Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Where to bend the tooth for setting?  (Read 1406 times)
Offline LeeB
« on: July 27, 2009, 02:20:27 pm »
I was looking at the suffulk website this morning (last night for most of you) and noticed that they set their teeth halfway up the tooth. Seems to me that this would cause problems later when resetting after a few sharpenings. I pretty much set mine up to bend the tooth right at the gullet. I use a suffolk dual tooth setter that came with the mill when I bought it used. No instructions for the setter,  so I just use like I figured would be best. Any thoughts or comments on where to put the bend?
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Re: Where to bend the tooth for setting?
« Reply #1 on: July 27, 2009, 02:50:22 pm »
I always set my clamp at the bottom of the gullet and placed the "hammer" just beneath the tip of the tooth.  That, in my estimation, gives a slow bend from the gullet to the tip.
I've seen pictures of teeth set with a sharp bend on the upper 1/3 of the tooth and have the same feeling about it as you do.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #2 on: July 27, 2009, 02:54:42 pm »
 Tom taught me.  ::) :D :D :D
Offline ely
« Reply #3 on: July 27, 2009, 03:27:43 pm »
not cetain where i clamp at. but i push just below the tip of the tooth.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: July 27, 2009, 04:07:24 pm »
The instructions that came with my Cooks Single Tooth Setter say:
"Allow the adjustable bolt point to make contact slightly below the sharp point.  The rule is to make your set or bend as high up the tooth as you can without damaging the tooth."
I adjust mine to set the blade with the bottom of the gullet just above the clamp of the setter.  This will put the adjustable bolt just below the point of the tooth.
Chuck
CHUCK - Retired USAF and now a Mobile Sawyer
1995 Wood-Mizer LT40HDG24 (Onan)
Shingle & Lap-Sider - Cooks Cat Claw Sharpener & Single Tooth Setter
4 ft Logrite cant hook and a few unknown brands.
I LOVE MY SAWMILL
Offline Puffergas
  • Jeff Davis
« Reply #5 on: July 27, 2009, 07:24:23 pm »
I set more towards the top.
Somewhere 20 miles south of Lake Erie.
Offline woodmills1
  • the truth shall set you free
« Reply #6 on: July 27, 2009, 09:21:25 pm »
did I repeat. I don't like setting............... ??? rather fill the dump with a............ :D :D ;D :D ;D :D spoon
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline backwoods sawyer
  • LT-70 proto-type, Cooks AC-36 with edger
    • Backwoods Custom Milling Inc.
« Reply #7 on: July 28, 2009, 01:59:36 am »
I keep the top of the gullet flush with the clamp. Seeing a saw with just the tip set makes me wonder about how much wear the gullets will get from sawdust spilling out. By putting a gradual bend on the whole tooth it seems that it would carry the sawdust out of the cut. There by reducing wear on the sides of the gullet.
Hmmm setting teeth verse filling the dump with a spoon. At least the beer would not have that garbage after taste if you chose setting the teeth.
100% portable. From our Backwoods to yours....
Offline bandmiller2
« Reply #8 on: July 28, 2009, 05:34:22 am »
Never really gave it much thought clamp near the bottom of the gullet push on the top.Some teeth are induction hardened about half way down the tooth you would have to bend below that.Their springy little devals i just let them bend where they want.It tough to just bend the tips,but I think the band would run easier if you can.Frank C.
Offline Cedarman
    • Cedarusa
« Reply #9 on: July 28, 2009, 07:01:39 am »
Sometimes there are burrs on the inside of the blade left from sharpening.  Therefore I make sure the backplate is just below the gullet.  If the burr pushes the blade away from the backplate then you will get false readings on the set.
Or you can make sure there are no burrs by deburring the inside gullet.
Offline Chuck White
« Reply #10 on: July 28, 2009, 08:55:43 am »
If you put the blade in the setter so that the gullet is even or slightly above the clamp, and  push the tooth just below the point, it will put a gradual bend all the way to the bottom of the gullet!  Although the tip will be bent a little more than the base of the tooth.
Chuck
I LOVE MY SAWMILL
« Reply #11 on: July 28, 2009, 04:10:09 pm »
Cedarman,
Setting before Sharpening takes care of that burr problem.   :)
Offline moonhill
« Reply #12 on: July 28, 2009, 08:55:56 pm »
http://www.suffolkmachinery.com/dual_tooth_setter.asp
I do know if you try to set less than half you risk snapping the tip of the tooth off :o
Under Extra Benefits they list longer blade life as a bonus for setting only the top half.  Art also mentions the gullet and proper set allows just the right amount of dust to slip out and stabilize the band.
Tim
Offline Cedarman
    • Cedarusa
« Reply #13 on: July 28, 2009, 09:37:30 pm »
Tom,  usually the burrs are gone after running on the mill, but sometimes especially for blades that are on the mill for only a pass or two because of "whatever"  there are burrs.  Just something to watch out for.
« Reply #14 on: July 28, 2009, 11:08:52 pm »
Yep!   I understand.  :)
Offline Puffergas
  • Jeff Davis
« Reply #15 on: July 28, 2009, 11:23:46 pm »
I use a piece of HSS to help remove the burrrrrrrrrrrrs.
Offline Andy Harden
« Reply #16 on: July 29, 2009, 12:50:44 pm »
The Suffolk dual tooth setter comes with a small plastic gage that sets the height of the blade that sticks out of the setter. This supposedly gives the best set. Some of the "little fingers" around here borrows the gage to play with and I have set the blade at the gullet height and can not tell that much difference. Every thing seems to run better following the owner’s manual.
Offline moonhill
« Reply #17 on: July 29, 2009, 04:19:30 pm »
I lost my little plastic gauge and that is when I snapped the teeth off.
Tim
Saw Anywhere!
