Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Blade sharpener  (Read 2340 times)
Offline ahlkey
Blade sharpener
« on: July 11, 2009, 09:55:44 am »
I have a Norwood Sawmill and have been looking at both their standard and industrial blade sharpener.  In addition have taken a good look at the Woodmizer sharpener nearby, and the Cat Claw from Cooks where a local guy sharpens them for me.  Overall it appears that for the money that the Cooks sharpener and setter is the best quality.  Anyone have experience with these sharpeners?  Given I have the Norwood mill I would like to buy Norwood but most of the references are the highest on the Cat Claw from Cooks.
Offline beenthere
  • EIEIO
Re: Blade sharpener
« Reply #1 on: July 11, 2009, 11:52:11 am »
Suggest, as a forum member, supporting the sponsor of the forum if any question as to which one.
Haven't heard anyone complaining about the WM sharpener.  :)
Offline LeeB
Re: Blade sharpener
« Reply #2 on: July 11, 2009, 12:57:22 pm »
At the risk of being branded a heritic, I have to say I prefer the Cooks. I'm comparing this to the older vintage WM that I have and no longer use. With the improvements to the newer models, the WM may be just as good. I have to use what I got.
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Offline Puffergas
  • Jeff Davis
Re: Blade sharpener
« Reply #3 on: July 11, 2009, 05:19:14 pm »
I've had Cook's Cats Claw and setter for about 15 years.
Somewhere 20 miles south of Lake Erie.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Re: Blade sharpener
« Reply #4 on: July 11, 2009, 07:55:20 pm »
I have a Cooks its a good machine.  Sounds like from your comment you have already done the leg work.  You won't regret it.  Tim
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Kobraken
    • bare hill sawmill
Re: Blade sharpener
« Reply #5 on: July 11, 2009, 10:54:50 pm »
I also have the cooks machine.  Very heavy duty and easy to setup and use.  Only had mine for a few months but it makes sharpening easy.   Ken
Offline kelLOGg
  • Good, fast, cheap... pick any two.
Re: Blade sharpener
« Reply #6 on: July 12, 2009, 06:35:51 am »
I have a Cook setter and Cat Claw sharpener and have been satisfied, but I have never tried anything else.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
Offline bandmiller2
Re: Blade sharpener
« Reply #7 on: July 12, 2009, 06:37:35 am »
I have a Cooks cats claw its built for the long haul and most parts can be found in a Graingers catalog.Its a heavy ridgid machine that will last a miller for a lifetime,with ample power very adaptable.I made a slight mod to sharpen 3" wide stellite tipped bands.Frank C.
Offline Joel Eisner
  • Building my own house using timbers from the land seemed like a good idea at the time!
    • Boothe Mountain Retreat
Re: Blade sharpener
« Reply #8 on: July 12, 2009, 07:20:30 am »
I have a Norwood sharpener with my LM2000 and it works just fine.  I saw mainly for myself and for the money you can't beat it.  I did buy mine lightly used from Stumpy when he switched to something different.
The saga of our timberframe experience continues at boothemountain.blogspot.com.
Offline ahlkey
Re: Blade sharpener
« Reply #9 on: July 12, 2009, 11:48:58 am »
Thanks for the response.   Anyone buy the band roller from Cooks?   I am having a little problem understanding if the band roller purchase is necessary and at an extra $800 it seems a lot?   Do you see the problem of diving or rising blades occurring often?   Thoughts?
Re: Blade sharpener
« Reply #10 on: July 12, 2009, 08:43:01 pm »
I have the band roller, and I have never put it on a stand yet....I check bands from time to time, and I haven't needed it....As has been alluded to in past post I think the problem with bands cupping is when people try to run a large band on a wheel that is really too small for it...It came with my mill package or I would not have it....Tim
Offline robnrob2
  • Always striving to make the tree proud.
    • Wood Crafting Woodworks
Re: Blade sharpener
« Reply #11 on: July 13, 2009, 07:01:02 am »
A band will tend to take on the shape of the crown of an ALL metal band wheel much much faster  then a rubber belt insert band wheel if at all.
Re: Blade sharpener
« Reply #12 on: July 13, 2009, 11:03:44 pm »
I have wore bands down to where I won't bother sharpening them again, and that just has not happened.  Tim
Offline Handy Andy
  • Location: right on the edge of the great american desert
  • I'm not new anymore
Re: Blade sharpener
« Reply #13 on: July 14, 2009, 11:14:03 pm »
  I've never seen a Wright, but isn't that what Timber King sells?  There are some on Sawmill exchange. And a cook, and a woodmizer.
My name's Jim, I like wood.
Offline ladylake
Re: Blade sharpener
« Reply #14 on: July 15, 2009, 07:25:03 am »
 I've been running a Wright from Tk for 7 years now, it works great.  Around $1850 or so new.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline Papa1stuff
  • Can I trade for an LT70?
Re: Blade sharpener
« Reply #15 on: July 15, 2009, 02:45:40 pm »
Has anyone used the new CBN sharpener from Woodmizer?
If so ,how do you like it ?
2008 LT40SH/51HP Cat
1994 F700 Ford Grapple Truck
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Offline LeeB
Re: Blade sharpener
« Reply #16 on: July 15, 2009, 03:04:06 pm »
Go to page 2 of this board and look about 1/3 of the way down. There is a recent thread on the CBN sharpeners there.  http://www.forestryforum.com/board/index.php/topic,38207.0.html
Offline ely
Re: Blade sharpener
« Reply #17 on: July 15, 2009, 04:18:30 pm »
i also have the cooks, and i got the package deal so it had the roller in it. i set it up and watched it gather dust for the first year. all the while thinking whats the purpose in that.
finally one day i found out. when you sharpen and set a band and it will not cut strait no matter what, just take if off and run it thru the roller. it made a believer out of me. i have only had about 8 bands that i was using go bad and have to be rolled so it is not really cost effective for me. but last year i purchased a box of bands that had to be rolled before we could even use them. thats where it paid off.
i usually will run 3 or 4 bands a year for customers that i sharpen for.
i would not take for any of my sharpening equip. all of it is cooks brand.
Offline Papa1stuff
Re: Blade sharpener
« Reply #18 on: July 15, 2009, 08:43:49 pm »
Thanks LeeB smiley_clapping
Offline Percy
  • Still got all muh fingers
Re: Blade sharpener
« Reply #19 on: July 17, 2009, 09:04:31 pm »
I dont think I have the "new" WM CBN sharpener but rather an upgrade kit I installed about three years ago. It was one of the best things I purchased for my mill business. Blade sharpening is a breeze compared to the Drag sharpener method. Im on my second wheel which is rather costly but overall, I think it is a cheaper, faster way to sharpen blades with a much more consistant result. Whatever brand you choose to go with, Im sure will work fine.  ;D
Its not the "years in your life" but the 'life in your years" that matters...Abe Lincoln
Saw Anywhere!
