Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: 262 xp  (Read 1139 times)
Offline blue_eyed_devil
  • I put the riot in Patriot
262 xp
« on: July 31, 2003, 04:50:55 pm »
Hello all
New to the forum.Does anyone know of a 18" bar that will fit my 262 that is comparable to the Windsor mini-pro.I can't find a mini-pro to fit my saw.I can mod one to work but was looking for a quick solution.
Thanks.... ;D
262 xp,395 xp,built my own chainsaw mill
Offline Kevin
    • The Milling Masters
Re: 262 xp
« Reply #1 on: July 31, 2003, 06:23:39 pm »
Welcome,
Baileys has them.
http://www.baileys-online.com/store/USA.htm
Item No: SVMP 18 SJ50
18" Mini-Pro Bar (.050 gauge) for medium Husky (uses 64 drive links of 375 pitch and 72 drive links of .325 pitch)   $27.95 U.S.
These guys should have it ...
British Columbia  Celtic Distributors  800-663-4742  Full Line Pro
Offline Kevin
Re: 262 xp
« Reply #2 on: August 01, 2003, 03:11:59 pm »
Oregon Power Match Plus will also give you a solid bar with a reduced nose radius.
Re: 262 xp
« Reply #3 on: August 01, 2003, 09:05:15 pm »
Thanks Kevin
Building a hancrafted log house.I have a 20" mini pro for my 395.It is probably over-powered for the small nose radius but I luv the maneuverability I get with the mini-pro.
Do you think the power match is a better bar.I might try it out on the 262.
Offline Kevin
Re: 262 xp
« Reply #4 on: August 02, 2003, 05:31:47 am »
Whether it's a better bar I can't say but I would think it would compare in quality, just keep feeding it lots of chain oil, keep the rails dressed, keep the groove clean and never use a badly worn chain on it.
Re: 262 xp
« Reply #5 on: August 31, 2003, 11:36:31 pm »
Well, I phoned Bailey's to order a mini-pro.They tell me Windsor quit making them for Medium Huskies.Got the same story from Celtic Distributers.
The bar I have mounted to my 395xp is actually a 20" Stihl mini pro.It came with a c-shaped clip to fit over the Husky's  bar studs.It worked fine other than I had to run an extra drive link so that the tensioning pin would line up.
The problem with trying to mount a 262xp is the oil gallery does'nt line up nor does the tensioning pin.
Guess I will try modding one this winter. :-/
Re: 262 xp
« Reply #6 on: August 31, 2003, 11:39:27 pm »
BTW Kevin.
What's your method for dressing the rails flat??
Thanks for your help!
Re: 262 xp
« Reply #7 on: August 31, 2003, 11:43:38 pm »
The reason it's great for log building is it's short overall height.With low profile chain, you can turn some sharp corners and plunge narrow slots.
Offline Kevin
Re: 262 xp
« Reply #8 on: September 01, 2003, 05:20:05 am »
I use the Pferd bar dresser.
Re: 262 xp
« Reply #9 on: September 07, 2003, 07:59:59 pm »
Kevin
It took me along time figure out why my saw would never cut straight.I always thought I was extremly poor at filing until I read your tip about keeping the rails dressed.I tried using two small blocks of wood to keep the file completely flat when dressing the bar.
Thanks for the tip!
The Pferd unit works much faster and no more blistered thumbs!!!
Offline Kevin
Re: 262 xp
« Reply #10 on: September 07, 2003, 09:17:24 pm »
You'll save many chains and prolong the life of your bar by dressing it  ...and not have the aggravation of those crooked cuts.
Glad to hear you like it.
Saw Anywhere!
