BID ON A FORUM AUCTION!
I find the debarker has limitations in its use. On some logs it will tend to climb on the opening cut when it would be most needed leaving me to cut straight thru all the grit and grime anyway.
Thanks everyone. I've gleaned a lot from the forum. Chuck - 4 times would sure pay for itself in a hurry. thanks for the info.Burlkraft I will be thru Greenbay on Tuesday and heading out with the mill that evening.Thanks againVictor
