Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Programming WM Accuset 2 - pattern mode  (Read 3261 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
Re: Programming WM Accuset 2 - pattern mode
« Reply #20 on: May 25, 2009, 10:04:18 pm »
I don't use my Accuset 2 much for patterns.  But, I do use it all the time.  It's my main sawing mode.   I programmed all 16 of the presets for the common sizes I normally saw.
Button 1 is  - 1" - 1 1/16" - 1 1/8" - 1 1/4"
Button 2 is  - 1 1/2" - 1 3/4" - 2" - 2 1/2"
Button 3 is  - 1 5/8" - 3 5/8" - 5 5/8" - 7 5/8"   ---- These are for sawing "store bought" size 2 by's
Button 4 is  - 3" - 4" -  6" -  8"
This has really reduced my sawing times and gets me home faster.   ;D
Hidden Acres Farm
I got a shotgun, a shovel backhoe and 57 acres!
Wood-Mizer LT40HDG25
Offline Bibbyman
    • Warden Sawmill
« Reply #21 on: May 25, 2009, 10:55:47 pm »
DR,  how would you saw say 2x6s using the pattern mode?
Here is how we do it.  (Given a log say 12" dia.)
We have one Pattern programmed to 1-5/8" (what we almost always saw our 2x lumber to unless otherwise told something specific) all the way down to bed.
Then we program Pattern #5 to 1-5/8" down to 6" (we always saw to full width unless otherwise told).
We level the log on the mill and make a 6" opening face.  Turn 90,  level the log, make another 6" face.  Turn 90.  Got to Pattern #1 and drop the blade to test where it's going to make a cut.  If not deep enough to make a 6" face, we'll try the next pattern.  Make the cut.  Turn the the last face and go to the other pattern and take that slab off.  Then we go to the Pattern #5 and take boards off each side until the cant is 6" thick.  We then turn the cant up and saw all the way to the bad on Pattern #1.
Here is a link to something I put in the Knowledge base some time about about using the Accuset.  It has some pictures.
http://www.forestryforum.com/tips/tips.cgi?display:1048179042-18739.txt
Sawing since '94
Offline backwoods sawyer
  • LT-70 proto-type, Cooks AC-36 with edger
    • Backwoods Custom Milling Inc.
« Reply #22 on: May 28, 2009, 12:38:34 am »
I cut 2x4 and 2x6 the same way as you described Bibbyman, but for larger logs that give multiple stacks, I have first click under #3 set up with all 1 5/8 the second click is all 1 5/8 with a six on the bottom, the third click has two 6” on the bottom and the forth click is all 6”. The four that are under #2 are set up the same way only with 3 5/8” I use the four under #1  for 7/8”, 1”, 1 ¼” The last one is all 7/8 with 1” on the bottom this is handy for edging so that you can drop to the inch 10-9-8-7- ect. The four under #4 I use for larger stock and when I need to cut something different I will program one of the ones under #4 that is close to what I need so it takes less time to program. I also have the auto up down programmed with the common sizes, another time saver. I find the more you use the accuset the more time you save.
100% portable. From our Backwoods to yours....
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #23 on: May 28, 2009, 07:44:55 am »
Quote
For a "store bought" 2x6 I open the first face to be at least 6" using manual down.  Flip the cant 90° and do the same.  Flip 90° again and use button 3 at either 1 5/8" or 5 5/8" depending on log diameter and what looks like the most yield.   I normally try to get the 5 5/8" size first.   Then I flip the cant so the 5 5/8" side is horizontal with the last edge up.   Sometimes two of them side by side.  Then I saw thru.   Depending on wood stress or tension I may flip the cant(s) 180° every few boards.   For a real 2x6 I do the same just using the other button presets.
Hidden Acres Farm
Offline Bibbyman
    • Warden Sawmill
« Reply #24 on: May 28, 2009, 09:08:40 am »
Kind of beside the Accuset point of the topic - but we almost always saw dimension lumber like your diagram (and the ones I show on the Knowledge base) – that is with the cant centered.  We try to keep back smaller logs just so this is easier to do.  I feel it always produces better lumber.
I have seen one sawyer that, even with small logs, will try to get doubles.  He will square out the log and then saw through and through making wide boards and then stand them up on the mill and split them down the middle.  I just cringe.  Most of it looks like it should end up in the slab pile.   Half of it looks like rocker runners with pith on one edge and sap/bark on the other.
Sometimes we have to make – say 2x4s – out of a big log.  We’ll still center one cant over the heart and not split it.   Many of the outer 2x4s will have some bow but not as much as they would have had coming from splitting a smaller log down the middle.
Our Auto down/up button #1 is set to 1/2".  The next punch of that button – set #5 is at 1”,  one more poke – set #9 is at 3/4" and set # 13 is at 1/4”.   Why 1/2",1”,3/4”, and then 1/4"?  That’s because we use the 1/2" drop most often, then the 1” and so on.
We use these when we make a too shallow face cut and need to make another cut.  Often Mary is offbearing and is closer to the “face”.  She’ll give me a signal in “fingers” of how many quarters to take off.  Sometimes we are sawing long butt cut logs and can get a 1x6 by 8’ from the flare.
Sawing since '94
Offline willowrunlmbr
  • No rain, no metal, and I'm happy
« Reply #25 on: June 01, 2009, 06:30:31 pm »
Woodsmills1
I would not reccomend smashin your accuset 1.  I have a '03 lt40 super with the accuset 2 on it and have been a little disappointed.  Now I am not bashin woodmizer at all, I know they have put a tremendous effort into the Accuset 2 and Marty Parsons and Jeremy from NY have proved to be very helpful in trying to troubleshoot some problems we have been having. I also know that some people have had no trouble at all, we just werent that lucky.  That said the only problem we had with the old accuset was that it occasionally lost its place in pattern mode.  This new accuset is faster but it is supposedly extremely sensitive to voltage spikes and we have been having some problems that have cost me a lot of money in downtime and lost/cancelled jobs.  I saved my old accuset and if we cant figure out how to solve these error messages (I have replaced just about everthing at least once, and torqued nuts beyond tight) very shortly, I am gonna put the accuset one back on, because even though it occasionally lost its place and was slower, it worked.  So even though you may not need it it never hurts to have a spare.
Super LT40G36, JD544B, NH LX 885, coupla stihls, sore back, and never enough time
« Reply #26 on: June 01, 2009, 07:43:28 pm »
Woodsmills1
I can understand your frustration.
When I bought my mill it was on its fourth Accuset, and in the first two years, I went thru three more along with multiples of each of the components that connect to it.
In the process I brought in an electrical engineer and he redesigned a couple of the components and solved the over heating problems I was having with the mosfet module. Woodmizer Portland got a little hot under the collar over that but it cost me less then what I was paying for replacement parts. However, since the new Accuset 2 came along I have not had any problems. It has been like having a new mill.
I do not know if you are running the same alternator that I have on my mill, but while I was having all of the problems, I found that the wire from the alternator to the battery was maxed out with the distance it has to go. Therefore, I ran a second wire of equal size along side it to lighten the load and that took care of some of the voltage spikes that I had been having. I keep all of my electrical boxes tightly sealed and spotless in side, dust can be a real problem as well.
I hope you are able to solve your problems with the Accuset 2 soon.
« Reply #27 on: June 01, 2009, 08:22:54 pm »
backwoods sawyer,
thanks for the info, I have the original alternater on the mill, it has been tested by a local shop to be ok, but I believe I might try your reccomendation and see if it might help our situation. any help is greatly appreciated.  Thanks
Offline woodmills1
  • the truth shall set you free
« Reply #28 on: June 01, 2009, 08:57:24 pm »
my accuset expeience so far has been just completly amazing, I am up to 245 bd ft per hr working alone using the mill and the edger separatley.  I can run fast enough to run them both at the same time.  When the 70 is used to cut a cant leaving the boards in place it is a thing of beauty.  It literaly flies through the cant, up, back and then down and forward and ready as I slow the speed to enter.  No more cigaretts while I cut cants for me.
It did get confused once.  It was raining and I was trying to program a pattern and it put the little < sign on all of the numbers.  I turned it of waited and then back on it was fine.
James Mills    Lovely wife   collect old tools  vaccuming fool  36 bd ft per hour
 oak paper cutter,   apple jacks   ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family,  LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
Offline Bibbyman
    • Warden Sawmill
« Reply #29 on: June 11, 2009, 09:44:00 pm »
Advanced trick with Accuset 2…
Maybe you’ve already figured this out but just in case you haven’t..
I’ve found that I can turn the ignition switch from “Run” to “Accessory” real fast and the Accuset 2 will stay booted up and still in the mode it was in.   This may not be off much importance to you guys with engines but for us guys with electric motors tend to turn our mills off and back on a lot, it can save time.
The way this helps is;  Say you’re sawing a beam and have to make some measurements to make sure the heart is centered, etc.  You saw through and then you want to turn off the engine/motor while you’re turning and making your measurements.   You can quickly turn the ignition switch from “Run” to “Accessory” and the Accuset is still active.  Pull the slab.  Make your turn.  Make your measurements, level your log and anything else you need to do.  Then adjust the head to your next cut.  Fire up the mill and start cutting.  About 6’ down the cut, and the Accuset will be booted up and ready to go but you’re already sawing.  You didn’t have to wait for the Accuset to boot up and then move the head to the next cut, etc.
Another way I used this same trick is when I’ve made my last cut.  I’ll set the Accuset to “Go to 12”.  As soon as the blade clears the cant, I’ll bump the Up switch and I’ll disengage the motor with the AutoClutch.  When the AutoClutch has completed its cycle, I’ll turn the ignition switch from “Run” to “Accessory”.   The head will continue to rise to the “Go to 12” mark as I bring it back home.
Sawing since '94
« Reply #30 on: June 12, 2009, 11:27:54 am »
When I fire up the mill it usually stays running until lunchtime or later. But along the same lines as what you are doing. When I have just a few of an odd size to cut, I will program in the changes and not save them. When I am finished milling them, I turn the switch off and back on and the accuset goes back to the settings that were there before the changes.
Offline Magic Smoke
  • Is letting the magic smoke out of the wires bad?
« Reply #31 on: June 12, 2009, 05:23:36 pm »
willowrunlmbr,
Are you still having issues? If so, what kind of error messages are you seeing?
Offline lakeview lumber
  • Member*
simple set works
« Reply #32 on: April 15, 2010, 05:32:40 pm »
 we installed simple set set works this winter i  like it sure beats trying to read the scale  and my lumber is turning out nice and even
but after some weeks now it sometimes just fades away
and i can not move the saw  up or down
 the motor still starts and it is not a short
i open the panel and checked some wires  and then it works again
 has anybody else run into that
lakeview
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #33 on: April 15, 2010, 05:51:34 pm »
Sounds like you might have a loose connection in there.   I'd disconnect the battery and tighten all the connections in the box.
Hidden Acres Farm
Offline Bibbyman
    • Warden Sawmill
« Reply #34 on: April 15, 2010, 06:29:21 pm »
Welcome to the Forum!   8)
Sawing since '94
Offline bugdust
« Reply #35 on: April 16, 2010, 10:07:34 am »
Great info Bibbyman! When Marty installed my Accuset 2 he explained in detail the set ups, but for me a picture is worth a thousand words. Until now I've never really understood this setting and greatly appreciate your input. Just completed sawing out Hemlock material for my church's 24'X40' picnic shelter. Now that this project is completed I'm looking at 70-2"X8"X12' for a customer. After the long WV winter it sure is good to be making dust again.
Since I retired I really like work: It fascinates me. I can sit and look at it for hours.
Offline Magicman
  • Knothole Sawmill, LLC
« Reply #36 on: April 16, 2010, 03:39:28 pm »
Welcome to The Forestry Forum lakeview lumber...... :)
'98 Wood-Mizer LT40SuperHydraulic/Lombardini
There is much that I need to do, more that I want to do, and less that I can do.
Never allow your "need" to make money to exceed your "desire" to provide quality service.
Offline Magic Smoke
« Reply #37 on: April 17, 2010, 09:41:12 am »
Have you guys discovered this neat hidden feature with Accuset 2; while in the manual mode, if you hit the "Down Arrow", the head will move to the nearest whole number...sounds trivial, but kinda nice if you want to get to a whole number without bumping the head back-and-forth trying to get it right on the number.
Offline Bibbyman
    • Warden Sawmill
« Reply #38 on: April 17, 2010, 10:16:58 am »
I use it real often.  Comes in handy when we're sawing some old cants like 7x9 RR ties down to 2x6s.  When you don't want to go and make a program to saw out a few.
What would be nice .... if pushing the DOWN arrow would make it drop to the lower whole number - no matter if it was above the half mark.  And then program the UP arrow to go UP to the next whole number.
Sawing since '94
Offline Bibbyman
    • Warden Sawmill
« Reply #39 on: December 23, 2011, 10:15:25 pm »
Note to self....  If you're going to make another video where you're hands are up close all the time, clean your fingernails!
I made a video of a bit of the features of the Wood-Mizer Accuset 2.  How it works and a bit of how to program and use it.
It's L O N G....  But it's just the tail of the elephant.
Sawing since '94
Saw Anywhere!
