Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Woodmizer hydrostatic  (Read 1850 times)
Offline DoubleD
  • Knowledge is power
« on: September 23, 2009, 07:32:43 pm »
I would like to hear if somebody tried it and how was your impression about it
Davide ;D
Wannabe a sawmiller
Offline Bibbyman
    • Warden Sawmill
Re: Woodmizer hydrostatic
« Reply #1 on: September 23, 2009, 09:25:03 pm »
I doubt if anyone on the Forum has one.  I think they were aimed at the Amish trade.
Sawing since '94
Offline fishpharmer
« Reply #2 on: September 23, 2009, 09:45:42 pm »
I did not know what it was, so though I would search the WM site.
Here is what I found:
http://www.woodmizer.com/us/sawmills/options/hydrostatic.aspx
I built my own band mill with the help of Forestry Forum.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #3 on: September 23, 2009, 09:57:36 pm »
the head moves very fast.  I wouldn't want one without accuset on it, though (which I don't think is available)
lots of dull bands and chains
Offline ARKANSAWYER
  • Poor white Southern trash
« Reply #4 on: September 24, 2009, 05:22:08 pm »
  I have sawed with one and it was different.  The thing had alot more power for moving the head down and back so the board return was very good.   I do  not saw with the computer much any way so that did not hurt me none.  Never have seen one with many hours so I do not know what the long term ordeal would be dealing with the hydrolics and hoses would be.
ARKANSAWYER
Offline Chico
« Reply #5 on: September 24, 2009, 05:51:33 pm »
I've sawn with hydros Last fine fast  as far as a setworks you should be able to adjust the speed on them but once you get used them it'll be like everything else Hydros are quick and save a lot of arm mmovement imo
Chico
My Daughter My sailor MY HERO God Bless all the men and Women fighting for us today If you see one stop and thank them
Offline DoubleD
« Reply #6 on: September 24, 2009, 06:49:41 pm »
Thanks for the answers so far
One more question: is it only available as walk behind head?
Davide  ;D
Wannabe a sawmiller
Offline Bibbyman
    • Warden Sawmill
« Reply #7 on: September 24, 2009, 08:18:32 pm »
Davide  ;D
I'd think it'd be because you'd have to run the hydraulic hoses in the cable track.  Maybe that wouldn't work too well.  Maybe Sparks can explain better.
Sawing since '94
Offline pineywoods
« Reply #8 on: September 24, 2009, 10:20:42 pm »
Woodmizer had one on display and demo down in Mississippi a while back. A small hydraulic pump (think auto power steering pump) mounted on the head and belt driven off the kohler. 2 control valves and 2 hydraulic motors, one for up-down, one for forward-back. The thing was blazing fast, they had the ride-along seat on it. I liked it, the control handle could be used as a speed control, ie the further you pushed the forward/back lever, the faster it went, definitely plenty of power for the drag-back. Not much of a practical way to add command console or setworks
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline Mikey H
  • Hey Mikey! He likes it.
    • Used Sawmills
« Reply #9 on: September 27, 2009, 08:33:14 am »
Hey Davide,
It is only available as a walk behind. There are no setworks or Accuset available at all. Yes, it was originally aimed at the Amish but we missed!  They want hydraulic, not hydrostatic.  The head movement is amazingly fast when the blade is engaged.  It can go from 1 inch above the bed to 35" in about 7 seconds.  It's not so impressive when the blade is not engaged, because the hydrostatic pump works as hard as the engine revs.  The log handling functions also move very quickly when the blade is engaged, not so fast when it's not.  The controls for both the head and the bed can be "feathered" so they've got some finesse to them.
The few dozen people that have one are located south of us (Indy), so cold weather is not a concern for them.  I've heard rave reviews from them and I'll try to get one of them to answer you, but I'm not sure that will happen.  None of them strike me as the computer type!  One of them is a 3-time Wood-Mizer owner that basically said, "Where have you been all my life?  I love this thing!"  But, if you're north of us, I'd steer clear. It's going to work VERY slowly at 5 degrees above zero or colder until all the fluid gets warmed up.  Bad experiences by our Wisconsin and Ontario reps are the main reason you don't here much about the LT40HDD51-H from us any more. It is only available with the 51HP Cat.  Hope this helps!
I work at Wood-Mizer in used sawmill sales
Offline Bibbyman
    • Warden Sawmill
« Reply #10 on: September 27, 2009, 08:47:45 am »
Thanks Mike. And welcome to the Forum.
Follow up question  based on what you said above...  I thought the log handling hydraulics were still ran by the 12v DC pumps like any other WM hyraulic mill.  Is that not the case?  How would you run the bed hydraulics from the pump on the engine?
Sawing since '94
Offline Mikey H
    • Used Sawmills
« Reply #11 on: September 27, 2009, 09:31:39 pm »
[/quote]
My memory might be bad.  I'll check it out tomorrow (not my memory, the saw). I do remember being amazed at the up/dn head speed when the engine is rev'd up.  You're right about the bed hydraulics being 12 volt.  I remember watching our blade guys operate it a few times and could have sworn the bed operated quicker when they left the blade engaged.  More 12v juice to the two hyd pumps?  Maybe. I'll check it out. More later!
Offline Mikey H
    • Used Sawmills
« Reply #12 on: September 28, 2009, 09:31:08 am »
I talked to Burl about this just now and he gave me two answers.  The first one was, "Good catch Bibbyman, I was just testing you!"  :D The second one was, "It depends on the condition of the battery. So if a battery was low, then yes, leaving the engine rev'd up would make the bed hydraulics run faster, but that has nothing to do with having a hydrostatic head."
So in other words: MY BAD!   :-[  I guess I was so jazzed up about how fast the head was moving that I hallucinated the bed going faster.  But I'm glad I can count on you to keep me right!
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #13 on: September 29, 2009, 04:05:34 am »
I am to understand hydrostatic cannot be added to the yanmar?
Let me down easy now.   :D
Scott
[Magicman]
Offline Mikey H
    • Used Sawmills
« Reply #14 on: September 29, 2009, 08:37:34 am »
I'm typing as easy as I can.  smiley_smug01 smiley_smug01 I'm assuming you mean building a new mill with the Yanmar. Right? We don't have a kit to "add" the hydrostatic drive to an existing mill.
Nobody has ever asked for the hydrostatic with a Yanmar.  I won't say it CAN'T be done, but it's highly unlikely.  Once in a while we'll make a mill configuration we don't normally build.  But, we only do it  for someone willing to give us a non-refundable deposit. You'd be the only one in the planet with one! If you're seriously interested, I can ask.
Offline pineywoods
« Reply #15 on: September 29, 2009, 09:13:00 am »
Did a memory refresh (looked at my pics).  Not one pump but two. Both variable displacement types-reversable. No separate control valves needed. Looks like somebody cannabalized a zero-turn lawn mower. Good thinking there guys. Hooking up a remote console and setworks of any kind would take considerable back-yard engineering, but it could be done.
Offline DoubleD
« Reply #16 on: September 29, 2009, 02:34:30 pm »
Hi Mike welcome to the Forum and many thanks for your exaustive answears  8)
Davide ;D
Wannabe a sawmiller
Offline ScottAR
  • eat mo' ribs...
    • n/a
« Reply #17 on: September 29, 2009, 11:05:41 pm »
I'm not serious enough to bother anyone...  yet...
I really like those yanmar engines...
Scott
[Magicman]
Saw Anywhere!
