked the quietness of electric and no smoke or fuel to deal with. Seems electric would limit portability.
Offline Stephen1
Re: Engine Trouble
« Reply #4 on: December 06, 2009, 11:05:23 pm »
I like the idea of electric also, except the portability, but it does not seem like I move this mill very much, I have a generator that will handle 220 but I don't know if it would handle running all day.
Offline logwalker
  • Got Logs??
Re: Engine Trouble
« Reply #5 on: December 07, 2009, 01:55:49 am »
Is there any shadetree in you? Weld that shaft up and take a hand grinder and put the keyway back in. What happened to cause it to do that? Joe
Offline jpgreen
  • My Boy- Snoopy Dogbone Green
Re: Engine Trouble
« Reply #6 on: December 07, 2009, 09:51:13 pm »
Hard to tell from your pics, but that almost looks like a pressed on bushing on the end of the shaft that failed?
Also- hard to tell, but it looks like that clutch and pulley set awfully far out on that shaft.
Maybe a stepdown shaft that was adapted for the machine, with a pressed on bushing to accomodate the clutch? Maybe one reason it broke that way.
If that's the case, you could possibly clean it up, and make a new bushing for it.
-95 Wood-Mizer LT40HD 27 Hp Kawasaki water cooled engine-
Offline sawguy21
Re: Engine Trouble
« Reply #7 on: December 07, 2009, 10:00:57 pm »
Replacement will be the way to go. Tecumseh engines and short blocks are no longer available, the company went under a year ago, so IMHO a Briggs and Stratton would be the cheapest alternative. Honda and Robin are very good but generally a little more expensive. Diesel is nice but quite pricey.
Offline Stephen1
Re: Engine Trouble
« Reply #8 on: December 07, 2009, 10:13:14 pm »
Okay Guys here is where I'm at now after listening to everyone here and a friends son, a small engine mechanic.
what we discovered was what jpgreen has said, the clutch was placed to far out on the end of the shaft. I noticed it all along but did not know what to do about it. I have now remounted  the motor and tomorrow we are going to weld the clutch onto the shaft. I know I shouldn't but it will let me keep cutting and looking for a better price on a new motor. I'll post some pictures of what we do tomorrow.
Offline Jim Spencer
  • Washington, Mi
Re: Engine Trouble
« Reply #9 on: December 07, 2009, 10:54:00 pm »
You could repair this with JB Weld.
I have done this about 5 years ago and haven't had a problem yet.  I know when I do have a problem now I will have to replace the motor.
Offline edwardj_
Re: Engine Trouble
« Reply #10 on: December 08, 2009, 01:24:11 am »
Being a small engine mechanic myself I do love JB weld...  but sad to say this isnt the place for it...   If it is possible for you to move the engine in closer I would suggest shortening the crankshaft up and if you need the threaded end on it you could re-cut the threads.  It looks like most of the keyed part of the clutch is still intact.  If you are looking to find a replacement engine and want an equivalent engine and consider the Honda Line go with a 9hp one.  If you want to go a bit bigger the 13hp.  I dont know the size of your mill so I cant suggest which would be a better choice.  Good luck on your fix/hunting
Offline nas
  • Measure twice and cut aw DanG
Re: Engine Trouble
« Reply #11 on: December 08, 2009, 01:17:16 pm »
Stephen, I have a 13hp honda i can sell you.  $7000.  It comes with a free Norwood mill attached to it ;D.
  I also know a good welder in Burlington if you want his info call or PM me.
Nick
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Offline Stephen1
Re: Engine Trouble
« Reply #12 on: December 08, 2009, 01:22:21 pm »
I know you have a good motor you can sell me, the business manager has issues with the idea though. I am going this afternoon to get the welding done. we'll see how it goes
Offline Stephen1
Re: Engine Trouble
« Reply #13 on: December 13, 2009, 02:59:27 pm »
I went up to visit my buddy and after some talking and visiting, we welded the clutch onto the crank shaft. He had a little concern as the metal on the clutch was almost like a spring steel, very hard.   I have been using it for 2 days now and it is still on there.  8)
I was able to trade him some aluminum shingles for his wood shed,that I had scrounged for free. Nice when things work and I didn't have to buy a new motor just yet.
Online ladylake
Re: Engine Trouble
« Reply #14 on: December 13, 2009, 05:41:27 pm »
Looks like you have the clutch way farther on the shaft like it should have been, I wouldn't have welded it or just a little that could be ground off easy.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline Stephen1
Re: Engine Trouble
« Reply #15 on: December 13, 2009, 06:29:52 pm »
Your right, I had to re drill the platform for the motor mount, which allowed me to put the clutch on further. The key in the clutch was part of the casting and it was broken also. We debated on how much to weld, and went with do it all. probably regret it ltr.
Online ladylake
Re: Engine Trouble
« Reply #16 on: December 14, 2009, 05:59:25 am »
 With the broken key I think you did good, if you need to get it off grind what you can with a angle grinder, then use a good hole saw with close to the same ID as your shaft.  I've welded a few pulleys to shafts with no regrets, they were shot anyway and are still running good 5 years later.   Steve
Offline Chico
Re: Engine Trouble
« Reply #17 on: December 15, 2009, 10:52:54 pm »
I would have cut the shaft or had it turned and had a sleeve made for it  and tack the sleeve maybe or have it about .005 small heat it and put it on You're prob going to have some probs from that welded shaft but hey who knows sometimes you do what you gotta do
My Daughter My sailor MY HERO God Bless all the men and Women fighting for us today If you see one stop and thank them
Online ladylake
Re: Engine Trouble
« Reply #18 on: December 16, 2009, 04:42:19 am »
 Sleeveing that shaft would have cost quite a bit, it can still be done if he has troubles. Looks to me like its going to stay on good , just so the clutch keeps on working.   Steve
Offline ely
Re: Engine Trouble
« Reply #19 on: December 16, 2009, 08:41:44 am »
thats how i would have fixed it too.
Saw Anywhere!
