Get your Forestry Forum Hats while they last!
I love concrete decking. You can safely span large distances, that is the only reason to use it as it is pricey. The design should take advantage of the 4-6' span the stuff can w/stand, and needs no decking underneath. I found when reusing some outdoor pallet racking that had it spanning the 42" spacing and then overhanging several feet on each side. We can and do get 30" heavy wet snows every 10 years or so, and it can take this kind of loading. Should last a lifetime. I will be making a shelter for my mill soon and plan on using it w/ steel bar joists. Ironwood
Concrete decking... Huh? what's that?
