Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Stihl MS 440 bar oil  (Read 1921 times)
Offline AtLast
  • Dis-member-ed
« on: September 15, 2003, 08:20:48 pm »
I have a new MS 440 that runs great. I work in forestry and use chainsaws on a regular basis but I have not seen a saw " react" like this before. Typicall the gas will run out long befor the bar oil res. empties. I dont know of an adjustment nor have I seen a saw that " uesally" the fuel is gone befor the bar oil. Useally they are about the same level...question is...do I have a problem? ???
Offline woodmills1
  • the truth shall set you free
Re: Stihl MS 440 bar oil
« Reply #1 on: September 15, 2003, 08:36:23 pm »
My new 066 seems to be the same the oil is only half on a fuel fill.  It slings oil off the bar when I check so I am just sayin it is ok.
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline SasquatchMan
  • Get it done.
« Reply #2 on: September 15, 2003, 08:43:54 pm »
Stihl's webpage says those saws have an adjustable oiler, so maybe a check in the manual or a close look at the oiler will give you a more natural/balanced flow... you would think that they'd be set decently at the factory though, wouldn't you?
Senior Member?  That's funny.
Offline Kevin
    • The Milling Masters
« Reply #3 on: September 15, 2003, 08:47:14 pm »
I run lots of bar lube.
The more lube the less wear and tear on the bar and chain.
If you can see it spray off the end it should be ok.
Offline David_c
  • treat people the way you want to be treated.
« Reply #4 on: September 15, 2003, 08:55:48 pm »
in my husky manual it says that they desing it so that you run out of gas first.
Offline ElectricAl
  • 1993 LT40HDE15
« Reply #5 on: September 15, 2003, 09:27:33 pm »
AtLast and WoodMills,
Flip your new saw upside down. Near the front in the case you'll see a little hole kinda in line with the bar. Embossed in the metal is a flow amount arrow. With an 1/8" flat blade screw driver you can adjust you oil flow ;)
Our MS440 is about 3 weeks old now and I did turn up the flow a little.
Happy sawing
ElectricAl
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
Offline blue_eyed_devil
  • I put the riot in Patriot
« Reply #6 on: September 15, 2003, 10:51:39 pm »
I turned my oilers right down so that it runs almost two tanks of fuel to one tank of oil.I don't want alot of oil flying off the bar onto my house logs.
The logs are peeled,so there is less grit on the chain, however doing this is very hard on the bar.Thanks to Kevin for the tip on keeping the rails dressed. ;D
262 xp,395 xp,built my own chainsaw mill
Offline johncinquo
  • Oh Boy A place to cut up!
    • My Pictures
« Reply #7 on: September 16, 2003, 01:06:53 pm »
I run all my saws full bore on the oil, all the time.  I would rather go through more oil than end up buying bars, chains, sprockets, and eventually motors.
I have just starting switching over to something, and maybe in cutting house logs you might do the same.  I started using vegetable oil!  No kidding.   I thought it was a big joke over on another site, then specificly asked the guys who say they were doing it and they confirmed in fact that is what they were using.  One guy says he has been using it for some time with no ill effects.  I don't particularly care for bar oil all over me, the truck, and everything else all the time.  If it works OK for me I will report back either way.
While you are checking your 440 over, check to make sure the oil tube, holes in the bar, and anything else is not plugged or even slightly clogged.  I had a terrible time awile back with one and it was 1 piece of wood chip lodged inside a tube that wa slowing the flow down enough to make  anoticeable difference.  An oil pump on a saw is not a high pressure set up, and can not put out enough pressure to unclog anything of size usually.  Cheers, JB
To be one, Ask one
Masons and Shriners
« Reply #8 on: September 16, 2003, 10:08:16 pm »
I would be worried about attracting bugs and critters later on after the house is built.I use Husky clear all year round.
I do the majority of my cuttting with the nose,so I keep the sprockets greased several times a day.I hate buying those expensive little tubes.I was wondering if anybody uses wheel bearing grease instead?
Offline Oregon_Rob
  • NW Oregon
    • Not open yet, but soon I hope
« Reply #9 on: September 17, 2003, 06:34:18 am »
One of the things to think about is what kind of cutting you are doing. If you are cutting brush and limbing, by are not going to need as much oil as if you were bucking good sized logs all day long.
Chainsaw Nerd
Offline Captain
« Reply #10 on: September 18, 2003, 05:34:01 am »
The question of greasing the bar tip.....
I had a friend that greased his bar tip with regular chassis grease and it did not last long.  Wheel bearing grease may last longer as it has better temperature characteristics.  I have always used and recommended those darn little tubes.
My uncle ran a saw shop when I was a kid, and he used to recommend turning up your oiler on the "big bar" saws so your oil tank consumption was about 3/4 to a full tank of fuel.  He also DID NOT RECOMMEND lubricating the sprocket nose, but keeping your bar groove clean.  Once lubricated with grease, bar oil can no longer get to the bar tip.  I have always followed his practice and recommended it to customers.  I have never worn a tip out before bar body replacement was necessary.
Having said that, Uncle Larry did recommend lubricating bar tips on saws routinely used in dirty or abrasive conditions.  The grease keeps the dirt and grit OUT of the roller.  He had a habit of making "stump chains" out of old worn chains and used a bar with a greased tip for this activity.
Captain
Offline Larry
« Reply #11 on: September 19, 2003, 05:05:35 pm »
I had a conversation with a Husky Rep a while back and there recommendation is to grease the bar tip at every refill or not at all.  Forgot the reason why.
I turn up the bar oil all the way because of the way I cut.  Bar is buried most of the time and I do a lot of bore cutting.  Oil is cheap.  Chains and bars are expensive
Larry
Nine out of ten trees recommend wood for your building project.
Offline AtLast
  • Dis-member-ed
« Reply #12 on: September 23, 2003, 05:38:14 pm »
Thanks for the input fellers.....I thinkin I agunna be turnin up the oil....Im buckin logs all day I go with the ole " the more oil ..the fewer bars"...thank again
Saw Anywhere!
