Welcome, Guest.
Please login or register and see what all the Forestry Forum has to offer.
March 12, 2010, 06:30:50 AM
Show my unread posts or Show new replies to my posts
Home Help Search Calendar Login Register
Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Your source for firewood processors, gransfors axes, logrite tools, grapples, winches, forestry trailers
Loggers Insurance Agency provides insurance for loggers, log haulers, logging equipment and sawmills including portable sawmills. We specialize in logging and lumbering insurance in Wisconsin, Minnesota, Michigan, Iowa, Illinois, Indiana, Kentucky and Missouri
Store
+  The Forestry Forum
|-+  General Forestry
| |-+  Drying and Processing (Moderator: Den Socling)
| | |-+  attic fan in kiln
Pages: [1]   Go Down
Print
Author Topic: attic fan in kiln  (Read 529 times)
kelLOGg
Full Member x2
Offline Offline
Gender: Male
My Photos: Go to my Photo Gallery
What you get when you don't get what you want is experience.
« on: November 10, 2009, 06:04:25 AM »
Has anyone used an attic fan for circulation in a kiln? Seems like the bearing lubricant would take the heat since an attic is comparable to kiln temperatures.
Bob
Logged
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
pineywoods
Senior Member x2
Offline Offline
Gender: Male
Forecast: Audio
Engineering analysis-just sittin thinkin about it
« Reply #1 on: November 10, 2009, 11:05:24 AM »
Bearings aren't the only concern. I built a solar kiln for a sawyer up the road. He bought plastic box fans from wal mart. The blades melted and fell off.  We also found that the fans last a lot longer if you leave them running all the time.
Logged
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
James P.
Senior Member
Offline Offline
Gender: Male
« Reply #2 on: November 10, 2009, 11:24:01 AM »
kelLOGg, I have 5 attic fans I bought new several years ago for a kiln. I have yet to build a kiln but I am hoping they will do the job. The only thing concerns me is they aren't enclosed motors and the moisture will have a negative effect in short order. The price for them is a lot cheaper than a true kiln fan . Plus kiln fans have alot higher cfm and HP from what I remember. I hope someone with some experience using them will post their results.
Logged
solidwoods
Senior Member
Offline Offline
Gender: Male
Best way to make the most money with a portable mill is to cut the least lumber you can.
WWW
« Reply #3 on: November 20, 2009, 09:02:37 AM »
Now that's funny Ya dats a good one!
The atic fan should have a temp rating on it if not check Grainger for the model # and check the spec info on it.
Logged
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
davemartin88
Full Member
Offline Offline
Gender: Male
« Reply #4 on: November 22, 2009, 08:48:37 AM »
Bob
I have a small (4'x8'x8') solar kiln using two solar powered attic fans for circulation. Been in use for about 3 years with no problems, fan is metal so nothing has melted! They were expensive but so far, so good.
Logged
solidwoods
Senior Member
Offline Offline
Gender: Male
WWW
« Reply #5 on: November 22, 2009, 02:01:53 PM »
In my kilns I use furnace squirrel cage fans.  They are rated for high temp.
We can get them from the scrap metal yard.  They allow us to remove them from a furnace, they charge $.10 per pound for the fan.  I can check it with a VOM to see if it has a short, also I check the fan for excess spindle play.
If we get the fan home and its bad, the scrap yard will buy it back for $.05 per pound.
I have the fans mounted on a piece of plywood with a hinge that has a quick release hinge pin. a few times per year , I take them down and oil the bearings.
Also these type of fans are typically 3 speed so I run them on high speed.
But they are not reversible, and they are more trouble to clean (kiln fans get caked on dust real easy).
jim
Logged
Ret. US Army
N. Central TN.
kelLOGg
Full Member x2
Offline Offline
Gender: Male
« Reply #6 on: November 22, 2009, 05:24:00 PM »
Well, thanks for all the feedback. I got 2 attic fans from Amazon.com - all metal with re-oilable bearings. Built a box to house them and this week I will put them in the kiln and be back on the "air".
I also got baseboard heaters installed to get the temp to ~135 -140*. The kiln is full of 7% MC white oak. I will reheat with the new heaters to kill possible bugs and empty the kiln.
Logged
Pages: [1]   Go Up
Print
Jump to:
Login with username, password and session length
Powered by SMF 1.1.4 | SMF © 2006-2007, Simple Machines LLC
Page created in 0.16 seconds with 20 queries.
Forestry Forum Rules and Disclaimer
