Get your Forestry Forum Hats while they last!
You can also buy a tractor with a ROPS/FOPS structure. It really depends on what your lifting needs are, and what else you might use the machine for. I like my Kubota, as it is an industrial backhoe loader, but I can also take the hoe off and use three point hitch. It can do more things than the skid loader. Run a mower, winch, box scraper, plow etc. Skid loaders are great for very specialized purposes. The tracked machines lift a lot, but are much more expensive to own and maintain. Both types of skid loader tear heck out of most any non-paved surface. Visibility and egress of skid loaders is also compromised. I lean toward a well ballasted tractor, or as Bibby suggested, a rough-terrain lift of some sort. A material handler is also a good choice, but less versatile than some options.I use a 644 Lull and a Samsung 150 (3 yard class) payloader at work. Both have their ups and downs. This is my Kubota. Will lift a 3,000 log, or a stack of lumber about a ton.(Image hidden from quote, click to view.)
I am looking to buy a piece of equipment to load logs onto my bandmill. How much advatage does a skid steer have over a tractor? A skid steer was recommended due to the roll cage/safety aspect of the design. What do you guys think?
Tractor by a mile - Just what I'm used to - I can load logs all day, never tear up the sod. Easier to get on/off of than in/out of. A zillion 3 poit hitch attachments out there. With a 3 point winch & chains, you can go just about anywhere & pull out anything that grows near me.
