Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: How can I measure tree height?  (Read 3080 times)
Offline jeffreythree
    • JTC Woodcrafts
« on: March 17, 2009, 10:52:54 pm »
How can I measure a trees height fairly accurately without using specialized tools.  I have heard you can use a 12" ruler at arms length and measure the distance you are standing away from a tree when the tree is covered by the ruler.  Do I add any lengths to this and how accurate is it?  I have 5 trees that are close(but not close enough) to Texas Big Tree registry champion size, but two others are close enough to actually measure the height instead of guess.   A cedar elm and a post oak.
Trying to get out of DFW, the land of the $30,000 millionaires.  Look it up.
Offline Sprucegum
Re: How can I measure tree height?
« Reply #1 on: March 18, 2009, 12:12:48 am »
If you are going for the record you will have to abide by their standards of measurement, whatever that may be. If you just want to see how close you are the shadow trick works pretty good:
Use a post of known height(eg 6') and measure its shadow. Then measure the tree's shadow and the math is......
post height/post shadow = tree height/tree shadow
Good luck with your records.
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
« Reply #2 on: March 18, 2009, 10:19:29 am »
Here's a simple technique to roughly estimate height:
Hold a yardstick perfectly vertically, 36" from your eye (it's helpful to have a partner to measure the distance to your eye and make sure you're holding the stick vertically).  Now, find a spot where the yardstick just covers the tree from top to bottom while holding the stick in this manner.  Measure the distance from that spot to the tree trunk (in a straight line, don't measure up or down a slope).  This distance will be the approximate height of the tree.
Good luck, and be sure to post some pictures of the trees, along with their measurements, if you get a chance! 8)
The sooner you fall behind, the more time you'll have to catch up.
Wood-Mizer LT-15, 25 HP
« Reply #3 on: March 18, 2009, 11:19:57 am »
Or you can get someone of Known height to stand at the bottom of the tree.  Back off a goodly distance and hold a pencil or stick so that it sticks above your thumb. At arm's lenght, place your thumb on his feet and the top of the stick on his head. This gives you an increment approximating his height.  Then just raise the stick so that your thumb is at the top of his head and the stick is "his height" above.  Keep doing this until you reach the top of the tree.   Multiply the number of increments by the guy's height and you will come close to knowing the height of the tree.
Offline ADAMINMO
  • Today is gonna be another one of those days!!
« Reply #4 on: March 18, 2009, 11:47:21 am »
shimmy up that baby with a tape measure.
Offline DouginUtah
  • You can't always have a tailwind, sometimes it's going to be a headwind.
    • Doug Sherwin's Homepage
« Reply #5 on: March 18, 2009, 12:17:46 pm »
All this reminds me of the message which made the rounds years ago when a physics teacher asked the class how to use a barometer to measure the height of a building.
Numerous ways were presented, the final one was 'I would go to the building superintendent and say, "Sir, I will give you this nice shiny barometer if you will just tell me how high this building is."'  :D
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
http://www.xmission.com/~sherwin/sawyer1.
Offline TeaW
  • Just a simple woodcutter
« Reply #6 on: March 18, 2009, 12:54:57 pm »
Put a mark on the tree at a known hieght . Take digital camera get  pic of tree, put image on a screen ( tv bigger is beter) measure hieght of mark and tree . Do the math.
TeaW
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #7 on: March 18, 2009, 03:30:41 pm »
The only trouble with a lot of those methods is, as the view angle increases, the length of the pencil or ruler is exaggerated because the tree is not growing in an arc. With the camera idea, the scale changes as you move away from the focal point. Same problem with aerial photography.
Your on the right tract guys, but you need to relate distance from eye to the bottom of the stick (length EA1), and distance from eye to the base of the tree (length EA), distance from base of stick to point on the stick where the line a site passes bye to see the tree top EB1, and length of stick from it's base to the point up the stick the line of site passes to see the tree top A1B1. Then solve for height AB as follows.
AB = A1B1 x EA
             EA1
This is called a Merritt hypsometer, and finding height by proportion. The angles of the triangle formed from eye to stick are the same as eye to tree length. If you want to modify Dodgy's method a bit, you can use tangents of right triangles to get it. Some how you have the find the angle from the horizontal line of sight to the tree top (α1), measure horizontal distance (D) from eye to tree face. Then you can add the height from the ground to the horizontal line of sight (AB) to height from the horizontal line of sight to the top (BC). Find (BC). You could easily rig up a home made compass. Just take two yard sticks and fasten them at the drilled hole with a wood peg or pencil. Hold the bottom stick level, raise the other stick so your line of site along the stick sees the tree top. Get your buddy to pull out his trusty $0.25 protractor to measure the angle between the yard sticks. Get your distance from your eye to the tree. Do the math. Make sure to add the bottom portion of the tree height from ground level up to the horizontal . Make sure your on level ground or the same contour as the tree. Otherwise you'll have to add or subtract the bottom calculation depending on whether you uphill or down hill) Same principle as a clinometer. On steep slopes you no long have a right triangle so you have to find top and bottom angles in relation to line of site to a point on the tree or imaginary point under the tree. That's why it's best to try and position yourself so your line of site is horizontal at 0 degrees with the reference point on the tree. Make sure you have your carpenter's level to get that flat horizontal line D. ;D
BC = tan α1 x D
Dirty Harry
    • JTC Woodcrafts
« Reply #8 on: March 18, 2009, 04:57:39 pm »
Thanks for all of these ways to measure height.  I think I will try Dodgy's and SD's since they both require yard sticks.  Measure the angle and do it SD's way and then turn it around and use it to make sure I am sighting it 36" away and vertically like Dodgy Loner suggested.  They are both umbrella shaped, so I hope I can actually see the top.  If it is close enough I can get someone out with real equipment.
     I have not been lucky enough to find a champ in my woods yet.  The 5 that are close are a 42" dbh cedar elm with half its crown gone, a 32" 50' tall honey locust that is not any where near the champs height of 93', 2 hickories with the dbh and spread but the tops were knocked out (unless one is a mockernut which has no champ in Texas), and my biggest post oak so far has a height of ~90', crown spread of 105', but only 138" circumference(champ is 206" circ).  The cedar elm I am measuring only has a circumference of 92"(st. champ is 131"), but this tree has got to be close to 100' tall since the first branches are above all the 60-70' trees around it and the spread is ~75'.  The post oak is 201" circ and has a 125' spread because it has 3 main stems.  All of this is on 17 acres of land 8).  I wonder if the state forester will still push for clearcutting to plant pine when he finally makes it out like he suggested over the phone?
Offline Kevin
    • The Milling Masters
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #10 on: March 18, 2009, 08:41:16 pm »
Here is a drawing to demonstrate the hypsometer method with tangents.
This time we are up on a hill and to find distance D, we must slope correct length EA.
D = COS (α2) x EA
Total Height AB = BC + CA
Where BC = D tan α1 and CA = D tan α2
So,
AB = D(tan α1 + tan α2) after simplification
If the observer where down slope then,
AB = D(tan α1 - tan α2)
It's the same as what a clinometer does for ya, usually calibrated for percents or chains or metric (1:20).
Dirty Harry
Offline STUMPKICKER
« Reply #11 on: March 19, 2009, 05:55:59 pm »
Cut r' down!  ;) :D :D :D
Offline Dodgy Loner
« Reply #12 on: March 20, 2009, 12:04:31 am »
Without a proper hypsometer, any estimate of height will be very rough, no matter how complicated the math.  We could go into great detail about all of the pitfalls that could influence the accuracy of your estimate.  If the tree is leaning, you must be standing in a specific spot to get a good estimate.  Of course, there is no practical way to determine what that spot would be, so you must estimate.  If the crown is umbrella-shaped, it will be difficult to determine what the uppermost branch is, because lower branches may appear to be higher than they are due to your point of perspective.  Just get a rough estimate, and if your trees are close enough to the champions, get someone with a clinometer out there to take a more accurate measurement.
Offline Lanier_Lurker
  • Give that kid some grits!!
« Reply #13 on: March 20, 2009, 12:34:43 am »
I seem to remember someone calling SD a dweeb in another post somewhere...
(I hope winter breaks up there pretty soon)
Actually, it was techniques similar to those that yielded the earliest measurements of the height of Mt. Everest.  They started at sea level and worked their way to (or near) it with a giant protractor that had a sighting scope on it - leaving stakes in the ground as they went with the elevation at that point emblazoned on them.  Then, aiming the scope at the summit of Everest from the last two or three staked points allowed them to solve for its height.  They apparently nailed it to within less than 10 feet or so, although the actual height has increased since those days due to tectonic forces.
Geometry is cool...
Offline Dodgy Loner
« Reply #14 on: March 20, 2009, 12:45:44 am »
Bet they wouldn't have nailed it to within 10 feet with a yardstick ;D.  But yes, geometry is cool.  When I was in high school, I actually made myself a crude clinometer with a protractor, a straw with a cross-hair on one end of it, and fishing weight on a thread.  I used simple trig functions to determine the height, because with my "clinometer" I could determine the distance to the tree, the angle to the top of the tree, and the angle to the bottom of the tree.  When I got a real clinometer, I tested my homemade rig and determined that it was actually remarkably accurate.
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #15 on: March 20, 2009, 06:43:50 am »
Dodgy, why wouldn't it be accurate? It's using the same math as the clino. A clino isn't doing anything any different at all. When you look through it at the tree and see 0 on the scale bar, that is the horizontal line from your point of view, death flat, to the tree face, or into the side of the hill. When you take a top shot on that leader and you have a percent clino, for instance, and it reads 100 %, you are standing at a position where the angle is 45° above that horizontal shot. That means the opposite angle is also 45 °, so if your 80 feet from the tree, the length of that tree from the horizontal (0 reading  on clino) to the top is the same. We assume the tree is straight up and down, and the angle between the horizontal line D and the tree axis is 90°. Then add the extra length from the horizontal to the tree base for total height. If the clino is in chains, when you see 66 as a top shot, you have a 45° angle, if you have a metric 1:20, and the top is 20 on the clino reading, you are have a 45° angle. You still have to either tape the slope distance to the tree at the point you took your bottom shot to correct for horizontal distance D, just like any engineer who surveys land or pull a tape along that horizontal line to the tree on the spot the horizontal distance D (0 reading on clino) hit. Just make sure you pull out the level from your hip pocket if using protractors and yard sticks. :D :D :D The math is the same whether done by calculator or computerized gadget. It's no easier to see the top with a clino than when a yard stick, nothing magic about it. No matter what gadget you use it's only and estimate and the precise height can only be determined by climbing the tree or cutting it down. It's not rocket science and once you've done it once or twice with your yard sticks you'll actual see how easy it is and think nothing of it. A little math and someone gets sweaty palms. I sure wouldn't want use the long way to cruise a forest, but we are talking one tree. All that those fancy gadgets do is put all the rulers, the level and the scale into one handy little gadget. The problem with a ground observation is being sure whether you are actually looking at the top no matter what gadget you use. :D :D The "accuracy" of your estimate comes in making sure you measure D and the angles properly. It will never be "precise" unless the tree is physically measured from ground to tip. Using a clino, with top shots over 100 % (percent scale for this example) the accuracy goes down. Not so bad maybe in eastern trees, but when trees are twice as tall it's almost impossible to see the top with over 100 % reading anyway.
Dirty Harry
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #16 on: March 20, 2009, 09:17:41 am »
Sure is easy to find the position E from the tree where the angle between horizontal to the top of the tree is 45 degrees when your carpenter's square has a level bubble in the base. ;D
Nothing complicated here, I just got a straight piece of squared cherry to make a longer sight for my square. I'm finding the position E away from the tree where I have 45 degrees (angle α1 in my pencil drawing) from the horizontal (eye level - point C) to the top of the tree B. I mark the horizontal shot on the tree with flagging tape.
Now I measure that distance with a logger's tape from that previous determined position E. The tape is held at 0 degrees to the horizontal. That was determined with my level on the carpenter's square, then marked with orange tape on the tree. That horizontal distance D is found to be 10.6 meters.
The driveway is level, so here I show that my carpenter's square is very accurate in finding eye level on the tree. The distance AC is measured and found to be 1.8 meters.
Now for the math.
Since the horizontal distance D is easy to measure on level ground, we know that to be 10.6 meters by measuring with a tape. Simple enough. We also have the height from the ground point A up to that horizontal distance at point C, it is 1.8 meters.
Now we need to find the remaining height from point C to point B as illustrated in the pencil drawing above.
BC = D tan α1
     = 10.6 x tan (45°)
     = 10.6
Well, what do you expect when you know D by measuring from your standing position E where the sight angle makes 45°? As you know tangent of 45° is one, well you do now. :D
So, total height is:
AB = CB + CA  (from sketch)
     = 10.6 + 1.8
     = 12.4 meters ;D
Who can't add two numbers?  ::)   :D :D
Dirty Harry
Offline tonich
« Reply #17 on: March 21, 2009, 02:46:42 pm »
Offline SwampDonkey
  • Board Moderator
  • Large Tooth
« Reply #18 on: March 21, 2009, 04:41:17 pm »
I try my best Toni, but nobody believes me when I show'm how simple stuff is.  Those fancy encased wheels are just graduated in tangents as a function of units, like a D-tape is graduated in Pi increments as a function of inches or centimeters. ;D ;)
Dirty Harry
Offline Phorester
  • Can't have a healthy forest without cutting trees.
    • About Forestry Forum Host
« Reply #19 on: March 22, 2009, 07:49:16 am »
Cut the tree down, then you can accurately measure the length instead of estimating the height.  ;D
Seriously, if your tree is close to being a champion, someone will be out to check the measurements  with a clinometer anyway.
About.Forestry.Com forum host. Ya'll come: http://forestry.about.com/mpboards.htm
Saw Anywhere!
