Get your Forestry Forum Hats while they last!
fishphamer, looked at the Cooks guides and think they are the best buy out there for the money. Stick with it you get the mill running right. Best of everything.
I was able to set mine in vertical plane by removing the wheels and attaching a straight edge to the hub. How do you attach the straight edge? Clamp, lugnut? Measure from the center of the hub to the top of the straight edge to make sure they are the same on each. From center of the hub to the top of straight edge on track? I am slow here. Or top of attached straight edge?I think if I understand the above part the rest will register with me. If the tires are in the same vertical plane but still not 90 degrees from horizontal plane track won't I still have trouble? I know this if for my benefit and do apologize for not comprehending, maybe someone can put it in simpler terms Next attach the string with the plumb bob on the small section extended from the top of the straight edge. Measure the distance from the string to where its tied to the front edge of the straight edge on the top. Next measure the bottom of the plumb bob to the bottom front edge of the straight edge, make adjustments until both measurements are the same. Do the same on the next hub without moving the sawmill. This should make both wheels in identical vertical plane. (Sorry for the rough drawing below)GF (Image hidden from quote, click to view.)
