Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: home-made hydraulics  (Read 17658 times)
Offline eastberkshirecustoms
Re: home-made hydraulics
« Reply #140 on: January 03, 2012, 08:25:13 pm »
Technical bulletin for pineywoods homemade hydraulics
Don't work very well when the temp gets down in the low 20's. 1 hp motor just not big enough to handle the cold tractor hydraulic fluid.  Temp fix until weather warms up a bit.
Wow, does it really get that cold down there? It is 4 degrees out right now, plus a nasty wind chill. It might take more than that little heater to get that fluid flowing. ;)
Offline paul case
« Reply #141 on: January 03, 2012, 09:32:12 pm »
Did you ever think about running dextron or atf in that? A lot of fellas run that in their bale bed hydraulics and the cold don't seem to bother it.PC
EZ Boardwalk and WM 94 LT40 hd
pc
Offline bandmiller2
« Reply #142 on: January 04, 2012, 07:04:45 am »
I would try synthetic Dexron fluid when its cold she flows. Frank C.
Offline pineywoods
« Reply #143 on: February 10, 2012, 10:33:23 am »
It appears that I forgot to include dimensions for the hydraulic toe roller. Here's some more pics and a little explanation
All the angle iron is 2X2. The 2 horizontal pieces are 8 inches log with a cutout for the roller. Vertical pieces are 12 inch and 18 inch. The 18 inch piece has a small 2X2 tab welded on the bottom to serve as a mount point for the bottom of the hydraulic cylinder. 12 inch long piece of pipe welded between the horizontal angles. The roller is a 12 inch long piece of 3 inch pipe (or whatever you have handy). Piece of scrap welded across each end with a 1 inch hole for the axle. Axle is a 15 inch long piece of 1 inch rod. The 2 pivot points are a short piece of the same rod, couple of 1/2 inch bolts would work just as well.  The hydraulic cylinder is 2 inch by 4 inch stroke.
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline jrkimroxie
« Reply #144 on: February 11, 2012, 09:31:14 pm »
Thanks for the info/specs. I hope to complete this phase of hyd. in the next week or so.  :P :P 8) 8)
Loving life 1 log at a time !!!!
Saw Anywhere!
