In Memoriam
Gallery
Find-A-Database
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
BID ON A FORUM AUCTION!
Home
Help
Search
Calendar
Extras
Tool Box
Forestry Forum Dictionary
Knowledge Base
Forestry Forum Support Auctions
Login
Register
The Forestry Forum
Forum
General Forestry
Forestry and Logging
(Moderators:
Ron Scott
logging tractor
« previous
next »
Print
Pages:
1
2
3
All
Go Down
Author
Topic: logging tractor (Read 4775 times)
tyb525
Senior Member x2
Gender:
Always learning.
Re: logging tractor
Reply #20 on:
February 21, 2009, 08:55:07 pm »
Mine's gas, but it still runs great somehow.
Logged
LT10G10, Stihl 038 Magnum, many woodworking tools.
woodmills1
Senior Member x2
Gender:
the truth shall set you free
Re: logging tractor
Reply #21 on:
February 23, 2009, 04:45:27 pm »
4wd with chains on rears
Logged
James Mills Lovely wife collect old tools vaccuming fool 36 bd ft per hour
oak paper cutter, apple jacks ebonic yooper rapper nauga seller, Blue Ox? its not fast, 2 cat family, LT70 and edger, 375 bd ft/hr, we like Bob, did I say free heat machine no oil 7 years
John Woodworth
Senior Member
Gender:
Re: logging tractor
Reply #22 on:
February 25, 2009, 02:26:56 am »
I personaly wouldn't think of logging with a tractor but to each his own, here on the west coast the terrain would tear them up, skidders are probably the most abused piece of machinery in the woods yet they always get the job done and with reasonable operator safety. Too many thing on a tractor un shielded to be damaged and the frames and running gear were designed for a whole different job, if your a weekend logger you will probably be fine but JD builds both skidders for logging and tractors for logging.
Logged
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026
OneWithWood
Senior Member x2
Gender:
showing the past to the future
Re: logging tractor
Reply #23 on:
February 25, 2009, 11:12:58 am »
What is the terrain like?
I use a JD4520 with a logrite arch to pull logs out once I get the logs to the access road. My terrain is severe and I use an old JD450C crawler/loader with a monster timber winch on the back to get the logs to the road.
Widen the stance of the tractor by extending your tires and put chains on the back if the terrain is rugged.
Logged
One With Wood
www.rwtbiodiesel.com
Dom
Full Member
I edited my profile! :)
Re: logging tractor
Reply #24 on:
February 25, 2009, 03:55:40 pm »
I guess it would all depend on the type of logging you plan on doing.
If you use the tractor for your own firewood lets say a max of 10 cords a year, the 4720 should be able to do the task if you are careful and attentive to your surroundings. If you plan to log heavier then buy a proper machine.
We had a 4720 at home for a while, and settled on a L5740 (Kubota's version). Neither are tractors I would use much in the forest (only for my own firewood). They have the power, but lack weight. we use ours for brush cutting, and other light work, and for this its perfect. At 60 HP, we haven't ran out of power yet. For heavier work, a real farm tractor would be better (bigger frame, heavier, able to handle some tough times).
Logged
debushau
member
Re: logging tractor
Reply #25 on:
February 25, 2009, 05:28:47 pm »
I also use an L5740 with a Farmi to do some light firewood logging. I used to own a JD 3520 but I found that it lacked ground clearance and had too high of a center of gravity. The JD 4000 series is better in that respect but still lacks ground clearance compared to the Kubota and is somewhat more "electronic". The JD has a nicer cab though.
I looked also at an M6040 which is about the same HP as the L5740 but is a larger frame and more weight. I felt that the L was a better choice in this application because HST and a shorter length make it easier to navigate through tight trails. On the weight issue, once you put a loader on it, fill the tires, and slap a Farmi on the back, you are getting up to 6,000 lb in weight. If that's not enough, you can get wheel weights, put on a belly pan, etc.
Logged
Maineloggerkid
Senior Member
Gender:
Earth first...Log the other planets later!
Re: logging tractor
Reply #26 on:
February 25, 2009, 06:25:53 pm »
I use a 4120 full time for logging. My best was 21 cords in 2 1/2 days. The average is about 6-7 cords a day, and I get my wood hauled by a 9 cord truck.( 8 cord legally, but he always overloads) I usually cut tree length because it is quicker, but I like to cut logs in the woods. It seems much better, the lot looks nicer, and you pay more attention to details. My setup is better suited to selective cutting where the emphasis is on quality, not quantity of wood produced.
Logged
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
mike_van
Senior Member x2
Gender:
I need to edit my profile!
Re: logging tractor
Reply #27 on:
February 25, 2009, 06:28:37 pm »
My limited 2 cents - Steep ground, lots of rocks, skidder country. The rest of it I think depends on the operator, how careful they are. Some will cut off a 4" tree, some want to push it over & mush on - A guy trying to fill a quota with a tractor is probably going to push it right to the max & beyond all the time. Someone doing their own stuff on their own lands going to be a lot easier.
Logged
sparky
Full Member x2
Gender:
I have the energy of someone twice my age!
Re: logging tractor
Reply #28 on:
March 01, 2009, 06:47:48 pm »
Selecting a tractor is like eating a watermellon. "Go for the red and throw the green away".
Sparky
Logged
I'tnl 2050 with Prentrice 110, Custom built 48" left-hand circular and 52" Bellsaw right-hand circular mills, Jonsered 2171, Stihl 084, and too many other chainsaws. John Deere 3020 and Oliver 1800 with FELs. 20" 4-sided planer and misc.
thedeeredude
Senior Member x2
Gender:
RufusRuffcut and Sawtooth to da races!
Re: logging tractor
Reply #29 on:
March 01, 2009, 07:46:02 pm »
Self loathing, are we?
Logged
woodmills1
Senior Member x2
Gender:
Re: logging tractor
Reply #30 on:
March 01, 2009, 08:17:52 pm »
the other orange has treated me well.
Logged
cilley
member
Gender:
Re: logging tractor
Reply #31 on:
March 03, 2009, 01:57:50 pm »
Hi everyone...........what you have usually depends on what your needs are........small operation, smaller tractor.........not in a hurry, same thing........and of course the number one concern.....what we can afford.........I just bought a 1963 Ford 4000 this weekend.........its not pretty.....but i know it will do what I want it to do..........price was right and paint is cheap....getting ready to mill some wood in the next 2 weeks........take care all.......Alan
Logged
sparky
Full Member x2
Gender:
Re: logging tractor
Reply #32 on:
March 03, 2009, 03:40:29 pm »
Deer Dude,
I have two green tractors, but my other colors outnumber them about 12 to 2. I am into antique tractors and most of mine start by crank. The John Deere and Oliver were bought because of price and the fact they have FELs. I have used both of them to skid and load.
Sparky
Logged
thedeeredude
Senior Member x2
Gender:
Re: logging tractor
Reply #33 on:
March 03, 2009, 08:09:01 pm »
Any pictures sparky? I love antique tractors in all colors.
Logged
Dave Shepard
Senior Member x2
Gender:
Geometrically proportional
Re: logging tractor
Reply #34 on:
March 03, 2009, 09:41:06 pm »
I've got a few, there all red but one. I-14 electric, SW6-TA, I-4, F-12 Waukesha, are a couple of the neater ones.
Logged
Wood-Mizer
LT40HDD51
Wireless,
Kubota
L48, Honda Rincon 650,
TJ208 G-S,
and a 60"
LogRite!
sparky
Full Member x2
Gender:
Re: logging tractor
Reply #35 on:
March 06, 2009, 04:49:11 pm »
Deer Dude,
I need to learn the procedure for posting photos. I will post a few when I discover how to do it. My pride and joy is a 1925 Minneapolis Threshing Machine, Model 17-30. It has a 2 speed tranny and 2nd is 3.25 MPH. It is a cross motor designed for belt work with 30 belt HP. The manifold has a selector to switch between distillate fuel and gasoline. It is stuck in the distillate position so I can't work it hard. I would like to belt it up to our tractor club's circular sawmill just for a cheap thrill.
Sparky
Logged
Polly
Senior Member
Gender:
I'm new!
Re: logging tractor
Reply #36 on:
March 06, 2009, 07:41:06 pm »
how about the log wench that fits on the 3 point hitch and runs off the pto has anyone got one,are they any good
Logged
Dave Shepard
Senior Member x2
Gender:
Re: logging tractor
Reply #37 on:
March 06, 2009, 07:50:12 pm »
I've got an older Farmi winch, and it's great. If you are logging with a tractor, it makes a big difference. Not only is it good for pulling logs out of weird places, but it keeps the butts off the ground, keeping things a little cleaner, and makes them easier to pull. Also, you can drop the logs and navigate around small obstacles, and then winch the logs back to the machine. Go back to the first page to see my logging setup, post #17
Logged
Wood-Mizer
LT40HDD51
Wireless,
Kubota
TJ208 G-S,
and a 60"
LogRite!
Reddog
Senior Member x2
Gender:
Re: logging tractor
Reply #38 on:
March 06, 2009, 09:13:07 pm »
Yes, as Dave pointed out they work well.
I have a 601 Farmi.
Logged
Banjo picker
Senior Member x2
Gender:
A goal without a plan is just a dream. Elbert H.
Re: logging tractor
Reply #39 on:
March 06, 2009, 09:28:34 pm »
What would be the speed and capasity of the farmi, I have a M7040 Kubota with a front end loader. Tim
Logged
Cooks AC 36--Prentice 210C--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Print
Pages:
1
2
3
All
Go Up
« previous
next »
The Forestry Forum
Forum
General Forestry
(Moderators:
Ron Scott
logging tractor
Saw Anywhere!
