Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Need Advice "Pronto," I got the fever bad after going to W.M. at Shade Gap, PA  (Read 2377 times)
Offline H60 Hawk Pilot
  • Location: Bonifay, FL (winter) Huntingdon, PA (Jun. to Aug).
I'd like your Advice regarding the correct saw, price evaluation and what ever you care to kick in... but be kind.
Today, I went to Wood - Mizer in Shade gap. PA (it's the only place I know of within reasonable drive distance).
Before I go through the line up & pricing, let me cover my intent.
I'd like to cut enough pine to do two cabins, my property has yellow pine and white pine tree's for sale on the adjoining property. The W P  are good size, about 30 to 38 inches I'd say. I have alot of hardwood that would make tie-cuts. 112 acres was clear cut in 1997. Some of the tree's were left standing. Some are crooked trees that were left behind. I also want to cut locust for a pole barn. The min. lenth will be 20 feet long.
Here's the estimate of tree's to be cut -- Yellow pine = 300, White pine = 150, Mixed Hardwood = 500, Locust = 100, Other = 100
Helper available (1) 14 YO Son (after school & weekends). I do not intend to get into custom sawing and need to build kilm to process some of the lumber and air dry as well. Interested in cutting D-type logs for cabin walls as well.
Todays , Saw Line Up & Prices at WM
(1) used LT 40 Manual, 18 HP Onan, Log Loader, Elec. Up & Dwn & Power Feed & Return, Jaw Type Log Roller, Mid 1980's as guess, set for the last 4 years (rusted) , saw is being gone over and 100% good to go after repair, as is, $ 12K.
The other is (LT70), Super Hdy., CAT Diesel, Remote Hydrostatics, 1360 hours, 2005 year model,  $ 27K, as is, looks good.
Also, all the WM Line Up at current sale prices.
What's the advice.
Offline gemniii
Have you researched the cost of just buying your lumber?
Right now it's almost selling at a loss in some areas.
Others on here have a lot more knowledge but from what I've read the cost of the mill is just the tip of the iceberg.
I'm wanting to get a small one, but for a hobby.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
I'd go with the LT70 of those two choices. Cutting that many trees, especially if you are dealing with a lot of stuff over 30", is a lot of good old fashioned hard work. I've put about a eighty-thousand feet across a manual W-M, and a lot of it big stuff. I think that the extra $15k will be well spent, as it will reduce your time spent to probably 1/3. You will still have plenty to do, even after the trees have been sawn. ;) Those prices look good, from what I have seen. Good luck. :)
Wood-Mizer LT40HDD51 Wireless, Kubota L48, Honda Rincon 650, TJ208 G-S, and a 60"LogRite!
Hydraulics didn't get too much attention on WoodMizer mills until about 1989  and I wouldn't attempt that number of logs without hydraulis and other log handling devices.
Personally, I would pass up the mid-80's mill, if you've accurately aged it.
The LT70 is a lot of mill.  It would be difficult to imagine your being unhappy with it, except for the initial outlay.
If my choice were Woodmizer, I would shop a used mill, but look for an LT40HD or more.
It's hard to go wrong with a WoodMizer mill, but you should also take a gander at some of the other bandmills too. WoodMizer is the only cantilever, but there are some good 4 posts mills out there.
Depending on what product you wish to end up with, you might also be smart to look at Peterson's or Lucas' swing mills.  The swing mills do a good job of cutting construction lumber and smaller boards, while minimizing the log handling.  The bandmills will cut it all, along with wide boards, but the log handling might be a little more complicated.
One thing for sure, you are setting yourself up to have some prime time with your boy. :)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Tom and Dave won't lead you wrong :)
Neither will Marty.
I would not want to tackle that much lumber without hydraulics.  An LT70 is a lot of mill, but if you can afford the outlay of cash for it, it will make you smile.
lots of dull bands and chains
Tom & All
I have been leaning towards a swing blade but have never seen one operate other then U-Tube and Liked what I saw.
Gary sent me a tape of his   Timberline 6610, VW power, not a lot of hours, will extend out to cut 20 ft. stuff, priced around $ 12K or a little less.. perhaps.
I have seen  Used Lucas  Mills  6/18 for $ 5,500 to $ 8,500 but nothing around PA that I saw listed anywhere. I thought the Lucas design was Ok but did not care for the support beam system.
The Mobile Dimension is my current choice but nothing in my back yard to see, buy or test operate .. that I know of ?
I can get into Brand X for $ 14,500 .. however.. still in the same boat, tough for me to buy a saw that I have not operated.
Regarding the purchase of the lumber and it's dirt cheap, that's the smartest thing that  I've heard all day.  However, I need to get the 14 year old out of the house.. away from computer and TV. I bought a 370 HP speed boat in March that got my kid out of the house but boating season is over now.
I need to get him out of the house for the fall season now, the sawmill should do it. Also, buying sawmill for better health reason >> excercise program, male bonding with my one & only kid, calling out trees that need to be cut. Also,lot's of other reasons that...  I ain't thought of yet (the fever is burning deep inside & hand shake).
Big Smiles, some BS above but mostly right on for buying mill..
Avery
Offline Dan_Shade
why not find a few folks within driving distance, and go out and work with them for a day.
I find mills to be like vehicles, a lot of folks are partial to what they own or use.  If you want a swingmill, find a local one, and see if he'll let you help for a day, I know woodmizer has owners set up that will demo mills if you are interested.
Where are you located?
I've worked around a swing mill, and I much prefer bandsaws.  but some folks have differing opinions (which is what makes the world go round)
Located in Huntingdon PA 16652, sort of southern PA, central part of PA. I'm 34 miles south of State College, 34 miles east of Altoona.
arbakerjr@aol.com
BAT Tel. with Magic Jack 412 250 7746 < great tel. no# to give out, no damage can result.
Avery
Offline DanG
Well shucks, Crashhawk!  If it's just a Mobile Dimension Saw you wanta see, you can just come play with mine.  I'm in easy driving distance...not more'n a couple of days...and the big Moultrie Ag show is coming up in less than three weeks. ;D
You can't really look at the cost of the mill if you buy a used one for one project.  You gotta look at what sort of deal you got on it.  For instance, you could probably give the WM folks the $27K for that LT-70, whack up your trees and sell it for what you had in it.  That theory only holds up if you are able to part with it when the time comes. ;D :D :D
    • My homepage
It's a myth DanG, nobody has ever parted with their mill when the project is done. ;) :D
I'll agree with other comments regarding the LT40 Hydraulic mills being a better choice. Two guys without a bunch of support equipment won't use the potential of the 70 (but it would sure be fun to run  ;D ). Our LT40 Super runs me ragged with an edger and loader. As for the swinger type mills, I don't have any experience.
Offline DanG
I know dat and you know dat, but he don't know dat! ;D :D :D :D
Dang
I want you to know that I ain't never come close to crashing my "CrashHawk" my last flight was 09 Aug., 09.  I have about 3,800 hours in the Hawk. I have run the Hawk flat out at 193 K (max. in dive) and up hill too >>>  nearly straight up, pedal turn at the top at around 30 knots then right back down and then do her again, etc. .
I forgot to mention... have a demo of the LT 70 at 8:30 tomorrow morning. If I buy it, they will train me on it & we will see. I moved my money out of savings today and that's a bad sign... looking to buy... bad with fever.
I had no intention of slamming 27K into a Sawmill, I thought 15 k was my limit. However, if the LT 70 hammers tomorrow and does great things, my next post may be as the proud owner of the LT70.
You are right about WM resale value. They just sold a WM LT40 HDG that was 3 years old (nice shape) for around 5 K of its price new, that's good resale value in anyone's book.
Avery
Offline Ron Wenrich
Have you ever thought about a circle mill?  You can get good production, and if you're only going to saw your own logs, you can make it a nice operation.  You can get hand mills for around $5k that are in decent shape, and that's with power.
Take a drive up to Port Matilda and see Woody1.  He put a Frick handmill on the back of a trailer.  It looks like this:
As for sawing cabin logs, its best to make a 6x8, then send them out and have them shaped.  We take ours over to Mifflintown.  You get a much better end product.
I'm curious to the specie that you're calling yellow pine.  The only native yellow pine in that area is pitch pine.  Also known as bull pine.  I've never seen that many in one area.  Sure its not hemlock?
Trees are measured as diameter at breast height, which is called dbh.  Its a measurement at 4.5' above the ground.  When you're talking 30-38" pine, where are they measured?
Crooked logs make crooked lumber.  You can saw it straight, but it won't stay that way.
    • My homepage
You are so toast. :D
You haven't mentioned what other equipment you have, or need. Before you plunk down the dough on the mill, you might want to consider how you are going to get the logs out of the woods, move them to the mill, handle sawn lumber and slabs/sawdust. Do you have storage area for all of the product you will make? You may have this worked out, but I don't want you to come home with the mill tomorrow without having weighed those factors. ;)
You may not want to do any custom work, but your son might if he likes this kind of thing. If he helps you for a few years, he might find he would like to run it for profit part time. More than one person has sent themselves to college using a Wood-Mizer. ;)
Ron & Dang & All
The White Pine from the Hicks Property next door are big ones and they ar 30 to 38 at the base (big trees).
The Yellow Pine is another story.  I was told by the previous (Raymond Vaughan) owner that they were rare trees for our area. They average around 20 to 25 inches I'd say.
I looked up Yellow Pine and found nothing. Yes, the Pitch and Jack pine trees came up on a search.  I cut alot of Jack pine when I was on our farm for paperwood. I have been away from the woods (trees) since the 60's. I am repeating what I was told like a parrot. I will take some pic's of the (? Yellow pine ?) and match them up. Sorry that I don't know my trees anymore. Give me a few weeks and I'll be better than brain dangerous (hopefully).
Regarding the crooked trees. I see that some parts of the larger oak tree's for a tie-cut or two, the rest is firewood. These type of crooked trees need to go away, what good are they.. firewood or whatever. I want to plant some seeding trees in the spring where the junk trees were.
That's all I know for now.... remember the plan .. get me & Son out of the house for Health reasons, male bonding or dis-bonding (depends on who's operating the sawmill) & Tree I D classes when time permits <<< now that's a funny  :D :) ;) :D ;D 8)).
List of Equipment.
(graps, chains, chokers, logging stuff since the 60's
(3) Homelite saws, no junkers
TD-340 IHC with Winch bought new in 1966, 1580 hrs.
977 CAT Loader, with Gen. Purpose & Grn. Clearing Bucket w/ Hdy. Shaker
91 Marmon, 425, 15 sp., Complete OH w/ 40K on Build.
94 KW, W-900 being setup as Hvy Haul Tractor w/ 3rd lift axle.
02 Chev. Top Kick C & C, bought for flat bed dump add-on
87 Utility Truck, 70 series with 12K crane
97 Chev. Box Van, 24 foot
48 ft Washbash box trailer, skylight roof
78 5000 IHC Dump, parting out to set up 02 Chev.
91, 87, 87 Chev. 1 tons, 3/4 tons all running, no junk.
3 gas powered 300/250/200 amp Lincoln Welders
Complete Shop for Working on Big trucks & Equipment, to include 600 HP engine dyno, 2 lathes, 2 milling machines, radial arm drill, 3 Pressure washers, etc., all in all tools alone.. about $200K, your'e welcome to drop in & check my toast ? Also, If I buy the LT70 tomorrow, I'll pay cash, how's that Good Buddy.
Avery
Offline gemniii
Base as in where your foot is?  Your breast?
Quote
Certain pines (Pinus) in the subgenus Pinus subgenus Pinus:
    * In American forestry, a term for several closely related species of pine with yellow tinted wood, including the Southern Yellow Pines (Loblolly Pine, Slash Pine, Shortleaf Pine, etc.), and the non-Southern yellow pines (Ponderosa Pine, Jeffrey Pine, etc.) and several others. More than one of these species may occur at any one site, with the term 'yellow pine forests' typically used in forestry and ecology to describe such forests or stands that contain more than one of these species.
Sounds like your set on a father son project.  Take good care of the mill, slap it in good storage and it might go up in price.
If your going to buy the white pine get it in the next year, before prices start back up.
Around here pine sawtimber has gone from $50/ton down to $26/ton since '05 http://msucares.com/forestry/prices/reports/.
Offline fishpharmer
I will tell you what you want
to hear.
Go ahead and buy that LT70 ;D 8)
I predict that if you test drive it you will own it. 8)
I built my own band mill with the help of Forestry Forum.
Offline DanG
Yeah, that LT70 is sold!  I can see that from here! :D
Crash, that "Crashhawk" thing is just good old fashioned leg-pulling, but I know you already knew that.  You may as well get used to it. ;) :D
Now that you've got your mill ;D you need to think real hard about the next steps.  Just take the "worst first" from that vertical log pile you got in front of you and go to school on them.
Oh by the way.  In your spare time, don't forget that we like pics. ;D :D
I have been checking into this Sawmill Forum since I discovered it in March, I think.
I really loved the Build a Swing Blade Post, I was all over it and notice your words of wisdom at this time.
I did not remember that tree's are measured at breast height. I'd just look at the tree at eye level and get real close the dia. eye balling.
My grand father had a steam powered mill (1910/20's) years ago. My dad and his brother's worked the mill. One day one of the governor weights came off and it ran away. The mill tore itself apart and pulleys and what not flew everywhere, never rebuilt, junk. However, I remember the storys of virgin timber and lived this business. Later on, I became a heavy equipment/ diesel mechanic by trade.
However, the best times of my life was spent in the woods cutting, skidding, loading up & running loads of logs or paperwood to the mill(s).
I don't have thin skin, perhaps I took the snipes wrong, I'll adjust myself to the correct setting. This is No joke, my Son is missing the boat in regard to the real world. Most of the kids are like him, computers, gamers, I-Pod, etc. .
I tried to teach him the diesel mech. business since I retired from the Army. He does not have an interest and boring.  He can't fix his bike without 100 % supervison. I tried to get him interested in flying while I still had my hand in it... not-aa.
The sawmill deal will happen because it's a the best move for my property and I need a change of pace. I'm a little burned out on the diesel business, just another broken hunk of iron, very few smiles at the close of the day.  He may hook up or not, I know that he'll be out of the house and present at the job site, we willl see !
If that LT 70 make's me smile from ear to ear, I'll own it. It will kill me to shell out 27K.  I've bought other toys that were just that... toys this LT 70 is a high speed... low drag machine.  They have New LT40 Hdg's too for 24K I think.
Yep, I can post picture's and we will see what goes down tomorrow. I wish the Sawmill Exchange was up, they post used machines a couple times a week (swing mill ?) .
Also, it's going to be 70 degrees in PA, so it's the last boat ride on the lake, pictures of that too. I have some pic's of the last Hawk I flew in Aug. . I can add them to my gallery, that's a real buzz saw for sure, 1,700 HP X's 2.
Later,
Avery
Saw Anywhere!
