BID ON A FORUM AUCTION!
I usually air dry before it goes in the kiln, and I tend to leave it in there until I need the room for another load.
How does one turn a drivable van into a solar wood kiln???
Quote from: pineywoods on September 21, 2009, 09:27:32 am I usually air dry before it goes in the kiln, and I tend to leave it in there until I need the room for another load.Leaving the wood in the solar kiln after the wood is dry does not result in over-drying? Do you keep the fans running?
I guess that I need to build one if I keep messin' with wood.
Piney,If I wouldn't aggravate you too much, I would like to stop by sometimes and get a lesson on solar kilning . I guess that I need to build one if I keep messin' with wood.
I am pretty close to building a solar kiln. I have it modeled in sketch up if anyone wants it
OK TY,Piney,I will be in that area a little after the first of the year as I have business near Bastrop. Woodbowl said he would like to be aggravating as well, so we might try to coordinate. Thank you very much, sir.
