Peterson Portable Sawmills
Please visit this sponsor
Lucas Sawmills
Wood-Mizer Band Blades
Lawn-Gardening-Tools.com
Hutto Wood Products
Author Topic: OWB Redi-Chek Remote temperature Thermometer  (Read 573 times)
Offline adamant
  • Member*
« on: January 07, 2009, 08:08:55 pm »
FOR those who monitor your water temp with a  in-line temperature probe. where did u mount it?
http://www.maverickhousewares.com/et73.htm
Offline rowerwet
Re: OWB Redi-Chek Remote temperature Thermometer
« Reply #1 on: January 13, 2009, 12:23:53 am »
I use a maverick ET-710S remote thermometer, first I put the probe in the water tank of my Maxim pellet boiler. after 1 day the moisture got into the probe and it started reading 285* in my 175* water. I brought it inside and put it on a copper pipe in my basement that is part of the boiler loop. It dried out and now reads about 5* lower than the actual water temp. I have it on a part of my loop after the  house HX so I can see how low my water temp gets during a cycle.
When the remote probe was outside I kept loosing the signal and having to go out and reset them both, now with the remote in the basement I don't ever loose signal.
Central Boiler Maxim M-175 outdoor pellet boiler
Paloma Propane Tankless water heater
Offline submarinesailor
  • LT15, F250 SD 6.0L diesel, and a wife of 38 yrs
« Reply #2 on: January 13, 2009, 06:39:40 am »
When measuring water temperature, you should be using a Temperature Probe Well like this one:  http://cgi.ebay.com/NEW-316-Stainless-Steel-Temperature-Probe-Well-B35-2_W0QQitemZ330266296399QQcmdZViewItem.  Also, you should have some type of mastic down in the well for better temperature conductivity – it’s makes for much faster and more accurate readings.
Bruce
Saw Anywhere!
