Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: elect. chainsaw sharpeners  (Read 5226 times)
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« on: May 20, 2009, 08:55:08 am »
How about who's using what and what they do or do not like about it.  I tried the search and it ain't workin. :(  Tim
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline pineywoods
Re: elect. chainsaw sharpeners
« Reply #1 on: May 20, 2009, 09:03:36 am »
Have one of them cheap harbor freight jobs. ($29.95 special) mostly plastic and does have some limitations, but it works just fine for me. Use it 5 times and it's paid for. I don't run a chain until it's so dull it takes a lot of grinding to get it sharp.
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline beenthere
  • EIEIO
« Reply #2 on: May 20, 2009, 10:18:23 am »
I only use an electric if damage from nails, rocks, or wire, etc.
Hand file is my preference, and takes no more time than setting up the electric. Again, just my preference.
A good sharp file takes one to two strokes per tooth.
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #3 on: May 20, 2009, 10:43:28 am »
i had an oregon model, I gave it to a tree service guy.
I find that a file is the way to go (much faster)...
lots of dull bands and chains
Offline sawmilllawyer
  • Ride hard, die free.
« Reply #4 on: May 20, 2009, 10:44:17 am »
Mostly hand file until the teeth need a grinding. Then I have the Harbor Frieght special like Pineywoods. Not the best set up but my chains are sharp and they cut well. The electric sharpener  really shines on chains that have rock, wire, dirt or metal damage. Couple times around with a light to medium grind does the job. Set up is kinda picky on the sharpener but once it is dialed in seems to do good work.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
Offline Ed
« Reply #5 on: May 20, 2009, 11:01:21 am »
Handfile and jig....unless the chain gets rocked real bad.
A friend has a Stihl SG, he'll straighten 'em out for me.
Ed
Offline sablatnic
« Reply #6 on: May 20, 2009, 12:09:34 pm »
Handfile and jig. (Jig from Oregon). Only grind, if the teeth has become hard because of grinding somewhere else. I repair chainsaws for a living. And sharpen "other people's chains" too. Has been doing that for about 25 years.
Offline beenthere
  • EIEIO
« Reply #7 on: May 20, 2009, 12:21:48 pm »
sablatnic
Where abouts are you located? Nothing in your bio for a clue.
thanks
Offline Cut4fun
« Reply #8 on: May 20, 2009, 12:25:13 pm »
I like the edge of hand filed best.
But I got tired of everyones rocked out chains and bought a stihl USG. Love it, wouldn't want anything different besides a Silvey Pro sharp for square and even get some pretty fast machine sharpened round chains off the USG.
Learn Chainsaw Repair ChainsawRepair
Offline sablatnic
« Reply #9 on: May 20, 2009, 01:07:52 pm »
Hi Beenthere
I live in Denmark. And yes. We do have trees here. ;-)
Offline beenthere
  • EIEIO
« Reply #10 on: May 20, 2009, 02:26:07 pm »
I thought you would have them there. :)
What is the history of the trees there?
Mostly plantation grown since the WWII era? or natural growth?
Are there trees over 70 years old that may have shrapnel from the war buried deep inside them?
I have heard that such buried artifacts were a problem in the Belgium and French forests, where many years of high quality wood grew over the buried metal from the fighting, causing sawing problems when trying to recover that wood.
Just interested in what you find in your forests now.
Glad to have you part of the forum here.  :) :)
Do you have a sawmill or do logging?
Offline mike_van
« Reply #11 on: May 20, 2009, 04:57:45 pm »
Tim, I've got the Efco grinder - Over 10 years now, not a problem with it.
Online ladylake
« Reply #12 on: May 20, 2009, 05:50:27 pm »
 Oregon 511a here, you'ld have to be realy fast hand filing to beat it for speed.   Steve
Timberking B20   Case75xt   770 Oliver   Lots of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader    2  trailers  Wright sharpener     Dino setter
Offline Devon
« Reply #13 on: May 20, 2009, 07:35:40 pm »
I use a Simington 451B swingarm grinder.  Sharpens full chisel and round, grinds gullets and I have a raker depth attachment for it as well.  Nice machine.  I highly recommend it.
Offline sablatnic
« Reply #14 on: May 20, 2009, 07:49:23 pm »
Hi beenthere
About our trees:
No. We have no problems with WWII shrapnel, since we didn't have much fighting. The nazis just took over all of the country one morning. April 9. 1945.
We see a bit of slugs from hunting, but not enough to be a problem, but you are right about France and Belgium having problems, and that is from WWI too. The Morgan car factory has had quite som problems because of that, I know.
Our trees now are mostly planted, but with some "semi naturel growth"too. (We harrow to cover the acorns and beechnuts, and weed the unwanted plants). We started planting about 200 years ago, when we had only 3% of forrest. We had 11% in 2000 and are working on 20% by 2100.
This is very brief, I know, and just the result of googling for about an hour.
No. No logging, and no sawmill. I just sell and repair saws. And brushcutters and lawnmowers. Been at it for the last 25 years. Don't know why, but maybe I like the people. Or the money?  :-D
Going to bed now. It is late night / early morning. 01:45.
Offline Jeff
  • Lead Administrator
    • THEE Forestry Forum
« Reply #15 on: May 20, 2009, 08:50:18 pm »
Search services have been restored.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #16 on: May 20, 2009, 09:21:16 pm »
I've got a Maxx grinder.  Haven't hand filed a chain since I've had it  ;D :)
« Reply #17 on: May 20, 2009, 10:49:46 pm »
Thanks for all the replys, i thank you all for answering.  I hand file, and have gotten pretty good at it, but when i have someone helping, its nice to have several chains around to be able to just change out when they get one in the dirt or rocks, and i have a heck of a time taking the time to put a dull chain back on the saw to sharpen it.   ;)    Thanks again   Tim
Offline PineNut
« Reply #18 on: May 20, 2009, 11:17:31 pm »
I have a sharpener from Harbor Freight. Not great but it gets the job done if I have do a serious job. But most of the time I would rather not have to pull the chain so it doesn’t get used too much.
Offline Heywood
  • My fifteen year dog.
« Reply #19 on: May 21, 2009, 07:29:31 pm »
This must be a good topic to ask a curiosity question?
I sharpen exclusively with a file and I don't use a jig or guide of any kind.  I use the chain until it gets down to about half the original cutter size, then I retire it with the thought that should I ever get a sharpener, or find a service that I trust to do a good joy, I might have that chain done.
Trouble is I never throw things away and my collection of chains is getting rather large.
How far do you guys take the cutters down?  ???
Heywood
Saw Anywhere!
