Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: String trimmers  (Read 1653 times)
Offline ErikC
    • Erik Cordtz Enterprises
Re: String trimmers
« Reply #20 on: June 09, 2009, 10:43:47 am »
  I have a Stihl FS250, with bike handles. It's a string trimmer/medium duty brushcutter I guess. I think it was about 500 bucks, but I was buying a $150 model every other year anyway. Not much gets in its way, and with the harness I find it easy to run. I don't have to push it at all to cut anything you can cut with string, so it should last a while. It does a good job with the blade too, and it seems heavy duty enough to take it.  Started on the 2nd or 3rd pull after all winter, this will be it's 3rd summer, and I use it a lot.
Offline Modat22
  • I love my dog.
Re: String trimmers
« Reply #21 on: June 09, 2009, 11:14:51 am »
I have an echo straight shaft trimmer that I believe is almost part exchangable for the stihl line (not completely sure though). Been a great weed wacker over the years (5 years). Only Modification I did was to drill the string hole out a little so I could use the 1.0 line
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
    • Florida Inspection Associates
Re: String trimmers
« Reply #22 on: June 09, 2009, 11:41:22 am »
Well that figures, if theres a lemon out there I'll get it. ;D
Kubota L-4200, Chainsaw, Bush Hog, and 85 acres of trees I'm not sure what to do with but I sure do have fun!
The First 40 years of childhood is always the hardest.
Offline John Woodworth
Re: String trimmers
« Reply #23 on: June 10, 2009, 10:36:27 am »
I've had my Stihl for 15 plus years without a problem, have cultivator and hedge pruner attachments with it and has run flawlessly every time. I wouldn't ever concider any other brand, had a Shindawa oonce and was the biggest piece of crap I've ever seen and gave it away when less than a year old.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026
Offline SamB
Re: String trimmers
« Reply #24 on: June 10, 2009, 08:06:50 pm »
Bought my first string trimmer in the late seventy’s, it was an Echo brand straight shaft. Ran well once you got it started but could be a little stubborn to get going. It finally gave out about 86 probably the ignition module, there was no spark. Didn’t get it fixed, gave it away, since I’d inherited a Green Machine brand straight shaft. Ran the Green Machine until about 95 when it gave up, it was a lot like the Echo in that it ran well after it initially started. Next was a Shindaiwa straight shaft ran well and started easy thanks to a primer bulb in the fuel line. It died last summer, no spark, went to price an ignition module and get a second opinion on the diagnosis. This was at the dealer where I purchased it, he said he’d take it on a trade in for a new one. Thus he knocked off $75 on a new $300 trimmer and I’m on my second Shindaiwa. So far it has been a good machine I used it for five hours today and I didn’t finish all my trimming, just to give you an idea of how much it’s used. I wanted to try a Stilh this time, but couldn’t turn down the deal on the Shindaiwa. IMO you get what you pay for the upper end machines are engineered to run a little longer and take a little more abuse. If you’re as good as I am at finding yellow jacket nest and snakes you probably want to get one with straight shaft. ;D
Offline thecfarm
Re: String trimmers
« Reply #25 on: June 11, 2009, 07:21:42 am »
I'm waiting for my 20 year old Echo to die so I can buy that Stihl model with all the attachments.  ;) All that I ever replaced on that was spark plugs,the head and an air cleaner.But this model is 20 years old,doubt a new one would last. And I have used this a lot and hard too.It's not a big one or a small one either.Just the right size to use for 2-3 hours steady.
Model 6020-20hp Manual Thomas bandsaw,TC40A 4wd 40 hp New Holland tractor, 450 Norse Winch, Heatmor OWB
Offline ErikC
Re: String trimmers
« Reply #26 on: June 11, 2009, 11:29:45 am »
 I haven't owned one, but the saw shop I go to all the time sells Echo and Stihl both, and said for the midsize and small size trimmers, Echo is as good as they get. I don't think they make a thinning saw type. Anyway, his opinion of the Echos is pretty high.
Offline KGNC
  • NC mountains
Re: String trimmers
« Reply #27 on: June 11, 2009, 01:40:48 pm »
I have a Husky straight shaft I bought about 3 years ago and it has been a constant problem. It has never run right for more than 1-2 tanks of fuel. I have try to adjust the carb many times, gave up and took it to the local Husky service shop and it's still not right. I'm wondering if it could have a bad crankshaft seal like can happen on a Chainsaw.
Offline SwampDonkey
  • Large Tooth
Re: String trimmers
« Reply #28 on: June 11, 2009, 04:28:23 pm »
Yes they do actually, and it has the most power of any currently made professional brush saw we can get here in Canada at least. The old Husky is no more and have downsized a bit in weight and power to match Stihl's FS550 and is 1 lb lighter than the Stihl. We have a fellow on the crew that has owned three Echo brush saws now. He's hard on stuff so can't judge nothing by him. ;D
Dirty Harry
Offline Carries-Mom
  • Gender: Female
  • howdy ya'll!!
Re: String trimmers
« Reply #29 on: June 12, 2009, 01:19:44 pm »
There's a new one out there...don't know the brand name, but it runs on propane...no gummin' up the parts...costs under $200.  Runs off of the little canisters and can buy them at home depot...hope the info helps... ;D
Offline ADAMINMO
  • Today is gonna be another one of those days!!
Re: String trimmers
« Reply #30 on: June 12, 2009, 02:02:30 pm »
I googled the propane weed eater and looks like Craftsman has one powered by LEHR, Sell the at most Sears stores for around $220.00. That is cool. Wish I would have known that a couple weeks ago and I would have got one4 of thos instead of the Stihl FS45 that I bought. O well It works great also. Looks like they do alot of propane changeover for enviro friendly stuff.  http://www.golehr.com/
Saw Anywhere!
