Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Low Hp blade choice for seasoned hardwood  (Read 817 times)
Offline gates
« on: November 04, 2009, 02:29:07 pm »
I have a LT15, 10 hp diesel. I am cutting some ice storm trees that are hard and seasoned. Red/Black Oak, Maple, White Oak. The bands I have been using cut good in pine, cedar, popular, and green wood. Is there a better choice for bands? My blades seem to be leaving alot of dust on the cant and dulling fast in these logs. I see Woodmiser recomends a 4 degree and a 9 degree for knotty, hard, or seasoned wood. What do you other small mill guys use? I need to order some extra bands anyway. What do you all sugest?
Thanks,
James
Offline Ohio_Bill
  • Wood is Good
Re: Low Hp blade choice for seasoned hardwood
« Reply #1 on: November 04, 2009, 03:44:25 pm »
James : I have had very good luck with the 4 on my LT40 25hp  I am not sure how they would wook with the lower HP  . There is a lot of talk about the new 7 but I think they require a little more power . I would give Woodmizer a call before I ordered some .  Hope this helps .
Bill
Offline Mo
  • Sponsor
  • Wood-Mizer Blade Sales
« Reply #2 on: November 05, 2009, 10:17:40 am »
James, feel free to give me a call. I'd be happy to help you out.
You can reach me at 1-800-522-5760 ext. 1610
Gary
Offline NMFP
« Reply #3 on: November 05, 2009, 12:07:07 pm »
A friend of mine has an LT 15 gas mill and he is running 7 deg bands on his and is cutting hickory, white oak and rock oak.  I typically only run 4 deg or 7 deg and havent found anything yet that these 2 bands will not cut well.
Do you sharpen your own bands?  If so, you can modify a 10 deg down to a 7 and see if that does the job for you.
Best of luck and let us know how you make out with your sawing
Offline ladylake
« Reply #4 on: November 05, 2009, 07:10:11 pm »
  Over here I buy 10* blades, run them on easy to saw wood the first time then sharpen to 4* with the same gullet dept. Sharpened at 4* they cut anything good.  Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Online tyb525
  • Always learning.
« Reply #5 on: November 05, 2009, 09:35:36 pm »
I run 7 degrees with good results. They seem to be a happy medium for anything from poplar to hard maple to hickory to locust.
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline gates
« Reply #6 on: November 06, 2009, 09:54:02 am »
Thanks for the replys. I am going to try the new 7* bands from WM. I will let you all know how they work. I have my bands sharpend at WM Re-Sharp. The next box I send in I will try to have some ground to the 4* and try that also.
Thanks again,
James
Saw Anywhere!
