If the logger doesn't know where the boundary is that is negligence in most cases. This is why you should always keep your boundaries marked...
Negligence, "The doing of something which a reasonably prudent person would not do, or the failure to do something which a reasonably prudent person would do under like circumstances"A reasonable prudent would not start cutting trees without first knowing who owns them and obtaining permission to cut them. I've been in the court room when the logger was found guilty of timber trespass because he didn't first find the property line.
mrnero, maybe i'm wrong but, wasn't your beef about stream crossings? now your focus switched to timber theft. this forum should not be your stage for being against logging!
mrnero is very misinformed and is attempting to interpret the law..... If you are neglegent you have neglected to do something.. Ie failed to check boundry lines.failed to file for a permit.... If you tresspass, you are a tresspaser Ie enter upon land of another with out right or permission, If you do not own the land or do not have permission to be there you are a tresspasser, if the property is posted *( with the best intent of the property owner or lessee )* or your are told to leave you and refuse to buy an owner or person with agent athority you are there and then arrestable * ( I have the handcuffs and will use them )* Theft is theft and any theft from realestate is a felony, timber is a part of the property and the assessed value is reasonable value. Larceny over $500.00 is a felony.. Ie. a 1 acre parcel ag land is valued at $12500.00 in Ma. and a 1 acre residential lot is valued at $100,000.00 Here so you have met the felony threshold.... The laws are there they are written and do have standing the problem is preception and interpretation........ The courts and judges have to stad on the written law as do we the public.... Auit whinning that laws don't exist, if you are be represented by a lawyer get a new one your are getting bad advise if not hire one because you don't under stand the law at all...... As I said before you need to stick around and learn a few things here before spouting off.... Many people have been arrested and or fined and even sentenced to jail for timber tresspass and timber theft in the recent past and will be in the future... As for conservation practices and wetlands crossing and or access you also need to read further to under stand the laws, there are exmptions and permitting practices inplace. We this industry should be doing a better job at policing each uther and cleaning up our messes and yes bad loggers are more our problem than anyone elses.... Also if a case fales relative to a judgement you disagree with THEN use the system and appeal, make case law that will make the law affirmed !!! More to come if need be !!!
Lets get back to the orginal topic : new wet lands stream crossing. Thanks
Quote from: mrnero on November 17, 2009, 06:42:13 pmLets get back to the orginal topic : new wet lands stream crossing. ThanksOk so from what I read there are adequate wetlands laws in place. If they are not being followed then they need to be enforced. More laws will do nothing without enforcement. So just enforce the current laws.
RSA 482-A is commonly referred to as the dredge and fill law, since these are the regulated activities. Fill is defined as material that has been deposited or caused to be deposited by human activity. Some examples of fill:1.Material, such as gravel, placed in a wetland or stream for a skid trail or truck road.2.Tree limbs (corduroy) placed in wetlands or drainage swale for a skid trail.3.Logs or rock (pole/stone ford) placed in stream bed for skid trail.4.Logs or rock placed in stream bank for a bridge abutment.5.Stockpiling of tree butts, slash, and debris in a wetland, bank, or waterbody.Dredge is defined as the excavation or otherwise disturbance of the soil in a wetland, bank or surface waterbody. Some examples of dredge would be:1.Excavating a bank to install a bridge abutment.2.Digging in a stream or wetland to install a culvert.3.Machinery ruts in a wetland, bank or waterbodyIf your proposed forestry project involves any of the above activities by crossing surface waters or non-frozen wetlands, then you are required to file Notification of Forest Management or Timber Harvest Activities Having Minimum Wetlands Impact.
Amen Chevy Tahoe. Mrnero I hope I have not offended you that wasn't my intention.As for wetlands issuses I have to get to a Conseravtion Commission meeting for 7:30 so I will have to check the forum when I return... I am the Vice chair of the commission, 8 years and counting.
Quote from: NH LawRSA 482-A is commonly referred to as the dredge and fill law, since these are the regulated activities. Fill is defined as material that has been deposited or caused to be deposited by human activity. Some examples of fill:1.Material, such as gravel, placed in a wetland or stream for a skid trail or truck road.2.Tree limbs (corduroy) placed in wetlands or drainage swale for a skid trail.3.Logs or rock (pole/stone ford) placed in stream bed for skid trail.4.Logs or rock placed in stream bank for a bridge abutment.5.Stockpiling of tree butts, slash, and debris in a wetland, bank, or waterbody.Dredge is defined as the excavation or otherwise disturbance of the soil in a wetland, bank or surface waterbody. Some examples of dredge would be:1.Excavating a bank to install a bridge abutment.2.Digging in a stream or wetland to install a culvert.3.Machinery ruts in a wetland, bank or waterbodyIf your proposed forestry project involves any of the above activities by crossing surface waters or non-frozen wetlands, then you are required to file Notification of Forest Management or Timber Harvest Activities Having Minimum Wetlands Impact.May be exempt from the $5k permit, but still have to file notification. So if whom ever you file the notification with was doing their job everything would be kosher.
True, how about the times when they are not doing there job ? It wouldn't be kosher then, would it ??
Quote from: mrnero on November 17, 2009, 07:43:48 pmTrue, how about the times when they are not doing there job ? It wouldn't be kosher then, would it ??So passing a new law will make that agency do their jobs? NO. Laws only work if there is an enforcing agency. Sounds like that agency just needs a kick in the pants.
Mr Chevytahoe, I was just wondering why a person in MI is so concerned what us land or property owners wants in NH. I just think that I'm missing something. Anyway, thanks for your previous thoughts /debate on this NH new forestry regulation that we hope will become law. Thanks
Quote from: mrnero on November 17, 2009, 08:11:59 pmMr Chevytahoe, I was just wondering why a person in MI is so concerned what us land or property owners wants in NH. I just think that I'm missing something. Anyway, thanks for your previous thoughts /debate on this NH new forestry regulation that we hope will become law. ThanksBecause once obnoxious over regulation takes hold in one area they tend to spread like a disease. Who is this "we" because most in the industry, people who do the right thing and people that rely on forest products industry (remember it trickles from the loggers to the grocery stores) I'm sure are against these useless permit fees. Until you can enforce the current laws, there is no since making new. Haven't seen one reason why a new law would help.
