Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Trailer Building Legals  (Read 2146 times)
Offline woodsteach
  • My wife, 3 daughters, and mill.
« on: November 09, 2009, 01:00:50 pm »
I have a student building 36' combine header trailer and I have some of questions:
How much does a header weigh?
Are lights required?
Safety Chains?
This trailer is going to be pulled down the highway.
I get tired of the good ole farmer getting by with the SMV, no lights, no brakes etc.
How is it that they can pull this down the road with no tags and my 31' gooseneck has the brakes, tags, lights, safety chain, the brake away brake activator and this "farm trailer" isn't required to have this stuff.
Or is it required and farmers are exempt? or just get by with it.
If the student makes this and pulls it down the road w/o lights,breaks, safety chains can it come back on me as I let it leave knowing it was illegal?
woodsteach (teaching metals as well)
well after some more searching I found this:
       """Raising safety standards of trailers.(Machinery)
Farmers Weekly
| July 06, 2007 | COPYRIGHT 2007 Reed Business Information Ltd. This material is published under license from the publisher through the Gale Group, Farmington Hills, Michigan.  All inquiries regarding rights should be directed to the Gale Group. (Hide copyright information)Copyright
Ensuring your combine header trailer is safe and legal on the roads could be trickier than you think, says Geoff Ashcroft
Combine header trailers sound like an unlikely candidate for controversy. Under the Road Vehicles (Construction and Use) Regulations 1996, they are classed as an agricultural trailed appliance conveyor, as long as they meet certain set criteria.
These include an unladen weight of less than 510kg, an indelible mark showing that weight and a pneumatic tyre fitted to each wheel. Moreover, they must be designed and built for the purpose of conveying a single agricultural trailed appliance or one agricultural, horticultural or forestry implement.
But if the header carrier has an unladen weight of more than 510kg it is classed as an ordinary trailer. And if the carrier and its load then exceed 750kg, it must be fitted with brakes.
And here lies an additional dilemma, since many combines do not offer a trailer braking service with which to couple the header trailer.
"Even if you stay below 20mph and tow the header behind a tractor, if the weight criterion is not met and you're out on the public road, then you're breaking the law according to Construction and Use Regs," warns independent transport adviser Mike Braithwaite.
It is a scenario that seems to have crept up on manufacturers, many of which continue to provide header trailers that clearly fall outside the regulations."""
So you are telling me that a $300,000 combine that pulls its own header trailer doesn't have a light/brake hook up!!!
Brand X Swing Mill, JD 317 Skidloader, MS460 & 290, the best family a guy could ever dream of...all provided by God up above.  (with help from our banker ; ) )
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
-Doug
Wooho! I found out how to have the Adobe Reader X toolbar displayed when I open a .PDF.
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
http://www.xmission.com/~sherwin/sawyer1.
Offline zopi
Re: Trailer Building Legals
« Reply #2 on: November 09, 2009, 07:33:23 pm »
Whoever came up with thst phrase ought to be fired...then shot...
out of a cannon.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline red oaks lumber
« Reply #3 on: November 09, 2009, 07:58:14 pm »
if you would have bought the next model up for 301,000 it came stock with wiring. lol
 anything pulled behind "farm equipment" is exempt
my favorite color is   clear
Offline zopi
« Reply #4 on: November 09, 2009, 08:29:17 pm »
Nowhere have I ever seen da fuzz messing with a farmer operating equipment in reasonable fashion...saw a guy once with a big tandem disk which blew a cylinder seal on a state road..he got some attention from the THP...
Got Wood?
And lots of junk.
Offline Don_Papenburg
  • I need
« Reply #5 on: November 09, 2009, 10:16:22 pm »
In Illinois ,Implements of husbandry(farm implements) are exemt from many of the rules and regs except axle weights .  However if you are towing with anything besides a tractor /combine  you can be subject to regular rules of the road.
 If you are hauling farm to farm you can bypass some laws . However taking products to market puts you under I DOT regs.
 A trailer for a combine head towed by a tractor at tractor speeds would be safe enough without brakes .  I pull two headers and carts with an 85hp utility tractor and can stop fast enough that I can slide the headers if they are not fastened .  My cart has lights red tail and amber warning lamps it also has DOT reflective tape  on the back and sides.  If I was the teacher I would make him install the reflective tape and warning lamps as a minimum to get a passing grade.   Even if these things are not required it makes sence to install them for safety.
 Surge brakes would not require any hookups to the tow vehicle .   Combines were not designed as tow vehicles hence no provisions for lights or brakes .
Offline ksu_chainsaw
  • KSU Wildcats
« Reply #6 on: November 10, 2009, 08:54:24 am »
Even though a header trailer doesnt need anything more than a SMV sign when pulled behind a combine or tractor, most of the header trailers in this area are usually pulled behind a pickup.  I would say he needs a pair of lights on the back, with reflective tape down both sides of the trailer.  The other night I was going down the highway and barely saw a set of brakelights- a header trailer behind a pickup- the only reason I saw his lights at night was because he had the brake lights at the top of the headache rack- and no flashers going 35 MPH on a 65 MPH highway.
Thats my opinion on the subject.
Charles
Offline woodsteach
« Reply #7 on: November 10, 2009, 10:10:06 am »
Thanks for the replies.
Charles, yep this one will be pulled w/a pickup 99% of the time I'm sure.
The student said that the header weighed 16k, if that is correct (sometimes the story gets bigger), and it is pulled behind a pickup how can it not have breaks and lights.  Does anyone know how much a 35' header weighs?
woodsteach
Offline nas
  • Measure twice and cut aw DanG
« Reply #8 on: November 10, 2009, 09:29:26 pm »
Better to sit in silence and have everyone think me a fool, than to open my mouth and remove all doubt - Napoleon.
Indecision is the key to flexibility.
2002 WM LT40HDG25
stihl 066
Husky 365
1 wife
6 Kids
Offline Ed
« Reply #9 on: November 11, 2009, 06:58:30 am »
I was behind a combine last night, he was pulling the grain header himself.
The trailer was a purchased one, there were no lights and no SMV sign. The back had 2 red refelectors (tape) that was it.
Ed
Offline dewwood
  • Makin sawdust
    • Powers Hardwoods
« Reply #10 on: November 11, 2009, 08:07:06 am »
I think a lot of those conveyances pulling combine headers are wagons which are not treated the same as trailers for DOT purposes.
Selling hardwood lumber, doing some sawing and drying, growing the next generation of trees and enjoying the kids and grandkids.
  • I need
« Reply #11 on: November 11, 2009, 09:47:20 pm »
That is true .  BUT you should still have brains enough to put lights ,reflectors and smv  if you plan to pull it down a road that others use.  especially at night.
Offline timberfaller390
« Reply #12 on: November 12, 2009, 07:34:43 am »
We had one of the local idiots with a badge stop Bob Johnston who has done alot of the steam work for MGM and the smithsoneion, for driving a steam traction engine down a public road. Bob told the cop that he had street bands on the steel wheels and an SMV tag and there was nothing he could do about it. He also said unless the cop could show him the law where it said that he couldn't drive an agricultural vehicle down the road for agricultural purposes then he would stoke his fire and be on his way. The cop just had to stand there and watch  :D  ;D
Appalachian Hardwoods Lumber and Logging Co.
Peavine Valley Farms
Three Notch Forge Farrier Service
Stihl MS390
John Deere 5103
58 IHC A-162 log truck
  • KSU Wildcats
« Reply #13 on: November 12, 2009, 09:58:29 am »
The only way a header trailer would be 16K would be if they stacked 2 corn heads on there on end- similar to custom cutter trailers- but those are required to have brakes- since they are not strictly "farm trailers."
Around this area that trailer wont have a total weight over 10,000lbs, just check what type of spindles he puts on there to see how fast he can pull it- if he uses the ag type spindles, the max speed of the trailer is 45MPH, but they have a greater weight load- this is what I usually see on header trailers.
Charles
Offline woodsteach
« Reply #14 on: November 13, 2009, 10:40:31 am »
Thanks guys,
I'm not against the "small farmer" trying to make a  living, and his job does require driving down the roads.  But the larger farmers:  2 tractor/trailer rigs,2 combines, tractor/grain carts etc and then not want to put lights on the trailer is just STUPID  >:(.
But like was said: put on the lights, reflectors, smv something to protect others.
sorry for the rant
woodsteach
Offline IMERC
  • I have fishin'itis.... Really bad...
« Reply #15 on: November 13, 2009, 11:17:11 am »
so what's a "header trailer"???
Who ever invented work didn't know how to fish.... Here fishy fishy....
Offline beenthere
  • EIEIO
« Reply #16 on: November 13, 2009, 11:19:11 am »
A trailer to put the large corn or grain heads from the combines.
http://www.fastline.com/v100/listings.aspx?category=Header%20Trailer
They are so wide, they don't fit down the road very well, unless on a trailer. Even then, the combines are pretty big for the roads.  :)
Offline IMERC
« Reply #17 on: November 13, 2009, 11:23:30 am »
looked at the link...
not sure what I'm looking at...
Offline Brian_Rhoad
« Reply #18 on: November 13, 2009, 12:57:07 pm »
Here in PA it is illegal to use a SMV triangle on a vehicle traveling more than 25 mph. Most of the larger tractors can travel more than 25 mph. But they also travel less than that, especially when going up a hill with a load. I've also been told it may be illegle to use a SMV triangle and 4 way flashers at the same time. When you start adding lights you have other DOT regulations to follow. Such as the towing vehicle must be licensed and inspected and have brakes just like any other highway vehicle on all 4 wheels. Wagons are no longer wagons but are trailers that must be licensed and inspected and have brakes on all 4 wheels. The state has no licensing or inspection proceedure for farm equipment. Can you imagine farmers having to get their tractors and wagons licensed and inspected? What a mess that would be! I know of an area west of me where the local police tried to make the farmers do that. I never heard what the outcome was.
Offline beenthere
  • EIEIO
« Reply #19 on: November 13, 2009, 02:38:37 pm »
There are several trailers for hauling the heads shown.
Maybe this link is better.
http://www.trailers4u.com/Header_Trailer.htm
Saw Anywhere!
