Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Sawing Pecan?  (Read 914 times)
Offline AJ
Sawing Pecan?
« on: August 02, 2003, 09:21:06 am »
Hello All,
I've got some pecan logs, probably about 1000 bf or so, that I need to saw up.  Several are pretty large, 24" or better.
My plan is to saw them and get them loaded into my solar kiln (or at least whatever will fit), but I'm not sure what size to saw them.
I'll use some of the wood myself, may try to sell some of the rest.  I was thinking of sawing most of it 4/4, and some 8/4.  How wide can I leave the boards without incurring too much cupping?  And, can both thicknesses be loaded at the same time in the kiln?
Thanks for any help,
Andy
Offline oakiemac
  • God bless the U.S.A!
    • Hickoryandoak
Re: Sawing Pecan?
« Reply #1 on: August 02, 2003, 10:30:18 am »
Is Pecan the same commercially as Hickory? ???
Offline AJ
Re: Sawing Pecan?
« Reply #2 on: August 02, 2003, 11:10:19 am »
From what I understand, it's all sold as the same.
Andy
Offline OneWithWood
  • showing the past to the future
    • RWT Biodiesel
Re: Sawing Pecan?
« Reply #3 on: August 02, 2003, 05:01:25 pm »
Let me ask it a different way.  What is the difference between pecan and hickory?  I always thought pecan was a type of hickory.  You know, like mockernut, bitternut, shakbark, etc.
One With Wood
www.rwtbiodiesel.com
Re: Sawing Pecan?
« Reply #4 on: August 02, 2003, 08:23:13 pm »
Pecan is a smoother brown in color whereas hickory is creamy colored with a browner heart and areas of red and brown streaks.  They are both about the same to saw, tough, and the woods work the same in the shop.
Borers like the sapwood so promptness in drying and perhaps some insecticide is warranted.
I've cut hickory and pecan as wide as the log will stand in 5/4 and gotten good results.  I wouldn't cut it any thinner than 4/4 and would even want that on the fat side.
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
Re: Sawing Pecan?
« Reply #5 on: August 03, 2003, 06:51:58 am »
I would flat cut it 1.125" on the mill scale. Best sides up/down and flat saw it.  As wide as you wish. Stack it on the bottom of the stack, sticks 1' apart.  Other thickness if you have a plan on its use. No plan, just mill/sell on spec?  Make it 4/4.
I wouldn’t saw around the heart (box the heart), just flat cut.
When it's 6-8% mc call a cabinet shop and step aside.  Surrounding objects may be in danger from the vacuum created by it's disappearance.
JIM
Ret. US Army
Kasco II B Band mill
Woodworking since 83
I mill & kiln dry lumber, build custom furniture, artworks, flooring, etc.
If you mill, you'll be interested in some of my work in one way or another.
We ship from our showroom.
N. Central TN.
Online Ron Wenrich
Re: Sawing Pecan?
« Reply #6 on: August 03, 2003, 11:45:31 am »
There are 2 types of hickory - true hickory and pecan hickory.
True hickories include shagbark, carolina, shellbark, mockernut, red, and pignut.
Pecan hickories include pecan, bitternut hickory, and water hickory.
It all gets sold as hickory lumber.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
Re: Sawing Pecan?
« Reply #7 on: August 03, 2003, 06:59:44 pm »
I agree with Solidwoods.
Before we left Arkansas, I had about 1200 ft, air dried in
the shop loft. I called one of my old customers, a Dr. that had a small furniture shop started. He paid well for all of it and asked if I had more.  It had a slight pinkish hue ???
 It was all 5/4 and about 8"-15" wide.
Offline AJ
Re: Sawing Pecan?
« Reply #8 on: August 03, 2003, 08:40:02 pm »
OK guys,
Thanks for the advice.  I've sawn about a fourth of what I have, cut it to 4/4 and put it in the kiln.  I believe I'll cut the rest at 5/4, I think I should have some 14-16" wide boards.
How well does this air dry, and how long will the logs keep without degrading?  The ends are sealed, but it sure is hot right now, and they're in full sun.
Thanks,
Andy
Offline LeeB
Re: Sawing Pecan?
« Reply #9 on: August 04, 2003, 12:30:53 am »
what i have cut air dried fairly well. don't let the logs set in the hot sun too long as it will change the color. not really blue stain but similar. it also gets hard as rock the drier it gets. my favorite wood. LeeB
'98 LT40HDD/Lombardini, Case 580L, Cat D4C, Ford 851 tractor, JD 3032 tractor, Husky 346 and 372XP's. !998 and 2006 3/4 Dodge 5.9 Cummins and a 1966 Chevy C60 w/ dump bed.
Saw Anywhere!
