Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Wanting to know some pricing. For my grandpa  (Read 1300 times)
Offline semologger
« on: September 17, 2009, 09:37:47 pm »
My grandpa bought a planner and molder. He asked me to see if I can find some pricing for custom work. I have no idea. Anyone know of a web site or anything to help thanks all. Semo
Offline Kelvin
Re: Wanting to know some pricing. For my grandpa
« Reply #1 on: September 19, 2009, 07:16:07 pm »
Local shop prices on finish planing, as opposed to rough planing are around $.25 bd ft and moulding around $.37 a linial foot.  Hope it helps.
Kelvin
Offline LeeB
« Reply #2 on: September 19, 2009, 07:31:25 pm »
I recon you ought to keep him no matter how much you can get for him. Grandpas are pretty hard to come by.  :D  :D
'98 LT40HDD/Lombardini, Case 580L, Ford 851 tractor. TK 1200, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 2000 F150.
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #3 on: September 20, 2009, 09:27:36 am »
Howdy.
This is our machining price list.
(I'm sure FF members will find it interesting)
MACHINE RATES.
Your logs into flooring $1.25 sq foot.
$1.40 sq foot for less than 1000sq'.
Your lumber into Flooring
$.60 sq foot *direct run, 1000 sq' or more.
$.55 sq'  *direct run, less than 1000sq'.
$.65 sq foot  from random width lumber more than 1000sq'.
$.70 sq' less than 1000sq' from random width lumber.
Your lumber into T/G Includes: kiln dry, and T/G, square ends.
For used/reclaimed materials flooring, the price is:
$1.75sf.
S1S, shiplap $1.25sf.
We don't offer pre-sized prices for used materials
Used lumber machining price list.
Includes kiln dry.
3/4 x 3x4 quarter round. .30lf
5/8 x 3/4 shoe molding.   .30lf
2.25" door/window case (in house patterns) .59lf
S1S, shiplap $1.25sf. all widths.
S2S, shiplap $1.45sf. all widths.
Resaw :
More than 1000bf
1.    Customer metal detects,  $.25bf , $5.0 per nail hit.
2.    We metal detect, $.35bf.
Less than 1000bf
1.    Customer metal detects,  $.35bf , $5.0 per nail hit.
2.    We metal detect, $.45bf.
Sawmilling.
$.20 per board foot of  material sawmilled.
$.25 bf less than 1000bf.
$.30 bf less than 500bf.
Kiln drying.
$.20 bf, 1" thick material 1000 sq' or more.
$.25 bf, 1" thick material 500-999 sq'
$.30 bf, 1" thick material 1-499 sq'
For thicker material add 10% more per qtr. thickness.
Surface 2  Sides.
$.20 sq foot  1000 sq' or more. ,
$.25sq'  12' long or 5"sq' or larger
$.30 sq'    500-999 sq'
$.35sq'    1-499 sq'
Straight line rip (straightening one edge)
$.15 bf,  1" thick material 1000 sq' or more.
$.20 bf,   1" thick material 500-999 sq'
$.25 bf,   1" thick material 1-499 sq'
$.05bf additional for lumber 12'+long.
Rip to width.
$.15 bf,  *direct run, 1" thick material 1000 sq' or more.
$.20 bf,  *direct run, 1" thick material 500-999 sq'
$.25 bf,  *direct run,1" thick material 1-499 sq'
Cross cut or Cut to length.
(To make flooring patterns like Herring Bone)
$.15 sq foot.
Moulder set up charge.
1-499bf or less,  $25.  per set up.
500bf or more, setup is free .
S4S (S2S/straighten/rip to width)
$..45 bf,  *direct run, 1" thick material 1000 sq' or more.
$..30 bf,  *direct run, 1" thick material 500-999 sq'
$..35 bf,  *direct run,1" thick material 1-499 sq' + $25 setup
$..40bf,   *direct run, 12'+long
$.35 bf,  *Non direct run, 1" thick material 1000 sq' or more.
$.40 bf,  *Non direct run, 1" thick material 500-999 sq'
$..45 bf,  *Non direct run,1" thick material 1-499 sq' + $25 setup
$ 50bf,   *Non direct run, 12'+long
S4S , pattern edges, Trim , moulding.
$.50 bf,  *direct run, 1" thick material 1000 sq' or more.
$.60 bf,  *direct run, 1" thick material 500-999 sq'
$.70 bf,  *direct run,1" thick material 1-499 sq' + $25 setup
$.80bf,   *direct run, 12'+long
$.70 bf,  *Non direct run, 1" thick material 1000 sq' or more.
$.80 bf,  *Non direct run, 1" thick material 500-999 sq'
$.90 bf,  *Non direct run,1" thick material 1-499 sq' + $25 setup
$ 1.00bf,   *Non direct run, 12'+long
Pre-finishing of materials.
$ Cost of sealer and topcoats vary depending on customer preference.
$.65 sq' +sealer and topcoat cost.
Includes a minimum of : Sprayed sanding sealer, topcoat,  (3 coats of topcoat, sand  between coats).
End match (T&G) the ends.
$.20 bf,  *direct run, 1" thick material 1000 sq' or more.
$.25 bf,  *direct run, 1" thick material 500-999 sq'
$.30 bf,  *direct run,1" thick material 1-499 sq'
Max length 6'
Glue-ups.
We can glue lumber together for moulding also.
Send your specs. for a price quote.
*Direct run is: lumber is pre-sized or  needs no pre-work, it will be run as is.  The lumber needs to be straight, within 1/8" width, within .005" of the required thickness, min lengths may apply.
Straightening, ripping, cross cutting defects , kiln dry, end match, are extra.
Non direct run is: We make the molding from random width boards.
Board Foot is:    L x W x T / 144 = BF  (use all inches or all feet)
This is used when volume needs to be known.
Square Foot is:  L x W = square foot (use all inches or all feet)
This is used when area or square feet needs to be known.
Ret. US Army
Kasco II B Band mill
Woodworking since 83
We ship from our showroom.
N. Central TN.
Offline red oaks lumber
« Reply #4 on: September 21, 2009, 06:09:09 pm »
solidwoods,
 your post is very interesting, somewhat confusing.
  my prices are as follows:
 sawing-.20 bf
 k.dry-.20bf
 s1s, s2s,s4s,any patterns (softwood .18bf) (hardwood .25bf)
  ripping .12bf
  making floor .35bf
 defecting for floor .20bf
 endmatching .20bf ( 12'' min. 16' max. length)
  widths do not matter(no up charge)
  volume   same thing (no up charge)
  for me, the less pricing options the less my customers are confused
my favorite color is   clear
Offline semologger
« Reply #5 on: September 21, 2009, 11:29:43 pm »
Thanks alot guys. i had no idea on any of this. I will be passing it along to him. Again thanks. Semo
Offline solidwoods
« Reply #6 on: October 21, 2009, 10:39:44 am »
Oaks Lumber:
What do you charge for logs to flooring, random width, random length, square end (not end matched)?
Am I'm reading your price list correct its $.75sf ?
That's milling .20  kd .20  making flooring .35  = $.75
jim
Ret. US Army
N. Central TN.
« Reply #7 on: October 21, 2009, 12:08:14 pm »
no your not reading it correct.
 sawing .20
 k.d.  .20
 machining .35
 end chop  .20
                 .95 b.f. not sq.ft
 i won't charge by the sq.ft only b.f. now selling products i'll sell by the sq.
Offline Den Socling
  • Board Moderator
  • just wondering
    • PC Specialties
« Reply #8 on: November 04, 2009, 02:19:21 pm »
red oaks,
A board foot is a square foot (12" x 12" x 1").
Den
« Reply #9 on: November 04, 2009, 05:48:32 pm »
only in the rough form, once you start maching on the wood it changes. example a 1X6 8' is 4 b.f. make 5" cover floor it drops to 3.33 sq. ft you can't foget the tongue it still is part of the board but, doesn't add to the width of cover
Offline Ironwood
    • http://www.branchandburl.com
« Reply #10 on: November 04, 2009, 08:39:24 pm »
Oaks,
 So do you charge per board foot before milled, matched trimmed? Just curious. Since as you said "you can't foget the tongue it still is part of the board "
          Ironwood
« Reply #11 on: November 05, 2009, 12:57:40 pm »
 based on rough sawn size,yes
Saw Anywhere!
