Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Old four sided planer (Hall & Brown)  (Read 4405 times)
Offline StorminN
« on: March 25, 2009, 09:59:11 pm »
Hi guys,
A friend of mine has an old planer that I think I'm going to acquire from her. It was left to her from her Dad when he passed away this past Fall. He also had a circle mill, you can read that thread and see the pictures of it here:
Anyway, I've been contemplating ways to process rough cut lumber from my Mobile Dimension mill... I have the need to make tongue in groove boards and lap siding, and I've been thinking about planers and shapers and such... smaller machines -- and then I went to look at this:
It's an old Hall & Brown four-sided planer / molder. My friend would like me to have it, since I would appreciate and use it. I'd like to have it, too... I just have to figure out how to move it and need to build a shed to put it in. I'm told it last ran about five years ago. It's dirty, but it's under cover and everything rotates by hand, no binding. If I didn't know any better, after a close inspection to make sure everything is tight and / or well lubed, I'd try and start it up... maybe with a small electric motor at first, just to make sure everything will spin right, etc.
Obviously, I'm a total greenhorn when it comes to equipment like this... I know it's dangerous and can shred / kill me in an instant, so I have respect for it... but without someone here who knows this actual machine, what do you do?
So my questions to you guys are... does anyone know anything about this particular brand or machine? I've seen other Hall & Browns online, but not one like this. I searched the forum and a couple of people mentioned having their planers, but not a four-sided molder. What about the square heads? I recall reading bad things about them? My friend tells me her Dad has spare knifes for it somewhere, including knives for T&G, lap siding, bevel siding, and perhaps cove siding. It looks like it will take a maximum of about a rough sawn 2"x12".
Here's some more pics:
Planer shed:
infeed rollers and controls
infeed rollers and square four-bladed top (first) head
six-bladed side (second) head
six-bladed side (second and third) heads
square four-bladed bottom (fourth) head
driveline side
Hall & Brown nameplate
drive wheel
engine
driveline
driveline
infeed end
driveline
patch on the base, looks like the casting was somehow cracked way back when
closeup of bottom (fourth) head
Happiness... is a sharp saw.
Offline VT_Forestry
Re: Old four sided planer
« Reply #1 on: March 25, 2009, 10:58:04 pm »
That is an awesome machine.  Not gonna lie though, looks like it will kill you in a half second :)  I'd love to see/hear that thing run!
Forester - Newport News Waterworks
Offline beav39
« Reply #2 on: March 26, 2009, 06:03:33 am »
these mills are dangerous but as long as you respect that you can really put out some fine product,im in the process of setting up a berlin machine works four sided moulder as soon as the snow is gone i will posts pics.i would say go for it just make sure you take notes on everything when you tear it down so putting it back together will go smooth                 scot
sawdust in the blood
Offline nomad
  • Member
    • Bill's Mill Portable Sawmill Service
« Reply #3 on: March 26, 2009, 06:27:44 am »
     I REALLY envy you for a chance to work on that old iron!!!
     What does it use for motors?  I'd want to check them carefully to make sure they're in good condition, or have them checked out by a motor shop (assuming it's got electric motors, that is.)  In particular, take a careful look at the start circuits.  Make sure the switches and wiring are in good condition.  Otherwise, replace them.  After cleaning and inspecting everything, I'd disconnect the belts and bump each motor to make sure it turns okay.  Don't try to use power to turn any components until you're sure there's no interference.  Turning things without any blades installed might be a real good idea, for starters.
     Once you've got it moved and installed, you'll need to check the infeed and outfeed tables for alignment.  Also make sure the heads are properly aligned and are easily adjusted.
     Has it got babbitt bearings?  If so, make sure they're not worn.  Instructions for repouring babbitt bearings are easily found and it's not difficult to do.  Square heads are scary, yes.
     You're right when you think that old machine could be dangerous.  I'd want to fabricate safety guards for all the exposed pulleys and belts, as well as the cutters, if they don't have any.  If you plan to try operating it without them in the beginning, I suggest putting up caution tape or some other barrier as a reminder to yourself and keeping other people as far away as possible.  I'd also want to disable the start circuits whenever I wasn't around it, unless you'll be able to lock the space you have it in.  It'd only take one curious person to win the "Darwin award" when you weren't there.
     Good luck with it.  I sure wish it was me instead of you!
        Bill
Offline Ironwood
    • http://www.branchandburl.com
« Reply #4 on: March 26, 2009, 06:51:09 am »
I would at least put some round (safety)  heads on the primary planing head. Square planing heads are not dangerous (per se) as they are captive in the machine. You have to make sure the knives are secure in the holders though (and that bolts have NOT been over torqued, which is common on "country equipment"). Replacing the primary horzontal head WILL give you a higher quality product AND peice of mind that the knives WILL not fly out. One option is to put some 1/2" plate steel (or thicker) schrapnel plates to protect yourself  ::). The vertical heads LOOK to be "gib and wedge" safety heads already (can be run up to 3500 rpm or so). I still like the idea of the schrapnel covers though. I would also replace the babbit w/ high speed pillow blocks (try Reid Industrial, no relation).
 I would go for it. If it were a smaller capacity I would pass on it, but the 2x12 size is a big plus. HEAVY ARN.
 Ironwood
Offline isawlogs
  • A smile is contagious ... Start an epidemic
« Reply #5 on: March 26, 2009, 08:38:58 am »
  Nice machine ,
  Nomad ,you can see the motor in one of the pics , it is all driven with that one motor, belts do the transfer.  ;)    I would take it in a flash .  8)
  You are lucky to have it all set-up ,  all you will need to do is duplicate what is there , that is really awsome .  That is nice that shewould like you to have it and keep it running .  :)
   They are heavy to move , it all depends on how far you are going with it . We have moved one similar to this one about a mile with a skidder , what we did was jack it up and put skids under it.
   Marcel
Offline pineywoods
« Reply #6 on: March 26, 2009, 10:17:43 am »
I turned down one just like it a while back. I could have gotten it running, but I just don't need another project. A 55 gallon drum half full of assorted knives came with it. The bearings are babbit, not necessarily bad, keep them lubed and they last forever. Sold for $500
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline StorminN
« Reply #7 on: March 26, 2009, 11:43:52 am »
nomad,
Marcel is right, the whole thing is run off the one gas motor... power transfered via all the belts. I believe it does have babbit bearings... and somewhere along the way, someone has replaced the oil wells with pipe nipples and zirc fittings.
Reid,
There may be some others guards for this somewhere ::) ... with the rest of the cutter knives. :D I will make a point to check all the head bolts. The chip breaker on the top head is about 1/2" thick steel, my first thought when I saw that was... that's nice that it's so thick! Yes, the vertical heads aren't square, they're round six-knife. Where would I find round "safety heads" that would fit a machine like this? I've got a good machine shop close by that could modify an existing round head. BTW, The capacity might even be larger than I thought... I found a Hall & Brown 1912 catalog online, and the "No. 8" machine, which is the 12" molder, will "dress on all four sides up to 4 inches thick. Will work flooring, ceiling, novelty siding, etc. Table drops to give 12-inch opening between Top and Bottom heads."... yep, HEAVY ARN.
Marcel, I have to move it 10 miles or so. My thought is to roll it on pipes or skids onto a low trailer. Anybody want to make a guess on how much it weighs?
Thanks guys,
-Norm.
Offline Sprucegum
« Reply #8 on: March 26, 2009, 02:55:30 pm »
Wow! A planer like that plus the mill! I'd just move down there and marry the gal - don't tell my wife  :D
I don't know anything about the machine but it sure would be fun to learn.
Offline nomad
  • Member
« Reply #9 on: March 27, 2009, 06:08:56 am »
Oops
     Sorry Norm; not sure how I missed the pic showing the motor.  As to moving it, I'd try using skids too.  Easier to set up than rollers, and not so prone to sinking in the dirt.
Offline Dana
    • Green Leaf Farms
« Reply #10 on: March 27, 2009, 06:12:09 am »
As to moving it, didn't I see a backhoe in the background in on of the pictures?
Offline Ironwood
« Reply #11 on: March 27, 2009, 06:21:44 am »
There are alot of folks converting to indexable planer heads, so keep your eye out on ebay, Craig's list and equipment dealers, the key will be getting a diameter to work close to the original diameter. The pillow blocks will alter the hieght slightly as well. You can always shim it up if you find a smaller diameter head (just gave a planer head assembly to a FF buddy in Jersey). There out there, and 12" is easy compared to a 30"+ ;)
 Ironwood
Offline StorminN
« Reply #12 on: March 27, 2009, 11:09:59 pm »
Thanks, guys...
I'll be sure to tell the gal!  ;D  :D
My current thought is either a low trailer, or a roll-back car carrier... I think I can find one around here that folds back at a low enough angle, and they all have a big winch on them... skid it onto the carrier, then skid it off when it gets to my place.
Yes, that's a JD backhoe, but it's overgrown with blackberries and hasn't run in five years or so either... it was parked with "hydraulic problems" back then (though it's a stick shift). Not a problem, though... there are a couple of working tractors still on the place, and I can bring a newer 4WD one there if need be...
Ironwood, I'll get into the heads once I get it to my place and set up. I understand... people upgrade to spiral heads and sell their old round heads. I bet you're right, 12" is easier than 30"+!... I don't plan on ever getting anything that wide! My sawmill only normally cuts 12" wide, and if have something wider than that to make flat, I bring it to work and use the 36" wide sanders we have here. Thanks for the info!
-N.
Offline John Woodworth
« Reply #13 on: March 28, 2009, 04:10:35 am »
It will take you some time and effort to get it going but you will be well satisfied in the end, ran one like it a few years ago. Keep up the maintance on the babbits(they are shimmed to take up clearancs) keep your blades sharp and above all the blade sets must be balanced as a set when sharpened or they will chatter.
Down the road the babbits if you cannot find anybody to pour them can be converted to roller brgs. they do run a lot smother with cess chatter from the play in the bearings.
We ran a 350 Buick engine to power it so if the motor can't be soved don't worry about it the critical thing is to find the correct RPM for the planner eitheir by tach or belt driven governor.
Jump on it, you will never be sorry, one pass 4 sides.
You can probably get a local tow truck (hyd boom type) to pick it up to put it on a trailer for you.
Good luck.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026
Offline Ironwood
« Reply #14 on: March 28, 2009, 06:32:32 am »
  "You can probably get a local tow truck (hyd boom type) to pick it up to put it on a trailer for you."
 I did that once w/ a 10,000 lb Oliver planer from a school dist. The crew used a bus tow truck to lift it onto my trailer.
 That would be ONE heck of a boom, more likely a crane truck. If you go that way ask for one w/ a 15,000 lb capacity. I just got done moving an 8000lb ice truck body (for a kiln), I did not want to spend $200 to hire a roll back so I winched ( 2;1 on a Warn 8000 lb oil bath gear drive commercial) it along with some help from my 3200lb truck mounted crane. I did grease the skids (literally) as I had to get it up onto a deck over trailer. I used 14'  I beams layed sideways and cribbed underneath w/ concrete blocks. I went rather well.  Your "planer" is a step up in weight, and will take some doing, but figure it weighs 10,000-12,000+ lbs. at least.
    Ironwood
Offline dail_h
  • G-Diddy and the Baby Hurlenator
Re: Old four sided planer (Hall & Brown)
« Reply #15 on: April 07, 2009, 06:54:34 pm »
   If you get a boom truck ,or a rollback,BE VERY CAREFUL how and where they,you attach straps chains cables. The frame is cast,and very unforgiving of localised stress.
          JUMP ON IT
World Champion Wildcat Sorter,1999 2002 2004 2005
      Volume Discount At ER
Singing The Song Of Circle Again
Offline StorminN
« Reply #16 on: April 09, 2009, 10:32:52 am »
This particular model of molder is very heavy in the left front corner... and it looks like it took someone by surprise in the past... the casting is cracked on the bottom corner there, and there is a steel "patch" of sorts curved steel, bolted through the frame there. The cast frame is bolted to a couple of planks, maybe 3"x12"... I'm hoping to put those planks on pipe rollers and roll it onto a low trailer. I have access to some nice steel, so I'm also considering welding up a steel "cradle" for the whole thing, to which I can attach casters. That way, I'll only need to jack it up and roll the cradle underneath, and can pull on the cradle instead of the cast iron of the molder.
Anyone got any specific recommendations?
Thanks,
-Norm.
Offline oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
« Reply #17 on: April 09, 2009, 10:37:05 pm »
That is one cool machine. They dont make them like that no more.
Once you get it up and running let me know, I'd like to come see it. :)
Offline pineywoods
« Reply #18 on: April 10, 2009, 09:33:05 am »
Norm, that crack and patch must have been a common fracture.  the one I looked at was cracked and patched just like you described. Not likely to be the same moulder, the one I was looking at was in a pine thicket in Louisiana.
Offline StorminN
« Reply #19 on: April 10, 2009, 10:20:57 am »
I will keep you all updated on the progress, and when it's up and running again, you're welcome to come take a look. I had a guy on owwm.org contact me, he's down near Portland, OR and has a few of these old molders, all are up and running down there... he invited me to come take a look, I think I will.
pineywoods, do you have pictures of the molder in Louisiana? Do you know what make it was? This Hall & Brown has been in this same spot for the last 50 years or so...
-Norm.
Saw Anywhere!
