Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Gonna build a swing mill!  (Read 14090 times)
Offline Chico
Re: Gonna build a swing mill!
« Reply #160 on: May 05, 2009, 02:29:00 pm »
Hilltop you can always use jack shafts instead of gerboxes saves weigt and movinparts in so far as the belts a lot of line shaft mills twisted the flat belts back in the day to make them do what they wanted them to
Chico
My Daughter My sailor MY HERO God Bless all the men and Women fighting for us today If you see one stop and thank them
Offline Hilltop366
« Reply #161 on: May 05, 2009, 08:50:27 pm »
 Chico I think we are on the same train there. I'm still looking for a engine, something with lots of torque thinking 4 cyl diesel like VW jetta or an Isuzu from a small GM truck.
Once I get an engine I can start the layout an figure out what parts I need to order like: bearings, shafts and pulleys etc.
Another idea I'm thinking of is a way to raise the vertical blade up out of the way to do double cuts on a cant to get wider lumber (this seem to be the major complaint of the two blade or swing saws).
Hilltop
Offline bandmiller2
« Reply #162 on: May 06, 2009, 02:49:24 pm »
Electric motors can be heavy to rotate but an arbor mounted right on the shaft would eliminate alot of rigging, 3 phase more the better.Find its pivot point.A three point 3 phase PTO driven gen.would be handy not only for milling but to run heavy duty plainers jointers est.Only throwing ideas out there.Frank C.
Offline DanG
« Reply #163 on: May 06, 2009, 03:37:02 pm »
Hilltop, the Mobile Dimension Saw uses v-belts with quarter twist to run the edger blades.  The main blade runs off of 6 belts directly from the engine, and the main blade's shaft doubles as a jack shaft to run the edgers via another 6 belts.  This system works extremely well, so you might want to borrow some ideas from it.
I'm fairly familiar with both the Lucas and Peterson mills, and have been wondering about something.  In order to double cut with the Peterson, you have to take the blade guard off.  The guard on the Lucas can't be removed, so you cannot double cut without turning the saw head around.  What I wonder is, why not make the guard movable, so you could just swing it to the other side for double cutting? :P
Offline bandmiller2
« Reply #164 on: May 07, 2009, 05:53:50 am »
Dan,I've wondered about that too its probibly liability in case someone left it in the wrong position.I'am sure it could be failsafed but that would complicate a simple mill and drive up the price.Liability is real and costly and gives night sweats to those who build sawmills.
Offline Meadows Miller
  • The Walkabout Sawyer
« Reply #165 on: May 07, 2009, 08:12:28 am »
Gday
I reckon thats the main reason also with the lucas the motors mounted low in the frame so double cutting is imposible after about 2" even after abit of workshop trickery on the guards  ;) :D Probobly to stop ppl trying  ;) Ive only herd of acouple of accidents with swingers usually through stupididty in modifying somthing or the other being A Idiot and not bolting the stops in when using the std tracks  :o :) ::) ::)Some Mothers Do Ave Em and you cant Idiot Proof Anything  ;) :D :D :D
Reguards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline Hilltop366
« Reply #166 on: June 11, 2009, 11:01:41 pm »
Where is the TinMan I have been waiting to see how his mill is coming along.
Anyone know?
« Reply #167 on: June 12, 2009, 09:10:00 am »
Gday
Hilltop Its been about two months hopefully Tinmans just been a little buisy Mate  ;) I know time can get away from you real quick  :o :) ::) ;) :D :D
Reguards Chris
Saw Anywhere!
