BID ON A FORUM AUCTION!
Can this filing guide be used on stihl chain?
That metal plate on that roller guide is what I use. Works well for me, if you don't have the safety chain. If for hardwoods, use the side marked as such. Fit the small slot in behind the raker, and use a good fine flat file to file off what protrudes above the plate. I find the roller guide the best way yet to hand file too. (Image hidden from quote, click to view.)
Here is a pic of the raker plate in position. Hope it helps. (Image hidden from quote, click to view.)
Well that's what I thought, but I could not figure out how to put it on right for the rollers to sit low enough to line up with the teeth! I don't know what's going on?
Quote from: Holshot14 on December 19, 2009, 09:55:11 pmWell that's what I thought, but I could not figure out how to put it on right for the rollers to sit low enough to line up with the teeth! I don't know what's going on?Here is a pic of the guide using the rollers to file the teeth. The guide slips over the links between the teeth, and then just the angle of the file is manual, as the depth of the file in the tooth is fixed by the rollers. Be sure you have the right diam. file for the chain, and you should be good to go. (Image hidden from quote, click to view.)I've found a flat file for the rakers works, but it needs to be like a sharp (not old and worn out which I found doesn't cut) Nicholson mill bastard. The file teeth are pretty fine, and just a couple passes takes the raker down.
