Get your Forestry Forum Hats while they last!
Wouldn't it be safer to just go up to the top, start limbing it, then use a chainsaw mill to take it down a piece at a time
I use the Humbolt notch a lot. Didn't know that was the name for it.
Tricky part is cutting the hinge, what I do is cut right below it because the hinge as it splinters and breaks can be quite dangerous. If I am cutting the hinge itself on a slope I would probably use my electric pole saw so I could cut it and be 10+ feet away (did that on a red oak). Basically nibble left to right sawing down gradually instead of cutting right through in one step.
I would have no part of that if I was you. Cutting with no notch, and pulling with a tractor to boot, is surely going to barber-chair. That tree if green is heavy enough to break a chain, and it will be shooting backward with force as well. I can't see how anyone who is an experienced tree worker would come up with this.
