Get your Forestry Forum Hats while they last!
With a clinometer measure the angle to the base of the tree. Take one-half of this angle and add it algebraically to 45 degrees. Move toward or away from the tree until the top of the tree sights at this angle. Re-measure the angle to the base of the tree and if the angle has changed, repeat the procedure. Rarely will you have to do this more than once. The slant distance from the tree to your eyeball is the height of the tree.
Many methods require you to be standing a known distance from the tree. This can be established with a prisim or gap gage. For example, with a 10-to-1 prism or gage, when the tree just fits the prisim or gage,you are 33 diameters from the tree. Walk up to the tree and measure the diameter and you have the distance.
