Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Mixed load in solar kiln  (Read 1516 times)
Offline davemartin88
« on: September 21, 2009, 06:29:45 am »
Any real concern with putting a mixed load of lumber (oak/hickory/cherry) in to a solar kiln? All the wood is between 15 and 20% moisture now and wouldn't think there would be a concern other than the different drying times. Don't have enough of each to do a full load but have more than enough if we combine- this load will probably be left in most of the winter unless we have a real heat wave here in N. Va. Thanks.
Offline pineywoods
Re: Mixed load in solar kiln
« Reply #1 on: September 21, 2009, 09:27:32 am »
I mix pine cedar and oak all the time. Kiln has a bunch of resinous pine and half-dry oak in it now. But now there are 2 factors. My solar kiln is a bit different from any I have ever seen, and 2- I'm too dumb to know you can't do that, so I go ahead. I usually air dry before it goes in the kiln, and I tend to leave it in there until I need the room for another load.
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline metalspinner
« Reply #2 on: September 21, 2009, 09:57:24 am »
Quote
...or have room to move it into the shop. ::)  My mixed load of hardwoods in the solar dryer is going to have to stay put until next spring at the earliest.  It was put in this time last year.  I just don't have room in the shop for it.
With it air dryed down below 20% I have not had any issues.  But I have the luxury of time because this is personal use.  No rushing needed.  Having a second dryer might be handy, though. Pretty much for extra drying/storage of greater variety of species.
« Reply #3 on: September 22, 2009, 10:18:09 am »
Thanks- I have a solar kiln for my own use and I use it like you guys- tend to leave the load in until I need it and then start another one from the air dried stacks but this is usually all oak. Didn't think there would be an issue but never hurts to check, thanks again.
Offline c austin
« Reply #4 on: November 14, 2009, 11:05:15 pm »
i have a old cube van 14' box that i turned into a solar kiln - which i drive to my friends mill and stack the wood in it, store the wood and sell the wood out of it. it has walnut and cherry in it now which is dried to 8%. it took 2 months to dry so i did not dry it too fast for either type of wood. I don't think it is a problem to dry different types of wood at one time if it's done in a slow, controlled manner.
Offline Lud
  • Impetuous.... Homeric....
« Reply #5 on: November 20, 2009, 07:28:23 am »
How does one turn a drivable van into a solar wood kiln??? ??? ??? ??? ???
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #6 on: November 20, 2009, 08:43:36 am »
No prob at all.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
We ship from our showroom.
N. Central TN.
Offline WDH
  • Forester
  • April 1998 - August 2008
« Reply #7 on: November 20, 2009, 09:01:10 am »
Leaving the wood in the solar kiln after the wood is dry does not result in over-drying?  Do you keep the fans running?
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline solidwoods
« Reply #8 on: November 20, 2009, 10:13:38 am »
With electricity.
Solar just refers to the heat source.
A solar kiln should have a way to control temp and humidity (something allot of people overlook) so electricity would usually be required.  It is possible to manually control heat and humidity though.
jim
Ret. US Army
N. Central TN.
Offline pineywoods
« Reply #9 on: November 20, 2009, 11:14:54 am »
Too dry ??? didn't know you could do that in Louisiana  :o  Truth be known, I've never seen a problem with that, probably just dumb luck. I usually turn off the fans and de-humidifier after about a week, or when the dh quits making water. There is some  flow in my kiln from convection, plus the enclosure is anything but air tight. The driest batch I've seen was some 1X4 oak destined for tongue and groove flooring. That measured just a tad under 6% with a pin meter.
Offline WDH
  • Forester
« Reply #10 on: November 20, 2009, 12:34:27 pm »
Piney,
If I wouldn't aggravate you too much, I would like to stop by sometimes and get a lesson on solar kilning  :).   I guess that I need to build one if I keep messin' with wood.
Offline submarinesailor
  • LT15, F250 SD 6.0L diesel, and a wife of 38 yrs
« Reply #11 on: November 20, 2009, 12:56:15 pm »
Me too.
Bruce
« Reply #12 on: November 20, 2009, 05:14:37 pm »
It's the best investment I've mad efor my woodworking hobby. ;)
Offline pineywoods
« Reply #13 on: November 20, 2009, 06:58:05 pm »
Piney,
The only thing that would aggravate me would be knowing you came by here and didn't stop to visit.  ;D I'm retired, my mill is pretty much a hobby operation, so I can and will stop and visit anytime. The real expert on runnin these things is another sawyer bout a mile up the road. His is a commercial operation, kiln is identical to mine, and he uses it to dry cypress. ON top of that, I will treat you to some of the best BBQ brisket in the south
Offline tyb525
  • Always learning.
« Reply #14 on: November 20, 2009, 07:33:29 pm »
I am pretty close to building a solar kiln. I have it modeled in sketch up if anyone wants it :)
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline woodsteach
  • My wife, 3 daughters, and mill.
« Reply #15 on: November 20, 2009, 08:05:53 pm »
Welllll what kind of question is that???
Pass it on  ;D ;D  can you attach it to your post?
woodsteach
Brand X Swing Mill, JD 317 Skidloader, MS460 & 290, the best family a guy could ever dream of...all provided by God up above.  (with help from our banker ; ) )
Offline WDH
  • Forester
« Reply #16 on: November 21, 2009, 04:19:06 pm »
OK TY,
now you are obliged to attach it.
Piney,
I will be in that area a little after the first of the year as I have business near Bastrop.  Woodbowl said he would like to be aggravating as well, so we might try to coordinate.  Thank you very much, sir.
Offline pineywoods
« Reply #17 on: November 22, 2009, 09:33:29 pm »
OK TY,
Piney,
By all means bring him on. As the crow flies, I'm about 15 miles west of Bastrop, little further around the road. Give me a yell when things firm up and I'll pm directions...
Offline WDH
  • Forester
« Reply #18 on: November 22, 2009, 11:35:12 pm »
That's a deal.
Offline climbncut
  • Urban Arborist with a love for trees
« Reply #19 on: January 05, 2010, 10:42:13 pm »
I know it's been awhile since tyb525 mentioned it, but wheres the model sketch of the kiln?
Tree Topping: "The most costly, money-wasting, tree mistreatment in the world"- Shigo
Saw Anywhere!
