Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: Oak n ferrous metals  (Read 1125 times)
Offline OneWithWood
  • showing the past to the future
    • RWT Biodiesel
« on: July 02, 2009, 09:18:53 am »
I got another reminder of why you should not place green oak boards in close proximity to steel.   >:(
I milled up a red oak log for a video the other day and just laid the boards off on a pair of gravity rollers I use to help transport heavy slabs to the kiln carts.  When I moved them a day later there was a nice blue stain where the wood contacted the rollers.
A quick look around the internet seems to inidcate all aluminum gravity rollers are rare.
If I put a good thick coat of rustoleum on the rollers I have do you think I can use them with oak?
One With Wood
www.rwtbiodiesel.com
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Oak n ferrous metals
« Reply #1 on: July 02, 2009, 09:20:22 am »
I would think so.  Another option would be to send them out to have them chromed.  Not sure what that would cost.
lots of dull bands and chains
Offline DanG
« Reply #2 on: July 02, 2009, 09:40:33 am »
If you can remove the rollers from their frame, you might could make some sleeves for them from some poly pipe.  That's the cheapest and most durable solution I can think of.
Online beenthere
  • EIEIO
« Reply #3 on: July 02, 2009, 10:08:53 am »
Or turn out some wood rollers.  :)
-- or try the rustoleum first.
Offline DanG
« Reply #4 on: July 02, 2009, 11:16:50 am »
I don't think the paint would hold up very long.  Of course, the cheapest option is to just not let the lumber stay on there, in the first place.
Offline Reddog
« Reply #5 on: July 02, 2009, 12:52:46 pm »
Or take them and have a LineX or Rhino-liner(truck bed liner) sprayed on them.
We used the stuff in the shop for wear coatings in mass finishing machines. (IE industrial cement mixers)
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
« Reply #6 on: July 02, 2009, 02:50:58 pm »
I had the same thing happen this spring as I was sawing up a white oak log.  I stacked the boards on the tractor's forks as I was sawing them, and as soon as I was finished, I hauled them to the drying shed to stack.  They were already stained, even though it had only been a couple hours.  Now I make sure to put dry boards onto the forks first when stacking oak on the tractor.
The sooner you fall behind, the more time you'll have to catch up.
Wood-Mizer LT-15, 25 HP
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #7 on: July 02, 2009, 06:39:29 pm »
 Powder coat 'em.  ::) ::)
Offline WH_Conley
    • Stone Hill Hardwoods
« Reply #8 on: July 02, 2009, 08:55:18 pm »
Had that happen the other day, in minutes. guess that is why they want to saw over size and plane off.
Bill
Offline fishpharmer
« Reply #9 on: July 03, 2009, 01:45:18 am »
I learn something new here everyday. 8)
I built my own band mill with the help of Forestry Forum.
Offline woodmills1
  • the truth shall set you free
« Reply #10 on: July 03, 2009, 04:56:41 am »
most of the oak stain from short term iron contact will readily plane out.  It does not run throught the wood like the stain from internal tramp metal.
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
« Reply #11 on: July 03, 2009, 03:12:55 pm »
Even the short period that a cant sits on iron bunks will cause stain.  Stainless covers were the best thing that Woodmizer provided.  Usually this stain is not deep.
I left some Oak on the back of my work truck for a couple of months (or more) and the diamond design was so deep in the oak, it wouldn't plane out.  If the contact is minimal, I think the stain will be too.
I hit nails when sawing some oak the other day.  The next day, the line of sawdust,on the ground, beside the mill, had a black area where the nails were located.  That was from the little slivers of nail that mixed with the sawdust at that one point.  You could tell exactly where the nails were on the mill.  It doesn't take much, but it has to remain in contact long enough to make Iron Tannate.
Offline OneWithWood
    • RWT Biodiesel
« Reply #12 on: July 06, 2009, 11:55:53 am »
Thanks for all the suggestions.
It is good to see I am not alone and that this discussion has been useful for others.
If you can't be a good example at least you can be an example  ::)
That's an old saying I just made up . . . :)
One With Wood
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #13 on: July 06, 2009, 07:03:33 pm »
Its already 6 hrs old.   :D  Tim
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline DanG
« Reply #14 on: July 06, 2009, 09:26:04 pm »
 :D :D
That's pretty old, as far as sayings go.  Most of mine don't make it nearly that long! ::) :D
Offline woodmills1
« Reply #15 on: July 06, 2009, 11:57:36 pm »
so much rain here that the dripage from my iron truck bodies is leaking on to the aluminum tool boxes under the bed and making a weird looking stain.
Offline Captain
« Reply #16 on: July 07, 2009, 07:42:19 am »
This thread really brought a smile to my face.  Tom said he was sawing the other day  :)
« Reply #17 on: July 07, 2009, 09:04:43 am »
Yep! A log a day helps keep the mullygrumps away.  A neighbor kept bringing logs and I had to do something or get covered up. What I need is help, some cooler temps.... and just a log or two a day.  ;D
Offline Cedarman
    • Cedarusa
« Reply #18 on: July 08, 2009, 05:21:46 am »
Not good to sharpen your chainsaw on fresh cut oak boards either.  Or any lumber for that matter.
Saw Anywhere!
