In Memoriam
Gallery
Find-A-Database
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
BID ON A FORUM AUCTION!
Home
Help
Search
Calendar
Extras
Tool Box
Forestry Forum Dictionary
Knowledge Base
Forestry Forum Support Auctions
Login
Register
The Forestry Forum
Forum
General Forestry
Alternative methods and solutions
(Moderators:
Ron Wenrich
Paul_H
OneWithWood
Water Project
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Water Project (Read 714 times)
Fla._Deadheader
Senior Member x2
Gender:
Linda Vista, Costa Rica
Water Project
on:
May 10, 2009, 02:16:35 pm »
I have a project started and have been searching for Plastic
insert Pillow Block bearings. May not BE plastic, but, I do not want ball or roller bearings.
Searches turn up NOTHING, but, I DO know they exist.
Anyone know what they might be called
Logged
sawdust
Senior Member
Gender:
Re: Water Project
Reply #1 on:
May 10, 2009, 03:06:22 pm »
Is it a shape you could machine yourself? I use a plastic on my jigs that is incredible. Normally this stuff is used as the slides in boom trucks. The stuff I buy is called nylotron it is grey and is easy to cut and machine.
david
Logged
comforting the afflicted and afflicting the comfortable.
sprucebunny
Senior Member x2
Gender:
Re: Water Project
Reply #2 on:
May 10, 2009, 04:11:05 pm »
Like this
http://www.igus.com/drylinr.asp
I searched for "uhmwpe bearings" =Ultra High Molecular Weight PolyEthelyne. There is also HMWPE and HDPE
Logged
Joan Twin Stihl MS180s, MS210 and an 026 Weeding and Thinning. Gilbert Champion sawmill
Senior Member x2
Gender:
EIEIO
Re: Water Project
Reply #3 on:
May 10, 2009, 04:50:16 pm »
Try mcmaster.com
Search
Plastic bearing
Logged
Fla._Deadheader
Senior Member x2
Gender:
Re: Water Project
Reply #4 on:
May 10, 2009, 05:48:19 pm »
Looks like this, guys.
Logged
sprucebunny
Senior Member x2
Gender:
Re: Water Project
Reply #5 on:
May 10, 2009, 05:56:20 pm »
http://www.igus.com/dryr/rjui11.asp
This is a list of dimensions available for pillow block bearings.
Logged
Fla._Deadheader
Senior Member x2
Gender:
Re: Water Project
Reply #6 on:
May 10, 2009, 05:58:22 pm »
Thanks Bunny.
Looked around in there, and only saw the inserts. Gotta go back and look again.
Logged
sprucebunny
Senior Member x2
Gender:
Re: Water Project
Reply #7 on:
May 10, 2009, 06:02:36 pm »
There are other suppliers, too.
That just happened to be the first one that came up with that search.
Logged
fishpharmer
Senior Member x2
Gender:
Re: Water Project
Reply #8 on:
May 10, 2009, 06:02:52 pm »
FDH I have several old worn tailshaft UHMW plastic bearings. They are really just a solid block. They could be used if you went to a larger OD shaft.
They are from an aerator like this.
http://www.houseindustriesinc.com/AquaElectricDDA.htm
Let me know if you think you could use them.
Logged
I built my own band mill with the help of Forestry Forum.
Senior Member x2
Gender:
Re: Water Project
Reply #9 on:
May 11, 2009, 05:12:45 am »
D-header,I've seen them in a Grainger catalog,pressed steel base and plastic ball.For under water rot resistant wood will last along time as a bearing.Frank C.
Logged
Print
Pages: [
1
Go Up
« previous
next »
The Forestry Forum
Forum
General Forestry
(Moderators:
Ron Wenrich
Paul_H
OneWithWood
Water Project
Saw Anywhere!
