Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Finished My Log Arch  (Read 2341 times)
Offline dmartin
Re: Finished My Log Arch
« Reply #20 on: November 21, 2009, 08:07:12 pm »
John Mc, I had been planning to fill the rear tires with antifreeze for awhile and I finally got around to this morning. It helped with the traction alot. With the winch mounted on the back traction is not an issue and most of the time when I will be using the log arch the winch will be on the tractor. After loading the tires I welded some short pieces of chain (anchor points) toward the front of the boom which also helped. I'm now satisfied with the arch and after painting the new welds I'll call it done.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #21 on: November 21, 2009, 09:32:37 pm »
I like that tractor.  I see that they painted it the same color as your arch........ :D
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
Before you die.....Take time to live.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline BARPINCHER
« Reply #22 on: November 22, 2009, 06:06:01 pm »
A cheap trick I use as needed is fill that loader bucket up with anything you can scoop.  Cuts down on having to use steering brakes as much plus the front end pulls.  Them R-4  tires are horrible in the woods.  I have them and made a set of chains up to help.
Serving hunters and the hunted with science based; non-traditional resouce management methods
Offline Lud
  • Impetuous.... Homeric....
« Reply #23 on: November 22, 2009, 06:39:28 pm »
Y'know that's why  they have right/ left rear brakes............o you can steer when your front tires are in the air!
Good looking job.  Be careful you don't waste an hour in the woods trying to turn around with a too long log on the arch........like I did tonite. 8)
Saw Anywhere!
