In Memoriam
Gallery
Find-A-Database
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Search
Calendar
Extras
Tool Box
Forestry Forum Dictionary
Knowledge Base
Forestry Forum Support Auctions
Login
Register
The Forestry Forum
Forum
General Forestry
Sawmills and Milling
(Moderators:
Ron Wenrich
Portable Chainsaw Mill
« previous
next »
Print
Pages: [
1
2
All
Go Down
Author
Topic: Portable Chainsaw Mill (Read 2170 times)
TJB
Full Member
Gender:
on:
October 27, 2009, 08:36:09 pm »
I have read all sorts of bad things about chainsaw mills, but I built one and it works fine for me. I was using a Norwood bandmill a few years back and I can tell you that using the chainsaw mill I have isn't any harder than that was. You can see my mill being built from start to finish on my website if you are interested.
http://www.tjswoodshop.com/homebuilt_portable_sawmill
Logged
TJ Brown
www.tjswoodshop.com
ErikC
Senior Member x2
Gender:
Re: Portable Chainsaw Mill
Reply #1 on:
October 27, 2009, 09:38:09 pm »
I see this is your first post. So if you haven't heard it yet...Welcome to the FF.
Logged
MotorSeven
Senior Member
Gender:
Reply #2 on:
October 27, 2009, 09:51:29 pm »
Your a very talented fabricator. I went from a Woodbug CSM(Stihl 066) to a Band. The Woodmizer is "better" if speed is a factor. My CSM made perfect lumber every time. But, cutting dimensional lumber out of a 16' ash or oak was very time consuming. I am building a house using my own logs cut & skidded off my property. The CSM would have pushed me back another year....an I'm not the patient type, so a Band is for me. Besides, I ain't getting any younger
RD
Logged
WoodMizer LT15 27' bed
TJB
Full Member
Gender:
Reply #3 on:
October 27, 2009, 09:52:50 pm »
Howdy, thanks for the welcome! I have been lurking here for awhile and just thought I would show my homebuilt
Logged
TJ Brown
www.tjswoodshop.com
In Memoriam
Gender:
Reply #4 on:
October 27, 2009, 10:00:15 pm »
Well welcome to the forum. We have some chainsaw experience here too, and I'll think that most of the members will agree with your philosophy about buying the mill that you can use.
Logged
fishpharmer
Senior Member x2
Gender:
Reply #5 on:
October 27, 2009, 10:08:35 pm »
Welcome to FF!
Nice mill and website.
Logged
I built my own band mill with the help of Forestry Forum.
Carpenter
Senior Member
Gender:
Reply #6 on:
October 27, 2009, 10:18:24 pm »
Good job on the mill. I seriously considered building a chainsaw mill, But, I ran across an old circle mill at a reasonable price. A chainsaw mill does have it's place. I enjoyed your building progression pictures.
Logged
TJB
Full Member
Gender:
Reply #7 on:
November 03, 2009, 08:15:33 pm »
Thanks for the positive feedback
Logged
TJ Brown
www.tjswoodshop.com
simplicityguy92
Full Member
Gender:
Reply #8 on:
November 03, 2009, 09:27:04 pm »
nice mill. looks similar to the one im buildin at school. i put the angle iron the same way so its stronger to
Logged
James P.
Senior Member
Gender:
Reply #9 on:
November 03, 2009, 09:32:32 pm »
TJB, really nice job. pics were worth waiting for with my slow dialup. Just had a guy give me a boat trailer just like that today. well it is completely rusted away but neat coincidence.
Logged
rickywashere
Full Member x2
Gender:
Reply #10 on:
November 03, 2009, 10:53:00 pm »
how much clearance do you have on the fence it looks a bit high for the last cut ? btw great looking mill you will turn out some great boards with it
Logged
Meadows Miller
Senior Member x2
Gender:
The Walkabout Sawyer
Reply #11 on:
November 04, 2009, 03:34:40 am »
Gday
And Welcome to the forum TJB
I LIKE IT !! nice web page Mate
8)I Started on csms for about 2-3 years when i was about 13yo Looked like yours just alittle heavy'r 40" wide by 28' main frame with 2 8' ext at each end
and a 3120 44" bar the main frame was 6x2 1/4 tube with a peice of 3x2 1/4 tube welded to the underside to mont the axle to the ext where done in 4x2 1/4 tube use to mill alot of D/fir from 8' upto 40' long by the B double load 45ton and 10" to 36' dia i got no problem with csms as i still own one i just like doing things alittle easer these days
ps i liked the legs and the way you hve your squaring arms settup An allround Top Job Mate
Regards Chris
Logged
Meadows #2 delux manual circular sawmill & Edger, 1997 mod 8-20 & 2010 mod 10-30 Lucas Mills ,Homemade 44" circular table top sawmill , Chamberlain 80hp tractor loader and farmi winch. 9 ton payload 79 mod International Acco 24' traytruck , 350. 359. 372 Huskys and a couple of 2095 Jonys
TJB
Full Member
Gender:
Reply #12 on:
November 04, 2009, 06:46:17 am »
The fences will drop all the way through the piece of tubing holding them. I can see they look like they are bottomed out in the photo, but they are not. The big mistake I made and have to fix is the tracks. The cross members are 3 1/2 foot apart and I ended up will the carriage being so heavy that the track bends down when the carriage is between the cross members. I'm going to weld tubing under the tracks to support them. I should have done that to start with or built the bed a little more narrow and run the track down the side channel
Logged
TJ Brown
www.tjswoodshop.com
Slingshot
Senior Member
Gender:
Reply #13 on:
November 04, 2009, 07:39:23 pm »
Interesting fabrication post. I like seeing things like this going together. I took a welding course at a vocational school several years ago and have enjoyed being able to do my own welding and cutting. Bought my own
tanks instead of renting and saved bunches of dollars by doing so.
Charles
____________________________________________________
Tailgaters are helping to clean the environment----they suck up fumes!!!
Logged
gemniii
Full Member
Reply #14 on:
November 04, 2009, 07:59:07 pm »
Looks great!!
With a few more mods you could mount a bandsaw head on it.
Logged
Senior Member x2
Gender:
Knothole Sawmill, LLC
Reply #15 on:
November 04, 2009, 10:06:11 pm »
Welcome to FF, TJB. I enjoyed watching you build the CSM. Looks to be well thought out, and the results are obvious. Congratulations.....
Logged
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
Before you die.....Take time to live.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
islandlogger
Full Member x2
Gender:
Reply #16 on:
November 05, 2009, 09:36:49 am »
Welcome to the Forum and by god I myself think that is one piece of handy work you have done there mate, well done!! Very Cool!!
Logged
zopi
Senior Member x2
Gender:
Reply #17 on:
November 05, 2009, 10:03:29 am »
Nice!...looks like a Ripsaw would fit in there somewhere....
Logged
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
woodsrunner
Full Member
Reply #18 on:
November 05, 2009, 08:26:32 pm »
Great post and website. I am a chainsaw miller also. CSM's definitely have their place and with a little experience you can definitely cut high quality lumber. I use mine for cutting big slabs, not really for making dimensional lumber. But as you said this works and that's what counts!
Scott
Logged
TJB
Full Member
Gender:
Reply #19 on:
November 05, 2009, 10:12:56 pm »
Thanks for all the nice comments! One of the selling points of the woodwork I do is the fact I try to use wood that would have been wasted otherwise, another one is that I mill it myself. I was thinking that if I could add that I also mill it on a mill I built myself it would be even more appealing to my customers. I have had a lot of people ask why I didnt buy or build a bandsaw. The short answer to that, I didnt want a bandsaw.
I was a sawhand in the log woods for quite a few years and I guess running a chainsaw got in my blood. I love to hear a chainsaw run and smell the mix of the oil, gas and fresh sawn wood all combined at the same time. Plus every sawmill in my area is a bandsaw and I like having a mill thats a little more unique, I like doing things a little different from those around me.
TJB
Logged
TJ Brown
www.tjswoodshop.com
Print
Pages: [
1
2
All
Go Up
« previous
next »
The Forestry Forum
Forum
General Forestry
(Moderators:
Ron Wenrich
Saw Anywhere!
