Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: SOLAR SHOWER  (Read 1926 times)
Offline jmmy6767
SOLAR SHOWER
« on: August 12, 2009, 09:52:13 pm »
Hey, anybody with ant pics of solar showers out there?   I want to build one .   I don't have any drawings yet, just ideas.  I have seen some that use coiled up garden hose layed out on a roof, or some type of cover above the shower.  Would you really get any good pressure, gravity fed coming out of a garden hose?   I was thinking about building a platform  (plywood)   with a grid of pvc pipe painted black. Any advice  would be appreciated.   Thanks, jimmy ??? 8)
jimmy
Offline Don_Papenburg
  • I need
Re: SOLAR SHOWER
« Reply #1 on: August 12, 2009, 10:29:57 pm »
I have just left the garden hose out in the sun on the lawn. an hour or two will do .   There is enough water in a 50' hose to take a short shower . Enough to get a good bit of dirt /dust off .  when the temp starts to cool stop the shower quickly.
Offline moonhill
Re: SOLAR SHOWER
« Reply #2 on: August 13, 2009, 05:43:09 am »
You may have fun looking at this site.  It has plans for the DIY'ers.
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Tim
This is a test, please stand by...
Offline iffy
Re: SOLAR SHOWER
« Reply #3 on: August 14, 2009, 08:46:55 am »
Here's mine.
And here's my son's copy
Offline jmmy6767
Re: SOLAR SHOWER
« Reply #4 on: August 15, 2009, 02:22:57 am »
           Thanks, for the info. guys ;)   I  like the barrels.   If I were going to go that route I would have to stand the barrels upright, with mosquito screen.  No water suply unless I was to pump from my pond.
jimmy
Online tyb525
  • Always learning.
Re: SOLAR SHOWER
« Reply #5 on: August 15, 2009, 12:52:06 pm »
Have you considered cold showers? ;D :D
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline jmmy6767
Re: SOLAR SHOWER
« Reply #6 on: August 16, 2009, 10:15:55 am »
Well, I have taken a few of those.   Not my usual choice though.   I will keep the idea in mind .  :D
jimmy
Offline iffy
Re: SOLAR SHOWER
« Reply #7 on: August 19, 2009, 09:10:56 am »
My son spent one summer in a cabin in Colorado with no running water. They did the cistern thing with barrels above ground. They dumped all the roof drains into a series of barrels that were all connected together with plumbing at the bottom. They built a shower enclosure downhill from the cabin and just ran a hose out of the bottom of one of the barrels to the shower enclosure and put a valve and sprinkler head on it. 'course it's gotta rain once in a while and the sun needs to shine. Painting the barrels black helps. Showering right after a rain can be pretty quick and refreshing.
Offline maple flats
  • Life is what you make it!
Re: SOLAR SHOWER
« Reply #8 on: August 29, 2009, 05:07:49 pm »
Years ago, when I was a scoutmaster, we camped a few times at a wilderness, limited facilities camp. Not far from the main lodge they had a shower set up. They had a well and pump at or near the lodge and then ran black plastic pipe for water to many locations on the 5000 acre property, but all were on the 1000-1200 acres closest to the lodge. The shower they had about 8 or 10- 55 gal barrels, each plumbed in series. The water went in the first one low, exited high, entered the next low, exit high and so forth until it went thru every barrel. The sun shined on them and in the after noon or evening you could take a shower with all of the hot water you needed. Those who showered earlier had to add cold water, but later showers used mostly the hot. Even with up to 15 scouts and 2 leaders showering the last ones were still quite comfortable. If the night was cool, early showers were not done. I believe the barrels were painted flat black or another dark color and I'm sure they were drained before freezing weather. The barrels were all in a rack about 8' high, laid down flat and the one fitting used was the smaller bung, the other was welded into the other end of the barrel. The scouts would climb up to feel the tank temps to feel how the cooler water was progressing thru the system. We never ran out of hot enough water, except one time we got to it and someone had left the water running for who knows how long. That time the showers were barely warm towards the end but were still not cold.
logging small time for years but just learning how, with a Forest stewardship plan, 2 compact Ford 4x4 tractors, 3point log arch, 8000# class excavator, lifts 2500# and sets logs on mill precisely where needed,  Peterson ATS upgraded to WPF mill, sugar maple/maple syrup a hobby gone amuck.
Offline GaryinMississippi
Re: SOLAR SHOWER
« Reply #9 on: September 10, 2009, 02:26:37 pm »
When I want to take a solar shower, I just stand out in the sunshine and let those rays rain down on me.  :D
Offline rbarshaw
  • Someday
Re: SOLAR SHOWER
« Reply #10 on: September 25, 2009, 05:33:00 pm »
I have used a black 5 Gal. bucket hung from a tree with a shower head off it thru a valve. Fill it in the morning, it's warm by evening, wet down, turn water off, soap up, rinse off. Careful use would do two adults.
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
Saw Anywhere!
