Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: trailer bearing issues  (Read 1767 times)
Offline sbishop
« on: October 22, 2009, 09:29:07 pm »
Hi, for the last year or 2 i've been running into lots of problems with bearings on my utility trailer.
i'm blowing bearings now every 2-3 months. i had to replace both sides in July, taking it on the road this saturday and decide i should check them tonight. Well both were shot. i can't figure out why they ain't lasting. i'm greasing them in the spring and fall.
When i first got my axle, it was almost 5 years before i blew a bearing. But i did blow a beaing on each side around 2-3 years ago, could i have ruin the spindles?
Sbishop
Offline Don_Papenburg
  • I need
Re: trailer bearing issues
« Reply #1 on: October 22, 2009, 09:38:08 pm »
Check the spindle to the bearing ID .   do you use the best bearing grease you can?  pack the bearings  ? are your seals up to snuff?  Did you tighten properly ?  Not too tight or loose?  Are the hubs ingood shape?  Oh and have you by chance been overloading the trailer ;D ?
Offline sbishop
« Reply #2 on: October 22, 2009, 09:49:53 pm »
Yes to all above  smiley_whacko
i'm 100% it's the right bearing kits i'm using, the grease seems good, packing the bearings, always using new seals. i thighten the nut by hand then use a wrench and tighten a little more, spin the tire a few times, loosen the nut, tighten by hand. hubs are new less then a year.
Haven't been overloading the trailer in the last couple of years  ;)
  • I need
« Reply #3 on: October 22, 2009, 10:00:17 pm »
Guess I ain't no help then.
Offline WH_Conley
    • Stone Hill Hardwoods
« Reply #4 on: October 22, 2009, 10:26:21 pm »
I have been having the same problem. Bearings going out too soon. I just go in the local NAPA store and throw end labels from the boxes down and tell them to give me another set. Yes, I do overload.
I do think you can score the axle, or something, once you lose a bearing on an axle, it seems that is more prone to going out again.
Bill
Offline Gary_C
  • Sunrise on the Prairie
« Reply #5 on: October 23, 2009, 03:03:45 am »
I hope you are replacing both cup and cone.
When you "pack" the bearings, are you forcing grease inside the cage till it comes out the other side or just filling the wheel bearing cavity with grease?
Are you properly preloading the bearings?
After you replace the bearings, do you periodically check for hot or warm bearings under load? It could be too tight or loose. This should tell you when the preload is not right or a bearing is failing prematurely.
Offline Toolman
  • "DONT TREAD ON ME"
« Reply #6 on: October 23, 2009, 04:58:58 am »
That nut should only be hand tightened. Have you checked the bearing race? If the race is scored, it could cause excess heat. Other than that, unless you submerge your axle in water alot, those bearings ,properly packed in grease ,should last for years. I just replaced my bearings in my utility trailer this spring after 17 yrs. of use.
"A government big enough to give you everything you want, is strong enough to take everything you have" (Thomas Jefferson)
Offline Woodchuck53
« Reply #7 on: October 23, 2009, 05:10:06 am »
We repack every spring with a quality grease and replace with only Timken bearings. I would check both as well as mike the spindles. Have a safe one
Case 1030 w/ Ford FEL, NH 3930 w/Ford FEL, Ford 801 backhoe/loader, TMC 4000# forklift, Stihl 090G-60" bar, 039AV, and 038, Corley 52" circle saw, 15" AMT planer Corley edger, F-350 1 ton, Ford 8000, 20' deck for loader and hauling, F-800 40' bucket truck, C60 Chevy 6 yd. dump truck.
Offline fishpharmer
« Reply #8 on: October 23, 2009, 05:19:16 am »
Woodchuck beat me to it.  Quality of bearings can
make a difference in life.
I built my own band mill with the help of Forestry Forum.
Offline JayG
« Reply #9 on: October 23, 2009, 02:04:39 pm »
I am having more bearing issues in the last few years also. Using the same technique I've used since I started doing that stuff 50 (WOW) years ago. My parts guys indicate there are no more bearings made in the USA. If somebody knows different, I'd love to know. He asked if I wanted Chinese or Japanese? I keep an extra full set (for one axle)of packed bearings  for each trailer on the trailer in a small tool box. You notice they never go out in your driveway! :D
Offline Toolman
« Reply #10 on: October 23, 2009, 02:49:57 pm »
Add that to the list of "goodies" that are'nt manufactured in the USA anymore.
Offline Gary_C
« Reply #11 on: October 23, 2009, 03:26:53 pm »
I believe you are supposed to torque to a certain setting and then just back off to the first hole for the cotter key. What I do is tighten till I can feel it bind when turning and then back off just till it's free. I may do that a few times to see if the setting changes and then put the cotter key in the first hole when backing off.
You may have to reset the cotter key later on some bearings if it does not stay preloaded. That is why I always check for temperature after running. Even good bearings will sometimes be too tight or loosen up after break-in.
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #12 on: October 23, 2009, 05:56:11 pm »
 I have never heard of tightening a wheel bearing by hand.  I do the same as Gary_C Tighten it and back off  to the closess hole , I think your bearing issues are do to the instalation procedure you are using . I beleave you are running the bearing to loose and causing premature wear on them .
   Marcel
Offline Toolman
« Reply #13 on: October 23, 2009, 06:06:21 pm »
I was always told to hand-tighten which usually lines up to the hole for the cotter pin. That's how works on mine anyway. I do go just  slightly beyond hand tighten with the wrench, but not much.
Offline caver
    • Cavers travels
« Reply #14 on: October 23, 2009, 10:02:41 pm »
Tighten with wrench, do not turn the wheel while doing this. Back the nut off and tighten finger tight. Then, back it off until the first nut castellation lines up with the hole.
This is for a Dexter axle. 50K+ miles on camping trailers and never a failure.
Dexter instructions.
http://i.b5z.net/i/u/1080235/f/Instruction_Sheets/059-831-00A.pdf
Baker HD18
  • I need
« Reply #15 on: October 23, 2009, 10:57:11 pm »
Just bought 18 bearings from Motion industies  Made IN USA anmd at a better price than furen bearings .
Offline rebocardo
  • Atlanta GA
« Reply #16 on: October 23, 2009, 11:04:39 pm »
Are your axles bowed? Your 3500# axles should have a slight upward bow (or straight) unloaded and then once loaded should be straight. If you are very good with a tape measure, jack up the trailer, take the wheels off, and measure the axle flanges left to right on the top and then the axle flanges on the bottom. Helps if a second person holds the tape. Now load it and look at the difference and measure again.
If the top and bottom do not match or the top is less then the bottom, you have a problem.
Offline IMERC
  • I have fishin'itis.... Really bad...
« Reply #17 on: October 24, 2009, 01:29:33 am »
are you using offshore made bearings???
are you changing the races when you changing the bearings???
is water getting in to the housings???
and is the grease yur using high temp...
suspect bad race/alignment then mounting then incorrect grease/lube proceedure...
Who ever invented work didn't know how to fish.... Here fishy fishy....
Offline IMERC
« Reply #18 on: October 24, 2009, 01:30:19 am »
you could need a wheel/axel alignment...
Offline scsmith42
« Reply #19 on: October 24, 2009, 07:08:11 am »
Things that I would check are:
1 - are the bearings fully greased - ie grease coming out from between the cages and the races?  Hand greasing a bearing is becoming a lost art...
2 - Were the races replaced with the bearings, and are they fully seated in the hubs?
3 - Are you using a very high quality grease designed for use in axle bearings?
4 - The correct tightness of the axle nut should allow you to move the tire (from top to bottom) about 1/16" - 1/8", measured in the center of the tread on a 30" diameter tire(or similar size).  To measure, grasp the tire on the top and the bottom, and try to rock it back and forth - alternatively pulling the top towards you and then pushing it away.  If you have smaller diameter tires, reduce the amount of movement accordingly.  For a 20" diameter tire I would shoot for 1/32" - 1/16" movement.
Scott
Saw Anywhere!
