Get your Forestry Forum Hats while they last!
You don't need fancy wire as the wire only caries the signal, not the current. You just need to make sure its insulated as it can ground out. When we were using ours we had about 750 feet of wire. 2000 feet will do 5 acres assuming the area is square.
Testing New Bottom Sponsor Area
