Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Anyone producing power via waterwheel?  (Read 1300 times)
Offline sbishop
« on: November 03, 2009, 04:33:00 pm »
Just thought i'd ask if anyone has a water wheel producing power? i'm thinking of building a floating waterwheel to produce power at my camp? The river is less then 50ft away and with a good strong current.
Sbishop
Offline SPIKER
Re: Anyone producing power via waterwheel?
« Reply #1 on: November 03, 2009, 05:22:36 pm »
you might want to do a search on "Hydro-Power" to see several posts about this lots of concerns regarding EPA/DNR issues as well as other things to consider...
also look at TBN http://www.tractorbynet.com/forums/rural-living/ as they have had similar posts/questions. in last few years
I'm looking for help all the shrinks have given up on me :o
Offline James P.
« Reply #2 on: November 03, 2009, 06:06:09 pm »
not to may streams around me, tax ditches with a little flow but I am sure any diversion of water might be illegal for me. so I am producing water from power. ( electric water pump ) good luck i think if you have the resource its a great idea.
Offline sbishop
« Reply #3 on: November 03, 2009, 06:44:25 pm »
My idea is to build a floating water wheel, not too big...that way i'm not interfering with the river. but there is a few people come down in canoe's in the summer, so i will have to move it out of the way when i'm not there.
I guess i'm thinking that others have floating docks, why can't i have a floating water wheel dock?  ;)
Sbishop
Online WH_Conley
    • Stone Hill Hardwoods
« Reply #4 on: November 03, 2009, 08:14:19 pm »
Camouflage the wheel under the dock. :D
Bill
Offline James P.
« Reply #5 on: November 03, 2009, 08:56:38 pm »
I have always liked water wheel power. I lived in Wilmington De when I was young and use to ride down to the brandywine river. There were several mills there at one time or another. I know that alot of those types of mills were washed away as well. I think a floating wheel sounds like a good tactic . It would be interesting to know what kind of KW you could get out of it or do you plan on just producing HP for some other type of equipment.
Online Jeff
  • Lead Administrator
    • THEE Forestry Forum
The farther backward you can look, the farther forward you are likely to see. Winston Churchill.
Because inquiring minds want to know... ;D Expired Circle Sawyer-Automatic Commercial Mill-Since 1979
Offline SwampDonkey
  • Forester
  • Large Tooth
« Reply #7 on: November 04, 2009, 03:54:23 am »
Ah, Jeff found the thread I was trying to find.  :)
Pre-commercial thinning pays off. :)
'If she wants to play lumberjack, she's going to have to learn to handle her end of the log.'
Dirty Harry
Offline bandmiller2
« Reply #8 on: November 14, 2009, 07:09:12 am »
Put it in the river with a sign  Bishop University green project with a  EPA number on it.Frank C.
Offline moonhill
« Reply #9 on: November 17, 2009, 05:23:38 pm »
I like the floating raft idea, gang them up or down the river or in a tide rip in which case it could be fixed so as to turn with the tide but still be anchored.
Tim
This is a test, please stand by...
Offline John Mc
« Reply #10 on: November 18, 2009, 12:52:24 pm »
I'd imagine one of the problems with generating electrical power with a water wheel (as opposed to a turbine) is that the RPM of the wheel is so slow. You'd need to gear it up a bit - which would cause some efficency losses from the gear box.  An undershot wheel as the OP seems to be considering will turn rather slowly. An overshot wheel as shown in Jeff's post would help. Gravity accelerates the water as it falls, turning the wheel faster. On the other hand, if I had the kind of drop for an overshot wheel, I'd probably be looking for a small scale hydro turbine instead.
Small time fire-wooder in a neighborhood cooperative.
Offline ErikC
    • Erik Cordtz Enterprises
« Reply #11 on: November 19, 2009, 11:39:26 am »
  Use of a low rpm permanent magnet generator like what is used on modern windturbines aids that problem greatly. They are only a couple hundred dollars, I know one guy using it in this application and have read several other accounts of it.
Peterson 8" with 33' tracks, JCB 1550 4x4 loader backhoe, several stihl chainsaws
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #12 on: November 19, 2009, 11:47:30 am »
 Gearing up causes loss of efficiency, is really a lame excuse, these days.
  Just build things a little OVER sized, and get on with the program.  ::) ::)
Offline John Mc
« Reply #13 on: November 19, 2009, 11:54:41 am »
Sounds interesting. If you run across any good links, please pass them along.
Offline JSNH
  • Lane circular mill
« Reply #14 on: November 19, 2009, 12:28:17 pm »
These are the people who wrote the book on low rpm generators.
http://www.fieldlines.com/
Saw Anywhere!
