In Memoriam
Gallery
Find-A-Database
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
BID ON A FORUM AUCTION!
Home
Help
Search
Calendar
Extras
Tool Box
Forestry Forum Dictionary
Knowledge Base
Forestry Forum Support Auctions
Login
Register
Forum
General Forestry
Tree and Plant I.D.
(Moderators:
help identify the tree
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: help identify the tree (Read 3759 times)
Lead Administrator
Administrator
Gender:
Re: help identify the tree
Reply #20 on:
July 17, 2009, 11:08:07 pm »
Yea but isn't your experience probably mostly with more southern specimens? Our Red Maple may split easy, or it may split exactly as in the photo. Variable. Our hickories for the most part will quarter themselves if left in the sun. coyotencuttin's tree is more on a latitude as ours versus the southern hickories. I've looked at a few ten's of thousands of logs up here and I would never have guessed hickory by the photo's presented from the northern hardwoods. Not that it can't be, but its certainly not close to my first inclination.
I'm still waiting for coyotencuttin's impression of the weight. Hickory tends to have that "heavier then I expected" feel when you grab a chunk. Maple's weight is more what you would expect for a chunk of firewood of a given size
Logged
The farther backward you can look, the farther forward you are likely to see. Winston Churchill.
Because inquiring minds want to know...
Expired Circle Sawyer-Automatic Commercial Mill-Since 1979
Lanier_Lurker
Senior Member
Gender:
Give that kid some grits!!
Reply #21 on:
July 17, 2009, 11:44:25 pm »
Off topic, but whoever felled the tree appears to have done a solid job.
I have to admit that the 2 more recent pictures look an awful lot like the red maple rounds I have out in the woodpile. The bark just does not look quite like hickory - but if it is hickory it would almost have to be pignut as Dodgy says.
The unexpected weight of hickory is also a good indicator as Jeff says. I just delivered some hickory I have been saving (for smoking meat) to a coworker. The pieces were only 12 - 14 inches long and 6 - 8 inches in diameter. When I grabbed them from the pile I was still amazed at how heavy they were. That stuff is dense.
It looks like a big old red maple to this amateur. The butt log looks pretty clear and straight too with not a much taper. Might be a good sawlog.
Logged
Senior Member x2
Gender:
DanG, The Official ForestryForum Cussword
Reply #22 on:
July 18, 2009, 12:44:11 am »
I still say, flic yer Bic on a little splinter and you'll know right away if it is hickory or not.
Logged
"I don't feel like an old man. I feel like a young man who has something wrong with him." Dick Cavett
LeeB
Senior Member x2
Gender:
proud to be a TEXAN in Arkansas
Reply #23 on:
July 18, 2009, 03:00:51 am »
Just the tiniest wisp of smoke would tell the tale wouldn't it DanG.
Logged
'98 LT40HDD/Lombardini, Case 580L, Ford 851 tractor. TK 1200, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 2000 F150.
Board Moderator
Gender:
Large Tooth
Reply #24 on:
July 18, 2009, 04:13:40 am »
Looks like soft maple to me and I've never seen one split easy, it will splinter as bad as rock maple. That crotched tree would be even worst to split. Dad always cut the junk trees for firewood and it was hard labour to get them split. Finally got a wood splitter for the tractor and a tow behind after done farming. I get rock maple for firewood and I bet I get 2 rounded wheel barrels of kindling sized splinters from each 1.5 cord load.
Now white birch, that's not even work.
Logged
Pre-commercial thinning pays off.
'If she wants to play lumberjack, she's going to have to learn to handle her end of the log.'
Dirty Harry
SPIKER
Senior Member x2
Gender:
I'm new!
Reply #25 on:
July 20, 2009, 05:15:22 pm »
second set of pics tells me maple as well most defiantly not hickory from this latitude.
this is a pignut hickory it shows the traditional diamond shaped raised bark.
standard shag bark hickory
king nut hickory
unfortunately I do not have any pics in the gallery of any red/silver/sugar maples. My best guess is red maple as silver usually has more furled bark, like mentioned some maples will twist/corkscrew as the grain grows red is worse for this and also worse for splitting, usually silver maple will pop and fall apart with little effort.
Logged
I'm looking for help all the shrinks have given up on me
OneWithWood
Senior Member x2
Gender:
showing the past to the future
Reply #26 on:
July 21, 2009, 07:48:01 am »
After looking more closely at the pics I am moving away from hickory and closer to red maple.
Jeff has seen a few more logs than I so I suspect he has it right.
Logged
One With Wood
www.rwtbiodiesel.com
bull
Senior Member
Gender:
im getting board on a daily basis ho hum
Reply #27 on:
July 21, 2009, 08:13:33 am »
I hit the Maple button !!!! white wood thru to the heart.....
Logged
LeeB
Senior Member x2
Gender:
Reply #28 on:
July 21, 2009, 04:52:10 pm »
Burn some. Your nose knows.
Logged
Forester
Administrator
Gender:
April 1998 - August 2008
Reply #29 on:
July 21, 2009, 06:59:35 pm »
I just saw this thread, and it was maplish to me from the start. I lean maplish. Like Dodgy says, the end grain tells the tale.
Logged
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
coyotencuttin
member
Gender:
Reply #30 on:
July 21, 2009, 07:28:26 pm »
sorry i haven't updated anything lately. been busy cutting my little personal log yard. i tried to burn a little piece sunday night and i think it stunk. wouldn't want to eat anything from that. kinda smelled like citronella or punk. i don't think its very heavy to lift.a couple pieces pulled the limb/spike out of the wood.it would split and sometimes it would split hard but it would not split clean, it would tear more than i would say it split. thanks for all the help. harold
Logged
Woodmizer LT 40 Hydraulic.
stumpy
Senior Member
Gender:
I feel alot more like I do now than I did before
Reply #31 on:
July 22, 2009, 07:55:15 am »
I vote for Silver maple
Logged
Woodmizer LT30, NHL785 skidsteer, IH 444 tractor
Senior Member x2
Gender:
Reply #32 on:
July 23, 2009, 08:23:39 pm »
Good going Coyote! You've made a positive ID. It's a nothickory!
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
Forum
General Forestry
Tree and Plant I.D.
(Moderators:
Saw Anywhere!
