Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: sawing out a house  (Read 7887 times)
Offline Planman1954
Re: sawing out a house
« Reply #100 on: January 12, 2010, 07:48:08 pm »
Finally thawed out enough around here to get back outside to the mill. I took a photo of the shingle cants loaded on the 4 jigs. It's time to make shingles!   ...12 at the time.
Norwood Lumbermate 2000 / Solar Dry Kiln
Offline 1GUNRUNNER
« Reply #101 on: January 14, 2010, 09:38:10 pm »
No tar paper or at least vapor barrier?  :-\
Offline trailman
« Reply #102 on: January 16, 2010, 09:54:37 am »
i once worked for a builder who built a house in a very wet spring time. the frame wasnt very dry before the drywall went up and later on drywall screws were poping every where.! :D
Offline Planman1954
« Reply #103 on: January 16, 2010, 10:30:58 am »
Trailman:   The shingles are on a barn. I'm going to use wood on all the interior as well as the exterior...no sheetrock. I do plan on using a kraft backed insulation for an interior vapor barrier.
There is no felt under the shingles so that they can stay dry all the time...this will help to reduce rot. (You may want to read the earlier posts on this thread). I hope ya'll have a good weekend!  Go Saints...
Planman
Offline JD350Cmark
« Reply #104 on: January 16, 2010, 11:36:12 am »
  Planman -  Looks good.  Do you have to turn the cants after each cut to get a taper on each set of shingles?
2004 Wood-Mizer LT40HDG25
Offline Planman1954
« Reply #105 on: January 16, 2010, 08:09:18 pm »
No JD. The cants stay put on the jig. If you look back on page 4 of this thread, about half way down the page on the second photo of the jig, you'll see a little stick. All I do is walk the line after each cut and flip all the sticks up, or flip all the sticks down. This gives a taper. They work pretty well. I do get a little vibration sometimes on a cant here or there, but that is due to a little bit of slack between the cant bottom and the side of the jig. I just put a little taper wedge along the bottom of the cant, and the thing usually stops shaking so bad. Also, I've found that the dimensions on the scale for each cut is: Sticks up..1/4" cut.  Sticks down..5/8" cut. Works like a champ. Oh, and I walked out to the barn today in the rain...just for kicks to look up to see if there was any water under the area that is covered... Thank GOD! It worked. :)
Offline paul case
« Reply #106 on: July 17, 2010, 09:24:39 am »
plannman
hows the shingles holding up?
pc
EZ Boardwalk and WM 94 LT40 hd
pc
Offline Planman1954
« Reply #107 on: July 17, 2010, 02:45:41 pm »
They're holding up better than me! I've still not gotten all of them on. I'm still tryin' though. It's slow doing all the work yourself....from logs to installed (and stained) finished product. I plan on posting a photo of the finished roof soon...I hope. And also, this week I'm rebuilding my father's old trailer...completely. The last load of large logs killed it. I got the boards and bolts off of it today before it began to rain, and have a buddy lined up for Monday to re-weld the broken supports. I'm going to grind all the metal, prime it, paint it, recut boards and paint them (Not the bottom side) and install them. Then I'll put on new lights, and I should be good to go for many years...Anyway that's the plan from the Planman1954!!
Here's a before photo of the 45 year old trailer:
Offline paul case
« Reply #108 on: August 07, 2010, 09:05:43 am »
planman,
does it look any different yet? i was wondering if you been roofing lately with it being so hot.pc
pc
Offline Planman1954
« Reply #109 on: August 07, 2010, 10:08:09 pm »
It does look a little better. Not through with the shingles yet though. I had to stop last week and do the trailer restoration that I showed in the General Board thread. I cut 28 cants (2 runs ) of shingles yesterday and this morning. I'll start putting them on Monday morning. I''ll problably have to do about 8 more full runs of 14 cants to have enough to finish. Thatl be about another 30 short logs worth...That's why it takes so much time... but I'll persevere. I'll post a finished pic when it's completely done.
Later
Offline paul case
« Reply #110 on: August 18, 2010, 11:03:23 pm »
 there is some pics of the addition to the house. the first is live edge erc paneling. the second is red oak lap paneling or wall board. the third shows the steel exterior. pc
pc
Saw Anywhere!
