Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Margeson Insurance
Author Topic: Reflective insulation  (Read 2805 times)
Offline bandmiller2
Re: Reflective insulation
« Reply #20 on: March 08, 2009, 02:49:39 pm »
Save the scraps of that thin foil insulation and make disposible insoles for inside your work boots.Frank C.
Offline SPIKER
« Reply #21 on: March 11, 2009, 07:18:41 pm »
That PEX install looks good for the Mesh & stand offs, but looks like the PEX is too far apart for the northern climates. I'm told in Ohio you need 12" spacing, and 2 rows around perimeter 6" from outside walls.   This was told to me by guy who does the installs a lot.
I got some info from a company who also has a 1/4" thick layer of foam built into the foil bubble stuff.   Unfortunately that is in my email which crashed and is all gone.. :( thank you YAHOO.
I bought the foil bubble bubble poly for under my slab, but I'm putting it between a layer of 1" white styro and /4" blue styro sandwich.  (plastic/poly vapor barrier, 1" white styro, foil side down bubble bubble poly, and then 3/4" pink/blue styro, mesh on chairs PEX-AL-PEX and then 5" concrete with fiber in 6000 mix.) this is what my floor is going to be made up of. I bought the PEX-AL-PEX and the fittings & the "Foil Bubble Bubble Poly" from Farmtek a year or two back. just prior to the prices all going up.   the pricing is all back down now, reason I didn't get it in was I still had to have the outdoor pipe run prior to doing the floor. time money and loss of job kept the pour from happening for a couple years almost now...   This other foil bubble foam stuff looks good I have a sample from "PRODEX" http://www.insulation4less.com that will be going into my boots for this next winter!  thanks for that IDEA! lol should be just enough if I cut the stuff just right...;)
Mark M
Offline moonhill
« Reply #22 on: March 11, 2009, 08:26:02 pm »
I would place a caution on using the foil face bubble wrap as an insulator.  It needs an air space to work properly.  Squished under a slap leaves no air space, a vapor barrier, sure.  You can't beat 2" of foam under the slap, yes it cost more but you get what you pay for.  scsmith made a great point in his kiln being the same temp out side as in when the kiln is not running.  And being in the a warmer climate he will get away with it.  In the north it would be best to use the foam.
I run pex on a 1' grid also and rebar for a floating slab.  After you get done with the pour the wire mesh is usually on the bottom of the slab not in the middle where it belongs.
Tim
Offline OneWithWood
  • Board Moderator
  • showing the past to the future
    • RWT Biodiesel
« Reply #23 on: March 12, 2009, 11:49:51 am »
For the pured floors of the greenhouses we used 2" styro underneath the slab and on the sides of the slab.  A lot of heat is lost out the slab sides if it is not insulated.  The pex was installed on 12" centers using two overlapping rows.  The greenhouse stays nice and toasty during the winter.
One With Wood
www.rwtbiodiesel.com
Offline Engineer
    • BLAZE Design Inc
« Reply #24 on: March 12, 2009, 02:25:03 pm »
I put a product under my basement slab that is thin foam on both sides with a layer of foil in between.  I put wire mesh on top of that, ran my tubing on 12" centers, and ziptied all the tubing to the wire, and then poured concrete.  My floor stays nice and warm, it actually heats my entire house except for two second-floor bathrooms.
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end"
R. J. Wiedemann LtCol. USMC Ret.
Saw Anywhere!
