Get your Forestry Forum Hats while they last!
Why post and beam? I mean, as my timberframe teacher once said, "It will take the same time or less to cut real timberframe joints than it will to fab the metal brackets and fit them, so why not do the real thing?" No metal means no rust or rot from the interaction of metal and wood and water.
and I found out that it joint have to be build tight, at least to 1/32th of a inch or 1/64th. I have problem cutting wood up to 1/8th of a inch with a skill saw... (ok ok, maybe I can be as precise as 1/16 of a inch if I take my time and use a guide). But I don't see how I could be more precise than that with a wood chisel?
Correct me if I'm wrong but if the joint isn't tight, it will not hold (be strong and reliable).
Is it more difficult to chisel dried timber than freshly cut timber?
Sounds to me like a pole barn is the way to go.... Or maybe a purchased steel outbuilding (used???)..
JFL,If you pour a one piece concrete "monoslab", it will rise and fall with the frost and would save you some digging.
