In Memoriam
Gallery
Find-A-Database
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
BID ON A FORUM AUCTION!
Home
Help
Search
Calendar
Extras
Tool Box
Forestry Forum Dictionary
Knowledge Base
Forestry Forum Support Auctions
Login
Register
The Forestry Forum
Forum
General Forestry
Drying and Processing
(Moderator:
Den Socling
Setting pitch, leave fans running?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Setting pitch, leave fans running? (Read 734 times)
brdmkr
Senior Member x2
Gender:
I need to slow down...
on:
April 25, 2009, 07:21:18 am »
The meter says my first load is dry. I am ready to set pitch (SYP), but got to wondering... I know to turn the copressor off, but bo I leave the fans running?
Logged
Lucas 618 Mahindra 4110, FEL and pallet forks, some cant hooks, and a dose of want-to
ellmoe
Senior Member
Gender:
I need to edit my profile!
Re: Setting pitch, leave fans running?
Reply #1 on:
April 25, 2009, 02:15:33 pm »
I don't think you would want to shut the fans off, if there is moisture it may cause problems with your fans. Additionally, the fans will help even out the heat and moisture through the kiln. I never shut my fans off.
Logged
Mark, Wildlife Biologist (in my previous life), now 2 HD40E25's, Weining Promat, Koetter Kilns (2), Sore back and arthritic fingers!
brdmkr
Senior Member x2
Gender:
Reply #2 on:
April 25, 2009, 08:01:25 pm »
Thanks Mark,
After I posted this, I began to wonder what I was thinking to even ask such. Thanks much for verification.
Logged
logwalker
Senior Member x2
Gender:
Got Logs??
Reply #3 on:
May 03, 2009, 09:43:12 am »
How hot do you get it to set the pitch? Joe
Logged
Senior Member x2
Gender:
DanG, The Official ForestryForum Cussword
Reply #4 on:
May 03, 2009, 02:16:07 pm »
My understanding is that you will "set" the pitch at whatever temp you use. The key is in maintaining that temp for a period of time long enough to evaporate the volatile components of the sap. The longer and hotter you bake it, the more firmly the pitch is set, and the wood won't bleed at temps lower than what you used.
For instance, Brdmkr is going to use his beams inside a house, so the 120° temps he used during drying should be sufficient to set the pitch for that purpose. If his house gets hotter than that, a little bleeding will be the least of his worries!
The posts he is drying for his porch will be a different story. The S. Ga. sun will get them hotter than that, so he will need to cook them pretty good.
Logged
"I don't feel like an old man. I feel like a young man who has something wrong with him." Dick Cavett
Forester
Gender:
Large Tooth
Reply #5 on:
May 03, 2009, 02:55:55 pm »
I wonder what pine tastes like outta the oven. DanG?
Oh, gotta have a little fun, eh?
Logged
Pre-commercial thinning pays off.
Dirty Harry
ellmoe
Senior Member
Gender:
Reply #6 on:
May 03, 2009, 09:27:07 pm »
I've been told 160 degrees for 24 hours. I not sure if this is by rule or what. I do know that the heavily pitched pine we saw needs to be at that temperature for the full 24 hours or we will have alot of problems with pitch build -up on our planer rollers and blades. Also, the sun shining through a window can heat up flooring, etc. to a temp. much higher than what you may think.
Logged
Print
Pages: [
1
Go Up
« previous
next »
The Forestry Forum
Forum
General Forestry
(Moderator:
Den Socling
Saw Anywhere!
