Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Flooding Husky  (Read 2477 times)
Offline blue_eyed_devil
  • I put the riot in Patriot
Flooding Husky
« on: September 01, 2003, 08:59:49 pm »
I searched the forum before posting so please don't hang me for asking.
My 395 xp is about 8 months old and is used  for several hours 5 days a week.I always run high octane fuel & 50:1 husky oil.I  keep the fins clean because I do get alot of shavings build-up from brushing end grain.I changed the spark plug last week.
Last week was the first time I had to adjust the idle to stay running.
Today the temperature was around 24 celcius.
The saw would quit (when hot) immediately after releasing the throttle and instantly flood.I know Huskies flood easy but this is rediculous.
Anybody know what my problem is??
Thanks...
262 xp,395 xp,built my own chainsaw mill
Offline Kevin
    • The Milling Masters
Re: Flooding Husky
« Reply #1 on: September 02, 2003, 05:43:23 am »
I would start with a carb adjustment using a tach.
The dealer will likely do it for free if it's that new and you bought it there.
Online Jeff
  • Lead Administrator
    • THEE Forestry Forum
Re: Flooding Husky
« Reply #2 on: September 02, 2003, 12:54:22 pm »
Quote
We dont do that here. Ask all ya want. :)
Offline Minnesota_boy
  • Some like 'em short, but I prefer looong!
Re: Flooding Husky
« Reply #3 on: September 02, 2003, 02:46:41 pm »
Is your fuel tank vented properly?  Sounds like you have a pressure buildup that forces fuel past the float valve. (yah, I know there isn't a float in the chainsaw carbs anymore.)
Offline jokers
  • Chainsaw Freak
Re: Flooding Husky
« Reply #4 on: September 02, 2003, 04:46:07 pm »
Yeah, carb adjust from the ground up, or you could have sawdust that went through the vent hole and bearing on the metering diaphragm, ultimately causing the needle valve to be open when it shouldn`t be.
Russ
Re: Flooding Husky
« Reply #5 on: September 03, 2003, 07:56:54 am »
My 61 did that and I found the that the filter in the tank had come off of the fuel pickup line. I put it back and it has worked fine since.  Don't ask me why, I don't know.  I guess that it was picking up trash from the tank even though I found none in it.
Offline Viking
Re: Flooding Husky
« Reply #6 on: September 03, 2003, 10:30:29 am »
Hmm, i wouldnt call 5hrs a day "several hrs", I run my saw about 10-12 hrs a day, but anyway i've noticed that it was suggested already, but get your carb checked :)
Offline Paul_H
Re: Flooding Husky
« Reply #7 on: September 03, 2003, 05:21:44 pm »
Viking,
I don't think 5 hours a day was mentioned,but fallers out here run 6 1/2 hours a day.
I was just curious what you do for work with your saw.Do you build loghomes,firewood,spacing? I haven't been East of Saskatoon since I was a kid,and was interested in happens out there. 8)
and we shiver when the cold wind blows
Re: Flooding Husky
« Reply #8 on: September 03, 2003, 07:24:19 pm »
Well, I just got some bad news from the saw shop.My 395 was'nt flooding it's self at all.It was building up friction from excessive scoring. hence it would stall when idling.I started it and ran it 3 times after the initial stall, not realizing it what was going on.I thought it was flooded since I did'nt feel any difference when starting.
They say I'm looking at a $640.00 bill to replace piston and cylinder and general tune-up kit.
I bought this saw for building (one) log house for my father.
I would have been better off buying a homeowner Poulin!!!!!!!!
Excessive heat build-up was what they said caused.Said my oil/gas ratio looked good.............. bummer
Re: Flooding Husky
« Reply #9 on: September 03, 2003, 08:14:06 pm »
Those long shavings that I talked about about in my first post were the probable cause of the heat build-up.I get them packed between the fins from brushing out the groove on my log ends.I clean them out every day,sometimes twice a day.I guess that took it's toll over time.
Offline Kevin
Re: Flooding Husky
« Reply #10 on: September 03, 2003, 09:46:42 pm »
That's a bummer and the rebuild estimate sounds quite high .
Re: Flooding Husky
« Reply #11 on: September 03, 2003, 09:49:17 pm »
Maybe its time to check out one of the "modification" guys. :P
As long as you have to spend the money, you might as well end up with a top notch saw. :D
Offline UrbanLogger
  • Don't trash that tree . . . TREECYCLE!
    • Midtown Logging and Lumber Co.
Re: Flooding Husky
« Reply #12 on: September 07, 2003, 10:32:23 am »
Isn't it still under warranty?
If so, send the powerhead to Baileys ( www.baileys-online.com ) in a plastic bag along with a copy of the receipt.
I'm pretty sure they'll fix it up for you.
Scott Banbury, Urban logger since 2002--Custom Woodworker since 1990. Running a Woodmizer LT-30, a flock of Huskies and a herd of Toy 4x4s Midtown Logging and Lumber Company at www.scottbanbury.com
Re: Flooding Husky
« Reply #13 on: September 07, 2003, 07:34:36 pm »
At the risk of making alot of  people mad here ,I have to say in my opinion.....,thier warranty is garbage! I bought the saw from a dealer.He asked me what I was using the saw for.I told him exactly what I was doing.
He gave me a two year warranty.When he called me the other day,he says no, it's not a manufactures defect because the saw was overheated.I told him I always run Husky oil 50:1,premium fuel (which is recommended) and I did my best to really look after this unit.I spent about $1400.00 with the extra bar.
Overheated !!!! How do you know if your overheating a 2 stroke? They don't come with a temp gauge! HE says yeah but with the warmer temperatures and I must have over-worked it.I know I did not overwork it because I only used it for cutting laterals,scarfs and notches,not to mention the fact that it is almost the largest saw you can buy.
He also told me that it was only covered for 3 months for this type of thing...LOL .
I had intented to use this saw on a mill I just built.I wonder how long it would have lasted for that application?
Neways..sorry for the rant. I'm looking for the cylinder /piston kit to fix it myself.
From now on I will be mixing at 40:1 too!!!
Offline IndyIan
  • Weekend Woodsman.
Re: Flooding Husky
« Reply #14 on: September 10, 2003, 10:16:48 am »
I hope this isn't too late but it would probably be worthwhile to talk to a service rep at husky since your dealer isn't helping you.  It can't hurt to ask what they can do for you.
The excessive heat build up excuse does sound a bit fishy, imagine the heat build up of the saw cutting in the amazon...  Huge HARD, hardwood trees in 100+ degree F conditions.  As long as your air/fuel mixture was correct I would think it should be hard to kill that saw on purpose!  At least in a relatively short time.  Also the hotter the air is, the richer the A/F gets making the saw run cooler.
Good luck!
Offline Gus
Re: Flooding Husky
« Reply #15 on: September 10, 2003, 11:41:10 am »
My experience with saws has been that they are primarily designed to cut across the grain of the wood with stock chain.Now anything out of the norm, such as cuts parallel  or diaganal will make a saw run excesively hot unless the right chain is used. There are markets out there that sell this type of chain or you can grind any combination there-of.
Really to bad about your saw. My personal preference is Stihl but have always held Husky in the highest reguard. Worked along side many of them. Never seen one score a cylinder. I'm guessing what happened would have something to do with the above scenario.
Gus
"How do I know what I think unless I have seen what I say?"
Re: Flooding Husky
« Reply #16 on: September 10, 2003, 04:58:40 pm »
I frequently cut along the grain when splitting big logs.  The chain cuts faster than cutting end-grain.  I'm sure my Husky 61 gets hot. It gets worked pretty hard. I've never had a maintenance problem though.  I use the bucking teeth but don't use excessive pressure.
When splitting a log, I try to keep the bar as close to parallel with the bark as I  can.  The wood comes out in long strips rather than chips and I frequently stop and clean them from the sprocket area.
When I work the saw hard like this I add a little more oil into the gas than usual and make sure that it is fresh hi-test.
My 61 is a hard worker and I'm real proud of it.
Offline Larry
Re: Flooding Husky
« Reply #17 on: September 10, 2003, 05:41:20 pm »
I wonder how much EPA has to do with hot running saws?  I run a 272XP Husky pre EPA but know the 372XP is running a leaner mix and probably runs a lot hotter with less emissions.
Maybe Dennis or somebody that knows what they are talking about could stop in and enlighten us.
Larry
Nine out of ten trees recommend wood for your building project.
Re: Flooding Husky
« Reply #18 on: September 10, 2003, 07:52:18 pm »
I think you have a point Larry and I hear it may get worse.I think the EPA wants to see catylic converters on saws in the future.
Offline UrbanLogger
Re: Flooding Husky
« Reply #19 on: September 11, 2003, 08:07:52 am »
Blue_Eyed_Devil,
Call Husky!
You're shop is feeding you BS. There's no reason you should be having problems with your saw as long as you've run 50:1.
40:1 would get you low performance, lots of smoke and fouled plugs.
I burnt the rings on my Husky 55 ripping a 48" diameter oak log at 7 months and my dealer did all the work under warranty.
Call Husky!
Saw Anywhere!
