Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: 066 hard starter  (Read 587 times)
Offline welderskelter
066 hard starter
« on: November 20, 2009, 12:37:17 pm »
My 066 has had a muffler mod and it has always been a hard starter.(5 pulls then fire, 5 more then start wide open). Can a person put a primer button on so it will start on first pull? Just curious. Thanks Harold
Offline Al_Smith
Re: 066 hard starter
« Reply #1 on: November 20, 2009, 07:54:15 pm »
Noooo . Playing with the muffler has little to do with weather the  thing starts . A screwed up carb has everything to do with how it starts .
If you have to full throttle that contraption to get it to go ,the carb is flooding . Rebuild the thing .
Offline joe_indi
  • The older I get the more I learn
« Reply #2 on: November 20, 2009, 10:08:46 pm »
5 pulls + 5pulls....that's 10 pulls.
That is 5 pulls too many. Not the greatest thing for starter life.
Check the pickup body and L screw setting.
Try drawing out the starter rope slowly, with the choke on 3 times.Twice more with off choke.
One smart pull and it should start.
Saves a lot of starter life and better for the elbow.
Joe
Offline GASoline71
  • 'cuz chicks dig scars...
« Reply #3 on: November 22, 2009, 09:19:02 pm »
Floodin' the saw... click the choke off after the first burble.
A primer bulb on a Stihl chainsaw would be a blasphemy...   :D
Gary
\"...if ya mess with the bull... ya gets the horn.\"
Offline edwardj_
« Reply #4 on: November 23, 2009, 08:25:32 pm »
How old is the saw and have you ever had it rebuilt?  My guess is that there are limiter caps on the carb.  If there are be carefull if you try and adjust them.  if you lose the cap and there isnt a spring holding it in place it will self adjust.  you also need a tach to properly adjust it.  you can also check the "float" height on it.  If it is doing its first burp after 5 pulls that is not unusual...  but 5 after that is odd.  you also should not need to have it WOT but should start properly on the fast idle setting.
Offline rebocardo
  • Atlanta GA
« Reply #5 on: November 25, 2009, 01:43:27 am »
FWIW: My 066 was one of my easiest starting saw, maybe three pulls.
Offline Al_Smith
« Reply #6 on: November 25, 2009, 05:12:32 am »
Oh the danged things seem to have a personality . I've got a few that will fire on 5 or less after sitting 6 months and others that need a prime if the sit over a few days .
Saw Anywhere!
