Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Today was a great day..  (Read 13436 times)
Offline tyb525
  • Always learning.
Re: Today was a great day..
« Reply #160 on: March 29, 2009, 11:30:06 am »
Here's some pictures...
Since ya'll want to see me in a picture, here ya go... :D
And the stack of lumber after about 6 logs..
LT10G10, Stihl 038 Magnum, many woodworking tools.
Offline Cedarman
    • Cedarusa
« Reply #161 on: March 29, 2009, 03:32:27 pm »
That was one fine stickering job 8) 8) tyb, you must have  a doctorate from the stickering and stacking school.
Offline pineywoods
« Reply #162 on: March 29, 2009, 04:17:43 pm »
That sawdust do pile up don't it. You gonna need a sawdust blower. Unless you can pull a Tom Sawyer on little brother.. ;D
1995 Wood Mizer LT 40, Liquid cooled kawasaki,homebuilt hydraulics. Homebuilt solar dry kiln.  Woodmaster 718 planner, Kubota M4700 with homemade forks and winch, stihl  012, 028, 029, Ms390
Offline tyb525
  • Always learning.
« Reply #163 on: March 29, 2009, 07:51:33 pm »
Cedarman, thank you :). The "trick" I use is to look straight down from above and line the sticker up with the ones below it. As you can see, it works pretty good, although it probably is a little slower than tossing them on there. I got pretty fast at it though.
The stack is 3 1/2' wide by the way, and as tall as I am (6')
piney, I see one of those in the near future ;D. for now I use a snow/scoop shovels and scoop it into a wheelbarrow every few logs. It's no big deal, and the price is right (free).
Also, what do ya'll use for stickers and how do you make them?
I have a lot of scrap pallet lumber (1x4 mostly), most of it is some kind of pine. I take those, cut them to about 4 ft long, and rip them to 1" wide with a 20 tooth rip blade on the tablesaw. It doesn't really matter the thickness of the wood if you always put the 1" dimension vertically. I can make a bunch up pretty quickly.
I've been kinda leery about cutting them on the sawmill, I guess just because I don't like the rougher surface it leaves.
Offline Fla._Deadheader
  • Linda Vista, Costa Rica
« Reply #164 on: March 29, 2009, 07:59:16 pm »
 Stand a few of them up, the 4" high, way, and run the sawmill blade through them. Make however many you have clamped, on every cut.
Offline tyb525
  • Always learning.
« Reply #165 on: March 29, 2009, 08:01:20 pm »
FD, that would be the smart way to do it.  ::) :D
Offline WDH
  • April 1998 - August 2008
« Reply #166 on: March 29, 2009, 09:46:46 pm »
Make sure your stickers are dry, otherwise you get might sticker stain that will not plane out of the subject lumber.
Woodmizer LT15, John Deere 2155, Kubota M5640SU and a passion for all things wood.
Offline tyb525
  • Always learning.
« Reply #167 on: March 29, 2009, 09:52:23 pm »
I believe all of mine are. Most of the boards they're cut from have some kind of grade stamp on them that mentions they are kiln dried or heat-treated (whatever that means).
Offline PineNut
« Reply #168 on: March 29, 2009, 10:14:01 pm »
I am lazy when it comes to stickers. Whenever I get a flitch that is not good enough to make lumber, it goes in a pile. I will peridocally take a stack of them edgewise on the mill and slide off 1” strips. The better strips go into a pile beside the mill and the trash goes into the slab pile.  The better strips are cut to length with the chain saw. Good ones are used for stickers and the rest go into scrap. It is quicker for me to cut three stickers and throw two of them away than to selectively cut the lumber into stickers
Offline brdmkr
  • I need to slow down...
« Reply #169 on: March 30, 2009, 12:00:35 pm »
All right!  Great!  Here is yet another example of someone who stickers wood that is pretty to look at.  My piles ................ don't look that way.  Good job Ty.
Offline Dodgy Loner
  • It's an anagram for "dendrology" and in no way a reflection of my personality
« Reply #170 on: March 30, 2009, 03:40:09 pm »
I was also going to congratulate you on the stickering job.  My piles don't look quit that nice, either :)
As far as cutting stickers, what I've found works best is to dry some 1" pine boards, then lay up 10 or 12 of them on the mill, side-by-side, and cut them 1" thick.  You can cut 100 stickers pretty quickly like that.  The rough surface makes no difference.
The sooner you fall behind, the more time you'll have to catch up.
Wood-Mizer LT-15, 25 HP
Offline Meadows Miller
  • The Walkabout Sawyer
« Reply #171 on: March 31, 2009, 05:12:23 am »
Gday
Its nice to see a pic of you Mate  ;) ;D 8)
Awsome job on the stickering there Ty  ;) ;D 8) 8) it could take me weeks to get a greenhorn to be able to stack timber like that mate  :o :) :) ::)   ;) :D :D :D ;)
But Just a side note tho Mate  ;)  the spacing just looks a little wide for 1" boards tho i space H/wood at 1' for inch for a guide just cut a couple of shorts at 12" for (1" thick) 18" =(1 1/2thick) and 24" =(2"or thicker) and you can just use them on the first layer to get things even and and started off right as You dont seem to have any dramas keeping them in a vertical line Mate  ;) ;D 8) be consistant with your spacing as it just might save some nasty supprises as it drys  ;) I dont want you feeling like im getting on your back about it tho Mate  ;) :D ;D ;D ;)
You would have just about cut enough now to cover the cost of the mill once its dryed  ;) just keep plugging away at it  ;) and keep up the good work Mate  ;) ;D 8) 8)
Reguards Chris
Jackson Lumber Harvester RMP 50" Manual Circular Mill #132 with Jackson Lumber Harvester Portable Edger, Meadows #2 delux manual circular sawmill & Edger, 1997 International 4700 Flatbed
Offline tyb525
  • Always learning.
« Reply #172 on: March 31, 2009, 04:24:42 pm »
Chris, that's my downfall as I seem to space them too far apart sometimes. There are 7 stickers per layer, the boards are 10.5 ft long. 7/10.5=1' 6" ft spacing, minus about 2 inches on the ends, which mean the stickers would be a foot and a few inches apart. I try not to get that technical, it takes enough time to line them up vertically. :D
Chris, and everyone else, don't feel like you're getting on my back, I love learning new tricks and tips. :)
Saw Anywhere!
