Get your Forestry Forum Hats while they last!
Quote from: htpd43 on September 03, 2009, 03:20:15 pm I didn't think I did anything illegal. But I am in NJ the same state that I am a Police Officer in That should help you get out of a jamb. No overweight limits as long as you have trailer brakes apparently. Glad you made it as far as you did. Enjoy the wood sawing and the great smell of oak sawdust.
Crap isn't always a bad smell, not when it comes with a nice clear Oak board
Let’s see, #1 New sawmill#2 New Trailer#3 New truck to pull new trailerAs the bug hits the log supply will increaseI’d say don’t get rid of that truck any time soon, you may find a need for it. Although not quite as heavy duty as the five ton wrecker that you drove. (I was operator on a five-ton wrecker before graduating to a 578, then an 88, and on to a Hemet wrecker)I have had people show up with loads like what you had on, with similar stories. One guy showed up about 4 hours after dark with one axel chained up to keep it from dragging (to much) he had no idea where the tire ran off to. They had started the project of moving the logs early in the day. He made to trips to pick up the lumber.
Whatcha doing with the lumber?It may have mathed out better to get a portable mill to mill the logs.You wouldn't have had to cut off logs to fit your mill so the yield to effort would be better.Its very cheap to have a mill sawmill compared to the time/ effort /etc's of doing it your self with a chain mill.I'd say chain mills are best used for thick stock , not 2" and less.If your working with a tree removal co. maybe have them stock logs to make a min. milling job for a portable, then have them mill them. Then you can haul lumber instead of logs. If the tree clearing co sells fire wood, give them the slabs to add to their inventory.jim
