Get your Forestry Forum Hats while they last!
Just a question. Are you carrying the board return "shelf" in it's carry position in the rear? I don't carry mine. If I did, the tongue weight would be even less.
Another thing that I just thought of is the small table that sits just behind the hyd. box used to be carried to the back of the mill and I think it stays on the front now correct me if I'm wrong, but that would add some more wieght to the hitch.
they just happen to see in your now-open box...Lj
Quote from: ljmathias on December 05, 2009, 07:33:39 pm they just happen to see in your now-open box...Lj The main reason to keep your tool box closed and also your truck doors and windows closed is to prevent "sawdust drift" from gradually depositing a layer inside of the tool box and inside of your truck. My habit is to always keep everything closed.......
Maybe the simplest way to balance it woud be to make (weld) a tool box for the back of the mill. Then you would have to go buy a couple of hundred pounds of tools. Oh dear! That would be dreadful.
Magicman the only thing I can't keep shut is my mouth.
I've never had anything but a stationary mill.Do any of you set up one of those portable tents to keep the sun/rain off at least at the sawyers end??or are they more trouble than their worth??Frank C.
and there was some light flurries and lots of wind. 20KM from my destination aNick
