Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Drilling a Chainsaw Bar  (Read 2592 times)
Offline Coon
« on: November 02, 2009, 01:38:25 am »
I got a couple of questions for some of the guru's here.
I am in the process of building a chainsaw mill and will possibly need to drill a hole in the bar.  What precautions do I need to make in doing this?  Is the material that the bar made of really hard?  Will heat be an issue while drilling? I can keep it cool with cutting oil or something if need be.
 I need this mill within the next couple of days to remove a couple of yard trees for a friend.  The yard is completely fenced in and he does not want to remove any fence sections to get the logs out so..... next best thing-- chainsaw mill.  He is not worried about the sawdust on the lawn.  I need some 12 foot long 3x6's and various other dimensioned lumber so..... here's my chance...  ;D
Brad.
Offline VT-Woodchuck
Re: Drilling a Chainsaw Bar
« Reply #1 on: November 02, 2009, 05:56:54 am »
Use oil and a sharp bit and you should be okay. I've done several with good results.
Offline bandmiller2
« Reply #2 on: November 02, 2009, 06:13:37 am »
Turn the drill as slowly as you can.Best setup would be a drill press or milling machine set at very low speed,cutting oil good pressure on the bit.High speed drill motors tend to harden the steel under the bit it just glazes over.Frank C.
Offline Toolman
  • "DONT TREAD ON ME"
« Reply #3 on: November 02, 2009, 06:20:53 am »
I would recommend a cobalt bit. Start with a smaller hole then work your way up to the desired diameter. This will greatly reduce the amount of heat. Low RPM and cutting oil also.
"A government big enough to give you everything you want, is strong enough to take everything you have" (Thomas Jefferson)
Offline coastlogger
« Reply #4 on: November 02, 2009, 10:52:12 am »
I read in a book years ago that the secret is to lie bar on top of another old bar while drilling, that way the heat dissipates to the other bar which is somehow better, otherwise it may harden just as you are breaking thru, due to high heat and air cooling(or something). This method does work, not sure if its really necessary or not.
clgr
Offline Coon
« Reply #5 on: November 02, 2009, 10:56:40 am »
Thanks for the replies guys.  I am still not sure if I will need to drill the bar but may figure it out olater in the day.  As for now I have to go move thounsands of bushels of grain around to keep it from heating.  :o
Brad.
Offline ely
« Reply #6 on: November 02, 2009, 12:11:04 pm »
i can remember two things in my past that were very toough to drill a hole in. one was a chainsaw bar, the other was the piece of flat metal that keeps the door from swinging too far open on a 1961 gmc pickup truck.
finally got them both done but not without a lesson or two from dad on which tools were ok for me to use and which were not. :-[
Online Gary_C
  • Sunrise on the Prairie
« Reply #7 on: November 02, 2009, 02:13:37 pm »
There is a lot of difference between manufacturers as to the hardness of chain saw bars. For example on harvester bars, the GB bars are much stiffer and harder to bend than the Oregon bars. However you can straighten an Oregon bar easily, but you can't say the same about a GB bar.
So the same can be true about drilling. Some may be easier to drill than others. You just have to try and see what bit will cut them.
Offline olyman
« Reply #8 on: November 02, 2009, 02:19:14 pm »
know the cement bits that look like a reg drill bit??? have the carbide pieces brazed to the tip of the bit??? they will drill that bar. not sure how small they come. also, when you drill, use water.oil is a ??? LUBE,hence,the bit will "float" a bit on top of said oil. water will keep it cool,and the bit will be right against the steel. done it,works.sounds strange,but aint.
Offline nomad
  • Member
« Reply #9 on: November 02, 2009, 06:59:10 pm »
     In a pinch, water will work better than nothing.  If you have to use water, use enough to keep it flooded.  A better bet would be to use a metal cutting lube. "Tap Magic," or something like it.  With that, you don't need a lot; just enough to keep the surface wet.
     Olyman is right; don't use a regular lube oil.  You'd be better off cutting dry.
Online Magicman
  • Knothole Sawmill, LLC
« Reply #10 on: November 02, 2009, 07:11:58 pm »
Diesel/kerosene works well.
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
Before you die.....Take time to live.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline Coon
« Reply #11 on: November 02, 2009, 09:02:00 pm »
I never had a chance to get the hole drilled today due to grain heating in the bin.....  had to rotate it to cool it down.
I have a small bottle of cutting oil that I will use if I don't try the water thing.   ;)   I even have an old bar I can try on first too.  Same brand and everything.
Brad.
Offline sawdust
    • Dream Dovetail Co.
« Reply #12 on: November 03, 2009, 09:17:38 am »
Coon, I have drilled lots of holes in bars for my jigs. I use a cobalt bit and salt water. 1/4 inch first and only hole. How big do you need? I only use salt water because that is what saline bags have in them.
David
comforting the afflicted and afflicting the comfortable.
Offline TwinCut
« Reply #13 on: November 03, 2009, 09:24:41 am »
With 23 years of machining experience I know what you are up against. Here is a simple trick. Resharpen a regular drill bit with a "Flatter angle". A brand new bit will have a 118 deg included angle. Regrind the drill to about a 90 deg or slightly less angle, and spin it at about half of what you normally would, and you will be amazed at what you can drill. There is an art to sharping a drill, but with practice it will work like a charm.
Offline jdunmyer
    • OldEngine.Org
« Reply #14 on: November 03, 2009, 03:20:44 pm »
I once drilled a bar with a carbide burr, as I didn't have a carbide drill. A regular bit just skidded on the bar surface. The concrete drill bit that's carbide tipped will also work.
Offline Coon
« Reply #15 on: November 03, 2009, 08:04:40 pm »
I am not to sure yet as to the size of hole that I am going to need.  Plan is to put an auxillary oiler on the mill.  As many of you know... I like to build things like this for myself and to suit my own needs.
Brad.
« Reply #16 on: November 03, 2009, 08:07:11 pm »
I wonder if you could punch one through there with a 30/06?  ;D
Offline TJB
    • TJ'S Wood Shop
« Reply #17 on: November 03, 2009, 08:12:29 pm »
I took my bar to a local machine shop and gave him 5 bucks to drill a couple of holes through it
Offline sawdust
« Reply #18 on: November 03, 2009, 08:17:46 pm »
Coon, if you are approached by Direct energy to consolodate your gas and electric bills. Chase them off. The thieving buggers hve small print that will cost you dearly. pm me if you want details. Anyway to get this to the rest of the Canuckistanis on here?
david
Online Gary_C
« Reply #19 on: November 03, 2009, 08:39:23 pm »
Drilling that bar may not be as difficult as you think.
It will be best if you use a drill press, start with a pilot hole, and then drill to the size you need. Make sure you have a sharp bit, run at the lowest speed you can, and use cutting fluid. The cutting fluid, what ever kind you use, is mainly to prevent the piece from getting hot.
For this job, heat is your enemy. Once you get that piece hot, it gets very hard to machine.
If you don't have access to a drill press, you must keep that bit perpendicular to the bar you are drilling. If you move just slightly off perpendicular, that bit will grab and most likely break the outside corners off the cutting edge and then you are in trouble. At that point, it is best to get another sharp bit as you will have a long way to grind to remove those outside broken edges.
So just go ahead and have at it.  8)
Saw Anywhere!
